Lg washer Balance needed asap
I need info on how to balance my LG front load washer
  • wayneunland Mar 28, 2008
    Thank you i will start looking asap
  • robert samples May 11, 2010
    its in your owners manuel under instalation
    President:
  • 1,314 Answers
Your welcome
Posted on Mar 28, 2008
  • robert samples Mar 28, 2008
    oh by the way if this is a brand new washer then more than likely the shipping braces haven't been removed that's in the installations too but remove them first i don't know exactly where they are on lg but if they haven't been removed that will make it hop like a rabbit and all washers have them when they leave the factory
SOURCE:
How do i troubleshoot for a ball sensor,switch on a LG laundry washer?
machine needs to be level.so it cant rock side to side or front to back adj feet .when u load machine put half in and rotate drum half turn and put the rest of load in.that should balance load.dont overload.try running empty if it still showing ua
Aug 09, 2014 | LG WM Washing Machines
What are the most major issues with lg wm2016cw washers?
all washing machines suffer from same things.overloading throws balance off stuff in pockets finds its way to the pump too much powder is used causing blockages and soft water areas cause elements to fir up with limescale.eventally motor brushes wear.but theyre cheap to replace
Aug 05, 2014 | LG WM2010C Front Load Stacked Washer /...
LG stackable off balance
Open the machine covers and check the tub/motor shock absorbers or dampers for condition. Best to change all if one is faulty.
Apr 11, 2014 | LG Front Load Washer & Electric Dryer...
Lg washer makes a scubbing noise
1) normally the noises coming in spin cycles. You need to re-balance the clothes load.
2) Re-balance the clothes and repeat the step if necessary and try again.
3) of course try to Level the machine, with the instruc.manual procedure.
God bless you
Jun 28, 2012 | LG Washing Machines
Large loads won't balance & spin
Could be:
1. Broken spring(unlikely)
2. Bad shock absorbers (maybe)
3. Broken spyder-the Inner drum part that holds the drum to the hub(kinda likely). If inner drum can be moved without outer tub also moving in tandem, then broken spyder is likely.
Good luck
Mar 06, 2018 | LG WM2301HW Front Load Washer
I have a LG wm-2277hw front load washer. The inside drum seems to be out of balance. What do I need to do.
hi dear it seems that you need to change rollers seal and maybe the axis IF UR WASHER IS NOISY if not you have to check the tub supports up and down.
Sep 11, 2010 | LG WM-2277HW Front Load Washer
Comes up with the sign UE ??
Hi
Thanks for using FixYa. The error code UE means there are some heavy clothing is loaded. Rearrange items to help balance the load. If the imbalance is heavy, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and will display the error code UE. In case, if the load is small then you need to add 2-5 clothes to balance the load. If the load is out of balance then you need to rearrange the clothes to balance it. Although the Washer has an imbalance detection and correction system but if still the problem persists then it means that it is due to control error and needs to replaced preferably by a qualified service technician.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 09, 2009 | LG WM-2277HW Front Load Washer
LG wm2277hw front load shakes violently
Barry The repairman was right. The drum is out of balance because of the load amount .Thed clothes or items need to be distributed around the drom rather than just throwing in. When it comes to spin the imbalance causes the machine to shake and move across the laudry.
As it sometimes works This is probably when you are not doing a heavy load of washing, so it appears to work OK.
Pack it with less, also adjust the front legs a full turn higher than the rear so prevent walking when it spins.If you cant find the spanner that was included , just use an adjustable one.
Aug 21, 2009 | LG Washing Machines
Balancing
This type of thing should not be required. Front load washing machines (well, topload too i guess) will balance themselves out for the spin cycle unless the machine is grossly overloaded.
Good luck.
Apr 15, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
265 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
