Is it possible to use the modem Huawei EC228 with Windows 7?
Hi, I just went through this. I have Windows 7 and it would connect after 2,3,4 hours of dialing. I did a COMPLETE quicklink uninstall using Ccleaner (love them). I then reinstalled from the orriginal disk and blocked all updates. Now this is weired, I have to start computer with the USB unplugged, start Quicklink plug in then the computer asks configured quicklink mobil reconfigure quicklink? I click yes. Some times I have to change to another USB but this works. For unlimited data compared to others I'll do anything to keep Quicklink. My Sling Box my Hava and my Pogo are verry happy with this.
Posted on Jan 29, 2012
    Brigadier General:
  • 4,090 Answers
The supplied driver may not work But you can drive it by selecting the STANDARD modem option.Let windows write the driver it has from its own stock
Please rate my help++++Thyanks for using FIXYA
Posted on May 09, 2010
Unlock huawei E353Tu-6 mobem
HUAWEI E353 TU-6 and Huawei E353 are same modem...You can Unlock it using the Unlock Code...Visit the site Prounlocking.com/huawei-modem-unlocking-service/rs8wp10/ get the Unlocking service for your HUAWEI modem and unlock it from service provider lock.Follow the instructions below and unlock it step by step...
If your Huawei Device is an USB modem, please follow these instructions:
If your modem software asked for an unlock code when you tried using another network's SIM card, directly enter the unlock code we sent you when prompted by the software.
Otherwise try one of the following
Method 1:
This method requires your PC to have a software called Hyperterminal which can be found on the Start Menu in Windows XP, 2003 and other older versions of Windows:
Start - > Programs -> Accessories - > Communications - > Hyperterminal
1.Remove all other modems, printers and other devices connected to your PC other than your monitor, keypad and mouse.
2.Start your pc, connect your USB modem and open Hyperterminal.
3.Enter any name and select any icon and click OK to continue.
4.Set Connect using to your modem port, Huawei Mobile Connect - 3G Modem or the right COM port.
5.In the properties window that opens, without changing any values, click OK to continue.
6.Type the following command(replace the word UnlockCode with the unlock code we sent you):
AT^CARDLOCK=UnlockCode
and press enter.
7.Your modem should now be unlocked. Close Hyperterminal, disconnect your modem and connect it again.
Method 2:
Use this method if Method 1 does not work or if you are not able to follow method 1.
If your PC does not have Hyperterminal or if your using Windows Vista or Windows 7 you can use the following method.
1.Download our Modem Communicator Application. This application has been scanned by Mcafee and contains no virus. For your safety, please scan the application again after you download it.
2.Switch off your PC, remove all other modems, printers and other devices connected to your PC except your monitor, keypad and mouse.
3.Start your pc, connect your USB modem and open the application you downloaded(mc.exe).
4.Click on the Check for Ports button and wait for the response.
5.Click on the Check for Modems button and wait for a response.
6.Click on the Send AT Command button and make sure you get the response"OK".
7.In the text-box next to the Send User Command button, type the following command(replace the word UnlockCode with the unlock code we sent you):
8.Click on the Send User Command button.
9.Your modem should now be unlocked. Close the application(Modem Communicator), disconnect your modem and connect it again.
Oct 12, 2012 | T-Mobile Huawei T-Mobile Webconnect USB...
I have installed window 7 ultimate on my machine and have fwt huawei wireless modem,but i have struggled to find driver that i can use with the modem
Run application setup.exe on virtual CD created by Huawei Modem. If you installing this application, it will also installing drivers.
Aug 07, 2011 | Microsoft Windows Vista Ultimate Edition
I have huawei ets2558 with cable usb - rs 232 TUSB3410 but is not working with windows 7
found this solution on scribd.com
http://www.scribd.com/doc/23712717/Installing-Huawei-Modem-Driver-of-PTCL-v-Wireless-on-Windows-7
Apr 17, 2011 | Computers & Internet
How to install huawei ETS1001 (FWT) modem driver for windows 7 OS
Windows 7 should manually install the drivers for the modem. However, modems usually don't require drivers unless they're being plugged in with a usb cable. If possible, I would use the ethernet connection as it's much faster than the usb connection. If that's not possible, search on the manufacturer's website to find the driver you require. I did some searching myself and couldn't find anything specifically relating to Windows 7, but usually a Windows Vista driver will work.
Mar 05, 2011 | Computers & Internet
I need driver for Windows Vista/7 x64 or x86
you can take it by internet or any computer vendor.
Oct 31, 2009 | Computers & Internet
Can't Send My Huawei EC228 Connection to My Router from my PC
Only way that can be done is to unplug it from the pc and plug it into the laptop,But if your laptop has built in wireless,you can connect directly to the router via wireless connection.
Jul 26, 2009 | Linksys Wireless-G WRT54G Router
Installation software for Huawei EC 325 USB modem
I lost the installation Cd please help me
Dec 29, 2008 | Computers & Internet
What router will work with my Huawei EC228 USB modem?
The Huawei EC228 is compatible with the Cradlepoint MBR-1000 and the CRT-350.
Dec 01, 2008 | Computers & Internet
Tusb3410 vista
Sir , I am having Huawei Wireless Modem.(TUSB3410).For Internet connection(dail up). I am having windows xp I cant install the modem with this vista. .Please solve my problem...
Aug 21, 2008 | Computers & Internet
Computers & Internet Logo
171 people viewed this question
David Payne
David Payne
