Is there a reset button for rca tv model p52731wk
    Problem Solver:
  • 6 Answers
You can try a hard reset with this model. It requires unplugging it and leaving it unplugged for at least four hours. There are numerous set codes for this model, but it all depends upon the problem you are experiencing. There is no singular "reset button," though, as the system was simply too complex in its day to warrant one.
Posted on May 09, 2010
I need to reset my password on my rca HD52W55
Hello
If your RCA tv has locked or you want to reset your password you can opt any one of the followinf option to unlock it without any passcode nd can reset it after.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won
May 06, 2011 | RCA Televison & Video
Rca RCA model 20F514TD
You need to reset it give me 2 mins I will post the solution here
Mar 28, 2008 | Televison & Video
Where is the reset button on an rca model#p46924 46" projection screen tv?
Hello
Reset button is on its remote control itsef. You can locate it at the bottom right side. Point it towards TV, and reset the setting you want to. OK.
Apr 22, 2011 | RCA P46924 46" Rear Projection Television
I have model RCS P52731wk. No power when i puch the power button on the front. Is there an internal fuse?
THERE IS A FUSE, it is located inside where the power cord connects.
Let me ask does power light come on for just a moment at all?
SD TECH
Nov 03, 2010 | RCA P52960 52" Rear Projection Television
RCA P52731WK REAR PROJECTION NO RED ON SCREEN
The RCA model is a 3 CRT projection TV. Most probably you need a new RED CRT, or there is a problem with the R(ed) channel (the picture is made up of 3 component colors: Red, Green and Blue). No way of telling without testing of the projector. Sorry!
Jul 11, 2009 | RCA P52926 52" Rear Projection Television
My T.V. won't come on.
I would guess that the HV Block has failed. A very common failure. I would hesitate trying to replace it unless you are familiar with Projection HV circuits. You did good supplying
the Model # and Chassi #. both are required to get the proper part# if you try to get the part yourself or calling a service shop to fix it.
Hope this helps,
Skyassoc
Jun 22, 2009 | RCA P52926 52" Rear Projection Television
I have a 1994 RCA projector TV model# p52731wk. The picture is all blue. How do I change the bulbs?
Unless you have a source for the tubes then I can help, however, those tubes have not been available for over 4 years now. I recommend start looking into a new one or see if you can locate a refurbished projection set from your local Television Repair Center.
Apr 23, 2009 | Televison & Video
Where is reset button on 35 inch rca tv,I can only view 49
there is no reset button. Ypu need to give more detail about what i sgoing on with your set. Also what is the model and ctc numbers thfey can be found on the back of set. Unplug set for around 30 minnets then plug back in see if it wil work then.
Feb 28, 2009 | RCA 20" TV
Rca p52731wk wont power on
check for bad or broken connections around the high voltage transformer......
Feb 24, 2009 | RCA P52960 52" Rear Projection Television
RCA Home Theatre Wide Screen TV Model# P52731WK
This sounds to me like the parameters are off, I recomend only a service tech adjust this for you because the parameters can only be accessed by a service man, and they are critical, if done wrong the whole set can go out of wack.
Aug 15, 2007 | RCA 32V420T 32" TV
Televison & Video Logo
202 people viewed this question
Top Televison & Video Experts
