Question about Microsoft LifeCam VX-6000 (68C-00001) Webcam
Buzzing in audio
My webcam has been fine, but now, out of nowhere, there is an annoying buzzing in the audio. What the... (the microphone is built-in).
    Scholar:
  • 202 Answers
It sounds like there is power interference on the audio wire. To be sure try plugging in a headset mic and see if audio noise goes away. That will isolate it to your webcam, and if the wire in it has interference you'll probably have to get a new one as the cost of repair would exceed the cost of a new webcam. You can try the free webcam test tool to try different mic combinations and see how the audio sounds.
Posted on May 09, 2010
No sound
Webcam Audio Getting sound to broadcast with streaming video using a webcam requires a few components to work in unison. Because most webcams do not have a microphone built in, you will need to buy a microphone for your computer or locate your microphone input if you have one built in (some laptops have these). The audio and video are two separate functions and must be diagnosed as such. b> Webcam Software b> If you have a webcam set up correctly and you are streaming video, then you are already halfway there. This details only how to make the sound work, so please refer to an article related to webcam video if you do not have that working already. The webcam audio and video both communicate with your computer via your webcam's software application. Due to this, you will find that there are settings specific to your webcam software for sound. Because there are various software applications that can act as an interface for your webcam, you will want to do a product-specific search on the Internet for your application's settings. Most often you will find the settings for sounds under Tools or Settings, then choosing Options or Preferences. Regardless of the application that you are using to broadcast your webcam video, you will need to ensure that your microphone is plugged into the "Microphone In" jack on your computer or laptop. The microphone input jack is commonly colored pink. b> Microphone Connection b> With your microphone plugged into the "Microphone In" audio jack, test the audio inside your webcam's software application. Most webcam applications allow you test your microphone by reading a sentence and watching a graph move as you speak. If you see this happening, then you have correctly hooked up your microphone. If you have a Windows PC you should also see if your computer recognizes your microphone by clicking on "Start" > "Settings" > "Control Panel" > "Sounds and Audio Devices." Under the "Audio" tab you will find a section for "Sound Recording." From there you can select or change your "Default Device." b> Hardware Troubleshooting b> In the event that your microphone is not recognized by your computer, continue hardware troubleshooting by contacting your computer's support staff. With a properly connected microphone and some minor adjustments in your webcam's software application, you should be broadcasting audio with your video in no time. Hope this helps.
Jan 22, 2013 | Gear Head Gearhead quick webcampro...
Trying to use a microsoft webcam, get the video but for microphone all I get when I try to play back a clip is a loud buzz and no recorded voice
depending on the webcam software, such as Youcam, you are using, go under setting and enable audio. It has nothing to do with sound setting of the computer.
Mar 05, 2010 | Dell Inspiron 6400 Notebook
Webcam audio problem
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone and have a built-in mike, between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Mar 23, 2009 | Microsoft Lifecam 6000 Webcam
Dell Inspiron 1525 buzzing sound
As you mentioned that you have downgraded to windows xp, did you change the sata operations to ATA mode from AHCI mode in bios before installing XP? If you have done this then try and reinstall webcam driver and also the audio driver. If possible get into device manager to check if all drivers are working fine.
Please rate your comment if its helpful.
Jan 20, 2009 | Dell Inspiron 1501 Notebook
GE Perfect Image Webcam 1.3 megapixels, installed software, microphone won't work, camera is fine
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Nov 03, 2008 | GE MiniCam Pro HO98656 Webcam
Audio delay
Jun 01, 2008 | Logitech QuickCam Communicate STX Personal...
Delay with sound
May 31, 2008 | Logitech QuickCam Communicate STX Personal...
Speach delay
Sound no longer works.
May 21, 2008 | Microsoft LifeCam VX-1000 Webcam
Microsoft LifeCam VX-6000 (68C-00001) Webcam Logo
172 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
