Question about HP DeskJet 5650 InkJet Printer
My hp deskjet 5650 won't print color. How do I fix this?
ctf1800
  • 4402 Answers
SOURCE: Color Printing Problem
If a document displays in color on the screen but prints in black and white, try the following solutions. Print a test page to determine if the color cartridge is working
  1. Turn on the printer.
  2. If you have an HP Deskjet 710c, 712c, 720c, 722c, or 820c series printer, follow the instructions below:
    1. Turn the printer on.
    2. Press and hold down the Power button while pressing the Resume button four times.
    3. Release the Power button.
  3. If you have any other HP Deskjet printers, click here for instructions on how to print an internal test .
  4. If the printout is black and white, with no color, follow the instructions below:
    1. Open the top cover of the printer and remove the cartridges.
    2. Verify that the correct cartridges are installed in the printer. Click here to see if you have the correct cartridges . If the correct cartridges are installed, make sure that the tape has been removed from the cartridge nozzles.
    3. Insert the cartridges firmly back in their cradles and close the latches.
    4. Close the printer door.
Verify the correct printer is selected as the default printer
  1. In the software application that you are using to print, click File .
  2. Click Print .
  3. In the Print dialog box, verify that the name of the HP printer you are using is listed in the Name box.
  4. If the printer is not listed in the Name box, click the arrowhead to the right of the box.
  5. Click the name of the HP printer.
  6. Click OK .
Check that the printer settings are correct
  1. Close the software application that you are using to print.
  2. Click Start , click Settings , and then click Printers .
  3. Right-click the icon (picture) for the HP printer.
  4. In the menu that displays, use the left mouse button to click Properties .
  5. In the Properties dialog box, click the Details tab. (In Windows 2000, click the Advanced tab.)
  6. Check that the driver listed under Print using the following driver or Printer matches the HP printer you are using. The following setting may be in one of several places, depending on your printer driver and operating system.
  7. In the Details tab, click Setup . Under Printout, select one of the color options. (If other options have check marks, click in the check boxes to remove the check marks.) If there is no Setup button, click the Graphics tab, and then click Color . Under Color Control, choose a color option, and click OK . If there is no Graphics tab, click the Advanced tab and look for the text Print in Grayscale . If there is a check mark in the box by Print in Grayscale, click in the box to remove the check mark, and click OK . If you are using Windows 2000, in the Advanced tab, click Printing Defaults . Click the Advanced tab. The box by Print in Grayscale should not be checked.
  8. Click OK .
  9. Close the Printers window.
  10. Open the software application that you were using to print.
  11. Try printing again.
Install a new driver If none of the above options worked, the wrong driver might be installed on the computer. For the most current HP printer drivers, go to the HP Web site.
Posted on Jan 09, 2008
  • 46 Answers
SOURCE: How do I disassemble and assemble my HP 5650
Sorry no diagrams, taking a printer apart is not hard if you have some basic computer building experience, otherwise I would take it to a local computer shop for service. Unless its a cheap printer, than do it one step at a time and take some notes.
Posted on Apr 04, 2009
blueextc3221
  • 15935 Answers
SOURCE: can not install hp deskjet 5650 with Vista operating system?
Drivers for this printer are already pre-installed with Vista.
Power down your PC.
Plug in the printer (wall and PC).
Startup PC - Vista will install the drivers and printer automatically.
Thanks for using fixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 14, 2009
omerboo
  • 424 Answers
SOURCE: the Windows 7 driver for the HP deskjet5650 does
Driver download link: HP Deskjet 5650 Color Inkjet Printer Driver
Posted on Feb 03, 2010
  • 16 Answers
SOURCE: HELP PLEASE
Remove one cartridge and close the access door. If the cartridge light goes off, the bad cartridge has been removed. If the light continues to blink, remove the other cartridge and reinstall the first one. If the light goes off, the cartridge in the printer is the good one.
Posted on May 31, 2010
My HP Deskjet 5650 will not print in color even though i have installed a new cartridge yet the test page is in color??
Just check your printing property and choose color print and apply the settings and then ok.
Good Luck
Feb 26, 2011 | HP DeskJet 5650 InkJet Printer
Can I turn off the Color & Print Only Black Ink - On a HP 5650??
To print in black and white you will need to go into your printers properties and look for a Printer Preference and change it.
Best of luck..
Nov 18, 2010 | HP DeskJet 5650 InkJet Printer
I have an HP deskjet 5650 and just changed both black and color cartridges. Test sheet ran fine with color and black. Now I am trying to print a Print Shop color document and the printer will only print...
Click Start
Click Control Panel
Click Classic View
Click Printers
Select your printer
Right-mouse click on the icon
Click Properties
Set the printer to print in "colour", not just "black".
Aug 30, 2010 | HP DeskJet 5650 InkJet Printer
I have a HP DeskJet 842 C. I have a black
The nozzles of the color cartridge is blocked or u have set the photo print to gray print
Apr 30, 2010 | HP DeskJet 5650 InkJet Printer
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
I want a software for my printer.
No Problem! Just go to HP.com/Support and download it.
There is one thing, however. You must get THE software for YOUR Deskjet. HP lists four different models for the Deskjet 5650 series. The 5650, the 5650w, the 5652, and the 5655. The software MAY, be the same for all models of this series, but I don't take chances, and give erroneous information.
Viewing the Deskjet from the front, the model number is on the lower right side.
Here is HP.com/Support, the page for the Deskjet 5650 Color Inkjet series, and the specific page that you choose which model you have,
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_query=Deskjet+5650&submit.x=3&submit.y=2
I'm going to click on the top model listed, HP Deskjet 5650 Color Inkjet Printer,
as an example.
Now click on the -> Software & Driver downloads heading.
Now choose which Operating System you are using.
I see they only have the Diagnostic Utility available, if you are using Windows Vista.
If you are using Windows XP, they have the full software package available.
(HP Deskjet Full Feature Software and Driver -Date: 12-2003)
Jul 12, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
HP DESKJET 5650 - DOES NOT PRINT ON ANY PAPER
Hi dear; When you put in the new cartridge ,did you removed the plastic seal(tape)?
Dec 10, 2008 | HP DeskJet 5650 InkJet Printer
Cant print. the tear like button is blinking
I have a 6940 color printer and I am assuming the 'tear' buttons are the same. If so, it is an out of toner indicator.
Dec 05, 2008 | HP DeskJet 5650 InkJet Printer
HP DeskJet 5650 InkJet Printer Logo
461 people viewed this question
Ben Johnson
