Question about Furuno 1650wf Gps Fish Finder Combo Navionics Charts
I want to transfer data between my 1650 wf plotter and my compute
I want to transfer data using a memory chip but i cant find a memory chip that will fit in the plotter. do they make them?
  • 64 Answers
Yes and you have to get them from a Furuno dealer as they have to be purchased from Furuno. The cost is about $200. If I can be of assistance email me: kevin@sun-me.net
Posted on Jun 14, 2010
What ram for
RAM is a type of computer memory accessed randomly during hard drive processes.
A computer's RAM is considered "random" because any byte of memory can be accessed without processing previous bytes.
Purpose of RAM
RAM is used to load and run programs or applications on a computer's operating system. More RAM means more applications and programs can be run simultaneously.
SRAM
Static Random Access Memory, or SRAM, stores data on a computer in a static method, meaning the data stays the same with power being supplied to the memory chip. SRAM is the faster RAM when compared with DRAM.
DRAM
Dynamic Random Access Memory, or DRAM, is a type of memory used in personal home computers. This type of memory must have an electrical current to refresh. DRAM is used more commonly because it's less expensive to manufacturer and install in chips.
EDO RAM
Extended Data Output, or EDO, is a new type of DRAM chip that uses technology to add 10 to 15 percent more speed than normal. A computer that uses EDO technology must meet the chip requirements or the EDO will not be recognized.
FPM
Fast Page Mode, or FPM, is a RAM speed enhancement that uses rows of bits selected in columns and rows of the memory.
FPM is used in EDO RAM.
Nov 02, 2012 | Computers & Internet
Memory full delete games? but i have a 8gb memory micro sd...how to set into memory card?
If you have full memory. you might have games, videos, music, pictures and sms that take up the spaceon your mobile. to transfer games connect phone to your computer and find the files of the games and transfer them to your memory card folder. If you use your user manual you will find steps for how to set your mobile to download all data to memory chip. Good Luck.
Jun 08, 2011 | Samsung GTC3300 Cell Phone
IWANT TO HOW DOWNLOAD VIDEO IN MOBILE CHIP
Three possible ways, easiest to most difficult:
1) Text message it to an eMail address.
2) Connect the (Cell Phone I presume), to a computer with a data cable.
3) Bluetooth transfer, Option/Send/Bluetooth to a device or computer or PDA with bluetooth capablilities.
Depends on the phone, if it video records, it probably has bluetooth too.
A computer with a bluetooth dongle will need to be set up.
4) A fourth possiblity would be to transfer the video from the mobile memory, to a removeable chip inside the mobile. Then remove the chip and put it into an adapter that allows it to be inserted into a SD (Secure Digital) card reader attached to a computer.
Dec 11, 2009 | Chips Computers & Internet
How much the memory on compaq v3000z can be increased and what type ddr, ddr2 or ddr3? currently it has 256.
Compaq Presario V V3000 Specification Memory Type: DDR2 SODIMM 200pin DDR SODIMM:
DDR, double data rate is a type of SDRAM in which data is sent on both the rising and falling edges of clock cycles in a data burst. It is usually referred to as DDR as opposed to DDR SDRAM.
SODIMM, small outline dual inline memory module. Smaller and thinner than standard DIMMs, SODIMMs are typically used in laptop computers.
Memory Speed: PC2-4200, PC2-5300 Chipset: Intel 945GM Chipset :
A group of chips that together make up a complete computer processing unit, usually on one circuit board (the motherboard). It may include the main central processor, graphics processors, secondary cache memory, and input-output controllers. Memory is one component controlled by the chipset. Standard Memory: 512MB Removable Memory Slot(s): 2 Max. Memory Per System: 2048MB (2GB) Max. Memory Per Slot: 2048MB (2GB) Dual Channel Memory Support: Supported Dual Channel :
A development in motherboard and chipset design that allows for increased bandwidth transfer when using two or more memory modules in separate transfer channels. These separate channels allow each module access to the memory controller, increasing throughput bandwidth. It is a good idea to use matched pairs of modules to ensure the best compatibility for dual channel operation. Tri-Channel Memory Support: Not Support Tri-Channel :
A development in motherboard and chipset design that allows for increased bandwidth transfer when using three or more memory modules in separate transfer channels. These separate channels allow each module access to the memory controller, increasing throughput bandwidth. It is a good idea to use matched three modules to ensure the best compatibility for tri-channel operation. Install Memory in Pairs: Not Required Install in Pairs :
Memory modules must be installed in pairs of matched memory size. This means that if you purchased your computer with 128 MB of memory installed and you want to add another 512 MB of memory, you must remove the two continuity modules and replace them with two 256-MB memory modules.
Aug 19, 2009 | HP Compaq Presario v3000z Notebook
Transferring photos from LG Vu to my computer
Though usual manage assistants can help you back the android phone, sometimes you may feel that is troublesome and not easy. Looking for android phone manager? It can backup Android Photos and transfer to PC. Easy way to Backup Photos on Android
Usually, you can back the android phone with USB, but sometimes you may feel that is troublesome and not easy. Looking for android phone manager?
Manage Your Android Device Efficiently It can transfer SMS from android to PC easily
Jun 15, 2009 | LG Vu CU920 Cellular Phone
Our computer cant access our psp memory card
fe4875a.jpg Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} PSP uses Sony Memory Stick Pro Duo and you need an adaptor (see picture) to use it on your external card reader or your laptop’s built-in card reader. Also, please check your card reader if it supports Memory Stick Pro Duo.
If you already have an adaptor but still doesn’t work, you can buy a PSP USB data cable to transfer files between your computer and PSP.
Apr 09, 2009 | Sony PlayStation Portable (PSP) Slim...
Where is the memory card folder of motorola l7 on the computer?
You cant access your memory card if you are in data and fax connection. You have to change the default connection as memory card then you can access it and there is no need to create a kjava folder its already in there its not visible by motorola phone tools.
Oct 05, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Transfering pictures from my memory card
when you connect your camera to the PC.
look in My computer and find the drive ( camera ) probably shows as Drive F:/ G:/ H:/ I:/ or similar.
Right click and open, then copy to folder on desktop, named My-Pictures ( Or similar ) once you,ve copied your photos from memory card to desktop on PC. Format the memory-card. which will erase all data. ( Right Click Format )
This should solve your problem.
Mike @ compurepair.
Mar 14, 2008 | Cameras
Sim card
You cannot save data on your SIM card other than contacts.
If you´re referring to the small Memory Stick Micro™ (M2™) in your phone or the internal memory you can use an adaptor an a cardreader, for the card, bluetooth or a cable connection to your computer for general data transfer, back an forth.
Feb 08, 2008 | Sony Ericsson Z610i Cellular Phone
Memory Stick error c:13:01
The problem is compatibility - or lack thereof. The older Sony cameras such as DSC-S50 (I have one), which used the original version of the Sony Memory Stick, can't read the new Memory Stick Pro - even with the "Duo" adapter.
I don't know all the specifics but it has to do with how the memory chip interfaces w/ the camera, how the data is transferred -- newer models of chips/cameras use a different, faster method for data transfer which the older cameras/devices can't do. Similar to "serial" vs. "USB" vs. "USB-2" issues with older computers.
So, sorry to say, but if you have a DSC-S50 camera like I do or similar older model, you're stuck w/ the standard Memory Sticks - which I have just discovered are very hard to find any more. I just finished a sweep of all major electronic stores/outlets in my area (silicon valley - where there's plenty of them), plus many web sites. And all you can find new, now, are the Pro/Duo chips, 1GB & up.
Anyway I hope this helps!
Dec 27, 2007 | Sony Cyber-Shot DSC-S50 Digital Camera
Furuno 1650wf Gps Fish Finder Combo Navionics Charts Logo
229 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Are you a Furuno Boating Expert? Answer questions, earn points and help others
