Question about Samsung LN-T4665F 46 in. LCD Television
Emerson PL-P42W picture goes out occasionally. Sound continues to work. I have replaced the power supply board, the main board, and the picture still goes out. Which board is defective? Is there a repair manual that I can look at?
  • Samsung Master
  • 12,061 Answers
Http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_name=LN-T4665F
http://www.retrevo.com/support/Samsung-LN-T4665F-TVs-manual/id/1235ci960/t/2/
http://www.scribd.com/doc/26351010/Samsung-Lcd-Lb350-650-Training-Book
www.plasma-television-repair.com/Sample-Preview-Plasma-Tv-Repair-Training-Manual.pdf -
www.scribd.com/doc/.../LG-TV-Plasma-Training-Manual -
http://www.scribd.com/doc/13862078/SONY-KDL42XBR950-TV-Plasma-Training-Manual
I have given you LCD and Plasma, manuals.... As you have asked for two differing sorts of sets, ??? please find above service and training manuals to help you get a handle on your problem, I am glad to see you started at least in the right place, the Power supply, well done! Please use the troubleshooting procedures and i think you will soon be able to repair your set, usually all one can do is be a "Board Jockey", but you may have to go Down, to component level to effect repair, so be safe good luck. Troubleshooting say if it is shutting down, after a certain amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins. Now just replacing boards will most likely just end up with more faulty, boards, as related you MUST ensure that you have the cause of the event, before we change anything. I have seen so called, "Techs" replace every board, and virtually every component, and that STILL didn't fix it, because the "Fault, or Cause" lay elsewhere, and had not be repaired FIRST, you see that FIRST STEP, like everything in life, is, CRITICAL.
Posted on May 09, 2010
Emerson Pl p42w-10a Was watching movie,pause it came back screen was black, has sound,flashlight test neg,logic board green lightit blinks 2x and goes off. hdmiports work i can cast to the tv. no menu
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here
Oct 20, 2016 | Emerson Televison & Video
I have a Emerson LED 32 LF320EM4A has sound no picture
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Oct 01, 2016 | Emerson 32-inch 720p LED TV Refurbished
EMERSON PL-P42W-10A. By mistake I created a short trying to fix a light switch with tv on. after that tv shut down. not even with a new power board didn't worked. can someone help me please thank you.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 24, 2015 | Emerson Televison & Video
Video settings don't hold for more than 15min
Check capacitors. There are some very inexpensive meters for this and cheap capacitors are behind many problems in electronics. Once you find it is a bad cap you can replace it or the board.
Sep 05, 2014 | Emerson 42" Plasma Tv Pl-p42w-10a 720...
Emerson PL-P42W-10A Loud pop, then no power, AC power okTV is about 18 months old. While watching I heard a pop and now TV shows no indication of power. Checked AC, OK.Im guessing a power supply
Power supply is most likely but best way is to with a volt meter follow the voltage to see if have in and out of the power board.
IN will be AC and output will be various DC voltages.
Jun 12, 2012 | Televison & Video
I need a mounting stand for a emerson model #pl-p42w-10a
Search on Ebay.com for;
emerson pl-p42w-10a stand
Feb 26, 2011 | Televison & Video
I have a 19 inch emerson lcd tv that has no picture and as u plug it in the tv makes a whinning sound but as soon as u unplug it the sound goes away
More than the tv power supply board have problems in this tv,don't know yet.But the whinning sound,the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.First must see how it turn out.
Dec 08, 2010 | Emerson LD195EM8 19 in. LCD TV
My Emerson HDTV 32 inch sound stopped working all together. The picture is fine, but there's no sound.
everything with sound picture av component has to do with the main board of the tv not the power supply the only thing you can do its replace the main board not the power supply board or anything else cause it may be only a resistor or a capacitor but to replace it the guy that comes to do it will charge more than replacing it go to www.shopjimmy.com and check your tv model and it will give you what you need and the price and cheaper than the manufacturer
Apr 13, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Samsung LN-T4665F 46 in. LCD Television Logo
64 people viewed this question
Henry  Thomas
Henry Thomas
