Question about Incase The Hardshell Case for the aluminum unib...
My incase case for my macbook pro is causing the hinges to crack
The black incase shell I have on my Macbook pro is causing crack in the upper bezel around the display. Is this common?
  • David Sirh Aug 20, 2012
    I had the same problem, too bad it ended up breaking my case around the hinges.
I've had the same problem when I had first installed my case. One day, when it was on the table, my friend leaned on it and there was a loud crack, which got me scared. Due to this, the cracking stopped. Turns out, there is a long tab to attach to where the fan opening is. Just flip your mac over, and push down hardly on the edge of the case, this way, it will be fully attached. Incase makes things perfectly, so if you don't install it correctly, it wont work. Hope this helps. Also, these instructions are not found anywhere.
Posted on Aug 18, 2012
  • belpben Aug 18, 2012
Macbook Pro Black Screen but Keyboard LED On
If you've already tried turning up the brightness of the screen (the "sun" icon), then you may have a problem with the backlight (possibly burnt out, in which case you'd need a new backlight bulb). See this post for more details:
How do fix my Macbook dark screen
May 13, 2014 | Apple MacBook Pro Notebook
Tip
MacBook Pro Display housing coming off
If you don't want to spend a lot fixing your old macbook, this is an easy way to do it!
I hope it can help you.
keywords
MacBook Pro Display housing coming off fix
MacBook Pro display housing partly unattached fix
Macbook pro screen separating from the case fix
MacBook Pro unibody housing fix
Macbook Pro screen separation problem fix
MacBook Pro screen glass coming off fix
Broken MacBook Pro hinge fix
on Jan 29, 2016 | Apple Macbook Pro 13 - Brushed Titanium -...
Macbook pro hinge crack
If the laptop still works you were lucky. The screen will die eventually when you open the lid too far again.
Take it to Apple and get it fixed.
Mar 28, 2014 | Apple MacBook Pro Notebook
Coffee spilt on macbook pro
When liquids meet electronics, you can't waste time. Conductive liquids cause most of the initial damage. Immediately unplug the laptop from its power cord, and pull out the battery. Don't bother closing programs or saving data. Stand it up on it's side to get rid of excess coffee. THEN...
Depending on your available tools and disassembly skills, remove more parts. Unscrew the outer case, and remove the plastic shell to expose the internal circuits. You can disassemble parts even further, separating individual components to help them dry. Do as much of this as you are comfortable with. Coffee is corrosive so you want to have ready an alcohol-based cleaning agent and q tips.
Feb 17, 2013 | Apple MacBook Pro Laptop Computer with...
The border around my screen has cracked in both lower corners. This is not the actual screen itself, but the metal shiny one around my 2008 MacBook Pro 15 inch. I was wondering how I, myself, could...
Depending on how far the crack goes, you may need just to replace the screen bezel, not a hard job. These go for ludicrous money 2nd hand and I enclose an example I found that would fit your laptop
(fix ya please note, I'm not promoting ebay)
http://www.ebay.co.uk/itm/MACBOOK-PRO-15-A1150-SCREEN-DISPLAY-BEZEL-SURROUND-/220816629778?pt=UK_Computing_Apple_Mac_Accessories&hash=item3369b26012
An alternative would be to fill the gap with some epoxy putty (would spoil the look of the Mac but would at least help keep the bezel together)
Jul 21, 2011 | Computers & Internet
How difficult is it to replace a CD-ROM drive in a MacBook Pro?
It is very difficult to replace an Apple Superdrive and is not recommended to attempt to do so yourself unless you have pre-existing experience in doing so. Before resorting to such desperate measures, try testing your hardware with the Apple Hardware Test. You will find detailed instructions on how to use AHT here.
May 03, 2010 | Apple MacBook Pro Notebook
Can't find a manual for macbook pro 17inch a1151 2.16ghz core2duo meed a teardown or repair manual replacing the lcd screeen which was sat on and the bezel snapped off at the hinge broke the built in cam...
OK!!
If you wish i could provide you a place where you could order Repair Manual. However, if you would like to replace screen, follow the below guid e:-
http://repair4laptop.org/notebook_lcd_display.html
Check for MacBooks section. Whether it's 17" or 18", the basics would remain the same. So, check and i am pretty positive, you would be able to change the LCD screen.
Also, look at one more Great Guide ;-
http://www.laptoprepair101.com/laptop/category/lcd-screen-repair/
If wanted a Video, follow this :-
http://www.youtube.com/watch?v=PRq0Rc8uYgM
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 15, 2009 | Apple Macbook Pro, -2.4GHz Intel Core 2...
Incase The Hardshell Case for the aluminum unib... Logo
224 people viewed this question
Top Incase Computers & Internet Experts
David Payne
David Payne
Are you an Incase Computer and Internet Expert? Answer questions, earn points and help others
