I have a Panasonic TH-42PZ700U that will not power on. The red indicator light is blinking 7 times. Trouble mode- SC Floating voltage SOS. Defective board possibility- SC, SU, SD, P board (SC, SU, SD > D, P). The P board has been replaced, and the problem persists. How can I determine which board to replace?
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details of the problem.
Thanks for using FixYa.
Posted on May 16, 2010
8 times red light blinking no pictuer in panasonic TC50u50
7 blinks? Driver SOS 2 SU / SD / SS Boards (SC floating voltage area). Check it. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts. Check this link too.
Dec 19, 2013 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Tip
BLINKS PROBLEM MALFUNCTIONING PART
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
on Apr 12, 2009 | Panasonic Viera TH-50PX80U Plasma TV
My viera plasma tv TH-42PZ700B won't turn on and it flashes red 7 times
7 blinks Driver SOS 2 SU / SD / SS Boards (SC floating voltage area). Check it. To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts. Blinking codes and details to Panasonic Plasmas are given.
Nov 30, 2013 | Panasonic VIERA Televison & Video
Hi Chester. My name is Dave Dollarhide and I live in Costa Rica. I use my Mom's stateside credit card for things like this. I have a TH-50PX80X Panasonic HD Plasma Television. It was manufactured July...
Good day!!!
2 blinking red LED lights indicate faulty 15v SOS D-Board
This are the blinking error codes.
1 blink STB 5v SENSE time out A-Board
2 blinks 15v SOS D-Board
3 blinks 3.3v SOS A-Board
4 blinks Power SOS P-Board
5 blinks 5v SOS D-Board
6 blinks Driver SOS 1 SU-Board / SD-Board / SC-Board
(SC Energy Recovery Circuit)
7 blinks Driver SOS 2 SU-Board / SD-Board / SC-Board
(SC Floating Voltage Area)
8 blinks Driver SOS 3 SS-Board / SS2-Board
(SS Energy Recovery Circuit)
9 blinks Communication Error between A-Board / D-Board
Panel-MPU and SYS-MPU
10 blinks Sub 5v SOS / Main 3.3v SOS A-Board
11 blinks Fan SOS PB-Board
try to reconnect all connectors inside your TV,if the problem persisted try to check the power supply output 15vdc while the TV is on..Let me know what is the reading of 15v output..you need a multimeter tester (range in dc)..Also trace the board where the 15vdc connected and try to disconnect the supply to it then check again if the voltage stable for 15vdc..
Thank you for using fixya..
regards,
chester
Jan 15, 2012 | Panasonic TH-42PZ700U 42 in. Plasma...
Panasonic 50 Plasma TV will not turn on and red light blinks 10 times.
Found thsi list two different places:
Oct 27, 2010 | Panasonic Televison & Video
My TV just turned off and the power light flashes 8 times. what is the flash code for 8 times on a panasonic TC-50PS14
thought I would post this here for everyone.
May 14, 2010 | Panasonic Televison & Video
Th42px80u- tv wont come on and red light flashes 10 times
Here are all the Panasonic blink codes.
Oct 21, 2009 | Panasonic Viera TH-42PX80U Plasma TV
No picture and the led ligth is blinking panasonic veita 52
If you have the flashing red light of death you can use the chart below, and call Panasonic to have it replaced. At the bottom is the list terms.
Panel = Plasma Display Panel (Plasma Glass)
D Board = Format Converter / Plasma AL / Sub-Field Processor
DG Board = AC-DC Converter / Digital Signal Processor / Full HD
Microcumputer HDMI Interface / Peaks Lite 2
H Board = Speaker Out / Sound Processor
AV Terminal / AV Switch
P Board = Power Supply
PB Board = Fan Control
SC Board = Scan Drive
SD Board = Scan Out (Lower)
SS Board = Sustain Drive
SU Board = Scan Out (Upper)
Jun 11, 2009 | Panasonic (TH-50PZ700U) Television
Panasonic TH42PA20 - No Picture
If you have the flashing red light of death you can use the chart below to see what the blinks indicate and call Panasonic and have the part replaced, at the bottom of this page is the meaning of terms.
Apr 13, 2009 | Panasonic (TH-50PZ700U) Television
After turn ON , blink 7 times and go off
Pamoya,
I ahve found a PDF in realtion to the "Blinking Light of Death",Panasonic has several problems. I have the same Plasma th42pz700u. the LED is blinking 7 times then repeats. The possible problem fron the PDF is this. Its in trouble mode SC floating voltage SOS. with defective boards. the boards are mostlikely one of the following depending on the flow chart. SC, SU,SD,or the P board.
Hope this helps.
Nov 18, 2008 | Panasonic TH-42PZ700U 42 in. Plasma...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
