Question about Mitsubishi WS-65807 65" Rear Projection Television
Can i replace the chip stk 392-570 to stk 392-560 is that ok ?
  • Mitsubishi Master
  • 1,212 Answers
I would definitely stay with the original stock number. Always a good rule, unless an authorized repair is warranted. As for resistor replacement any philips, NTE or RCA or an MCM stock number will be sufficient! You will need lots of patience and care as well as caution in removing and replacing any semi conductors. Good Luck...letme know how you fair! Thanks for asking!
Posted on May 09, 2010
Testimonial: "thankyou for the advise"
  • matt martin
    matt martin Feb 18, 2011
    You are most certainly welcomed!
My Mitsubishi tv vs70707 convergence problems. I just replaced my 2 STK convergence chips, and double check my soldering. Still have 3d pictures and can't find pico fuses. Glass fuses are ok.
Need a better picture, but usually fuses are listed as F(number) and would be on the power input to the STK chips. The resistors should be checked as well.
Feb 28, 2015 | Mitsubishi Televison & Video
Sony model #kp51ws500. Common problems for screen appearing warped
Need more details about how the screen is appearing warped.
if you have color separation and distorted image (warped,bowed, etc), then your Convergence ICs have failed. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
When you notice the symptons Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless.
Note: The STK chips are black about 3 inches long and will be mounted against a large aluminum heat sink (metal fins). They have about 20 pins on them. I believe they are STK392-560s in that set.
Feb 25, 2011 | Sony KP-51WS500 51" Rear Projection...
I have sony tv kp-65wv600. It has problems. color and video is blurry, double vision, letters are curved
You have a convergence failure.
Convergence IC failure is very common. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
Feb 24, 2011 | Televison & Video
The picture is warped red & blues distorted
Your Convergence ICs have failed. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
Note if one STK chip fails, you replace both regardless. They will be right next to each other.
Feb 20, 2011 | Toshiba 57H81 57" Rear Projection...
I have a mitusbishi ws-a65 hd 1080 tv. im having trouble getting the picture to line up with the shodows, its showing double, how can i fix this?
Your Convergence ICs have likely failed. It is very common on rear projections. Replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu.
Look for the converge option to align the red and blue colors
Note if one STK chip fails, you replace both regardless. There may only be one STK chip in this set. If there are two, they will be right next to each other.
Feb 20, 2011 | Mitsubishi Televison & Video
Tv is showing double images, not lining up
Your Convergence ICs have failed. Replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu.
Feb 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
My 65 inch sony tv half the screen is having colors like 3 d
Try This:
Feb 20, 2011 | Sony KP-51HW40 51" Rear Projection...
Stk392-110 chip is in my tv. can I use stk392-150 instead?
The model number you indicated: WS-55809 does not use the STK-392-110--IT USES TWO STK-392-570 CHIPS.
IF WHATEVER SET YOU HAVE USES A STK-392-110 YOU CAN USE THE STK-392-150 TO REPLACE IT--it is a higher current device than the 110 chip---there are some others even stouter but some create more problems.
I have used the 150 chip on several sets for the 110.
If this information helps you rate this solution as I do this here for FREE.
SD TECH.
Nov 14, 2009 | Mitsubishi WS-55809 55" Rear Projection...
STK IC 392-110 Chips
am having stk 4392 amp board 2 channel, i want to change this two channel in to one channel. what modofication should i do
Dec 02, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba 42H83 projection TV red convergence issue
the Convergence Ics are STK392-110 ICs you can get replacement Ics at the following link and they provide free instalation instructions.
http://servicemanuals.vstore.ca/
Jul 03, 2008 | Toshiba 42H83 42" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
277 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
