Question about Video Cameras
Firewire Problem - HELP!!!!!
Hello, this is my 1st time on the site.
Recently I plugged my camcorder into my computer using my Firewire. It has always worked but for some reason it just isn't registering the fact that I've connected anything at all. There's no new message saying 'new device found' or anything, and I've done all the usual procedures such as restarting the computer, program etc etc. Nothing seems to work - can you help me? Suggest what the problem might be and how to solve it?
Thanks for reading.
  • jatinpayal1 Apr 25, 2008
    I ahve canon MVX40i, when I plugged my camcorder into my computer using my Firewire. It was working before but for some reason it just isn't registering the fact that I've connected anything at all. There's no new message saying 'new device found' or anything, and I've done all the usual procedures such as restarting the computer, program etc etc. Nothing seems to work - can you help me? Suggest what the problem might be and how to solve it?
    New Friend:
I have the same problem too. I get the "DV IN" flashing on the corner of the LCD Screen on the camera, but my computer doesn't go "ding" or Found New Hardware. Running Windows 7 Pro 64 Bit.
Any ideas?
Posted on Mar 20, 2013
    Sergeant:
    Champion:
  • 435 Answers
make sure you are using 4 pin to 4pin firewire which looks like this:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
After connecting,
Switch on the Cam.
Open Windows Movie Maker and import video from device.
Posted on Mar 10, 2009
SOURCE:
Step by step instructions to transfer recorded videos from jvc gr-d370u to Pc, please.
First, you need a Firewire connection (also called IEEE 1394). Most of PC computers don't have it, including mine. I bought a cheap Firewire card and installed it into an empty PCI slot, costed about $15.
I hope you don't have the USB cable and the firewire cable plugged into your computer at the same time. That can break things.
With the firewire cable plugged into the DV port of the camcorder and the firewire port of the computer and the camcorder is in Play mode (and plugged into the wall AC power with the power adapter), are you saying that when you launch MovieMaker and "Capture", the video camera is not recognized?
There are only two conditions that can cause this:
1) The firewire400 port on the computer is not working properly (how do you know it is working?). If you are using Vista Home Basic, chances are good that the IEEE1394a firewire port drivers were never loaded... so, that will be your first step. Get that port working and you'll be ready to go.
2) The DV port on the camcorder is not working properly. This could be for several reasons, but lets hope the DV port was not fried if you ever had the USB and firewire connections to your computer at the same time... Reset the camcorder to factory defaults by disconnecting all cables, removing the rechargeable battery and removing the little date/time button battery inside the camcorder. Wait for about 20 minutes. Put the button battery back in, then put the rechargeable battery back on. Set the date and time. Connect the firewire cable to the DV port, connect the AC power adapter to the wall, connect the other side of the firewire cable to the firewire port on the computer, launch MovieMaker - will it "Capture" from the video tape?
Anyone you know nearby with an Apple Macintosh and iMovieHD? You will need a 4-pin to 6-pin firewire cable and the AC power adapter. If it works with the Mac, we know it is not the camcorder's DV port. If it does not work, chances are good the camcorder's firewire port is bad.
Hope this was helpful?
Jan 30, 2011 | JVC GR D370US camcorder Mini DV
Hello, I recently shot a student film on a Canon HV20 HDV Camcorder, Problem is my school doesn't have an HD deck to allow log and capture. I have final cut 6 and still can't get the setting right to...
This camera works fine with FCP 6. I use it all the time. You need to use the Easy Setup for Firewire basic HDV 1080/60i (or whatever sounds like that). The camera should be connected from it's small connector FIREWIRE port(under back panel cover -- USB port will not work for this use) to either a Firewire 400 or Firewire 800 port (auto-switches to 400Mbps if the device doesn't support 800) on the computer. Cables are available with a variety of connectors for this for under $20 ea (it's digital -- i.e. don't overspend on cables unless you have an actual problem!).
Mar 13, 2010 | Canon HV20 HDV Digital Camcorder
Hi i have a jvc grd250u mini video camera
Try googling IEEE 1394 and accessing the Wikipedia site. It shows a picture of both. The 6 pin is decidedly larger and of a different shape.
Oct 05, 2009 | JVC GR-D250 Mini DV Digital Camcorder
Firewire and playback on TV
I don't know it this will solve your problem but I'm using a 3 pole male plug and getting picture on the TV (but not great picture - see above).
Jan 01, 2009 | Canon ZR900 Mini DV Camcorder
Uploading a video clip to my computer
The issue may be that your camera captures via FIREWIRE for video and USB for stills. It's a common issue. You'll need hook up your camera to a firewire port. If you don't have one due to this PCs age, you can always pick one up for about $20 and with XP pro, installation is practically plug and play.
But I'll tell you this. If you're computer is that old, do yourself a favor and double the memory. Video is a bandwidth hog and if you don't have enough RAM, you'll run into all sorts of dropped frames and synch issues.
It's also probably time to start looking to upgrade that Dell.
JD
Digital Camcorder HQ
Nov 30, 2007 | JVC Cybercam GR-D90 Mini DV Digital...
Firewire connection not responding
Take a magnifying glass to the firewire port on the camera. Check to see if it looks damaged at all. I've used firewire with my students for many years and this has happened to me on more than one occasion. The student is not as careful as he could be when plugging in the cable. The inside of the firewire cable becomes damaged. This is a cheap fix. Buy a new cable. However, when the port is damaged, it is an expensive fix. Since the computer recognizes another camcorder it may not be the computer. And if you are using the same cable, then it will probably be a hardware issue with the camera. Look at the port and let me know if anything looks out if place.
Jun 29, 2007 | Panasonic PV-GS65 Mini DV Digital...
Sony DCRHC30
The problem with Sony is that they're always trying to push something proprietary and lock in their own equipment as a standard. It is not likely that you are limited to a Sony computer. It looks like it has both firewire and usb 2.0 outputs. Provided you have one, or both, of these on your computer, there are many choices for software which will do the capture and subsequent processing. A lot depends on how much subsequent processing you want to do.
Sep 14, 2005 | Sony Handycam DCR-HC30 Mini DV Digital...
Sony DCRHC30
Sep 13, 2005 | Sony Handycam DCR-HC30 Mini DV Digital...
Video Cameras Logo
298 people viewed this question
Top Video Cameras Experts
Al Rush
Ekse
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
