Question about Jenn-Air JGW8130DD Gas Single Oven
Model SVD48600 door won't open after clean cycle. Fan also locked on. Powered off overnight; no change: "Locked" still displayed
  • 17,970 Answers
That is a very complicated unit for the average handyman. It has electronic controls and a relay board, sensors and a locking mechanism. First thing I would check is the locking mechanism and the switch on it. Do this first and let me know if you find one of the switches defective or shorted. While there, check the light switch which is bi-functional being used for the light and also to tell the ERC the door is opened or closed.
Jenn-Air self-cleaning ovens have a special setting that allows you to clean the oven without chemicals or scrubbing. The oven heats to a temperature higher than used for cooking. The intense heat burns food spills and other residue off oven's inner surfaces.
Instructions
1. Remove the broiler pan and any utensils to prevent them from being damaged. Take out the oven racks, since the high heat might discolor them.
2. Wet a cleaning cloth or sponge with hot water and detergent. Wash off splatters or spills from areas that won't be affected by the cleaning process, including the oven door liner and the oven's front frame. Wipe up any excess grease or spills on the oven floor.
3. Close the oven door and press the "clean" pad on the unit's touch pad.
4. Enter the amount of cleaning time. For example, two hours is appropriate for a lightly soiled oven, three for average and four for heavily soiled. Cleaning should start immediately. The oven will remain locked during the cycle.
5. To delay cleaning, hit the "stop time" pad and enter the desired stop time. For example, if it is 9 p.m. and you want the oven to clean for three hours starting at 10 p.m., key in the numbers 1,0,0.
6. While the cleaning function operates, use the scouring pads to wash the oven racks and other utensils. Once the cycle ends and the oven unlocks and cools, you can use a damp cloth to pick up any loose or burnt debris inside. Replace the racks, broiler pan and utensils.
Tell us news.
Posted on May 09, 2010
I have a ge profile oven model starts pt 916 when i broil food the "locked" light flashes, i usually keep the oven door open so i can watch the food after about 5 min the locked light goes off
The only thing spring to mind Mary is that you somehow selected a cleaning cycle which superheats the oven and turns burnt on fat and grease to charcoal. The cleaning cycle never finished and the stove remembers it. The light is flashing to remind you. When the cleaning cycle is in progress, the door locks until it is finished.
Either remove the wall power plug or flip the breaker and leave it overnight. It _should_ erase it from the memory. Or you have to compete the cleaning cycle as per the instruction book.
Sep 05, 2016 | GE Ovens
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
No power, door locked
there are 2 thermal switches within the component area in front of the fan of the oven, they open and close like a switch at certain temps,if one of these go bad (stays open after oven clean cycle)and oven cools then it wont let power back to the unlock motor,you can access these switches and bypass them to test them,if lock works then merely replace that particular switch
Feb 04, 2013 | GE Ovens
My kenmore W&R locked to start the cleaning process and never turned on, but now won't open. It's been 4 hours.
Verify that the Whirlpool oven is connected to its power source. The oven may sometimes lock down if experiencing a power surge or similar electrical problems. Additionally, check that a fuse hasn't been blown in your home's fuse box. Some older homes may not have the proper wiring to support a high-powered appliance such as a Whirlpool oven. If you are not sure if your wiring is sufficient, consult a local electrician.
  • Check to see if the Whirlpool oven's Control Lock has been turned on, a safety mechanism designed to lock the oven and disable its keypad and display controls. A padlock symbol will be displayed in the corner of the Whirlpool oven's front display panel if it is locked. The oven will not unlock itself on its own even if it is disconnected from its power source. To disable, press and hold the "3" button on the keypad for five seconds until the padlock icon disappears.
  • See if the Whirlpool oven is engaged in its self-cleaning cycle. During the self-cleaning process, the stove will lock its front door and will flash "OVEN LOCKED" on its front display. This is to prevent users from accidentally opening the oven and burning themselves during the high-heat segment in the cleaning process. If you must open the oven, first stop the process by pressing and holding the "OFF/CANCEL" button on the stove's control panel. If the oven remains locked, wait for the internal temperatures to decrease. The locking mechanism is temperature controlled and will not unlock until internal temperatures have cooled.
  • Contact Whirlpool's service department if your Whirlpool oven remains locked and you cannot troubleshoot it or open it. All Whirlpool self-cleaning ovens are covered for five years after the original purchase date. Call the warranty team for assistance by dialing toll-free (800) 253-1301 in the United States, or (800) 807-6777 in Canada. Be prepared to give the oven's model number and purchase date
  • Dec 11, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
    I have a Maytag range that is displaying F9. The oven door is locked as well as the cook top that allows finding the model number. Please help if you can. I appreciate it so much.
    Hi
    F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
    Daniel
    Aug 07, 2011 | Maytag Ovens
    Can't release door after cleaning
    Sorry you are having trouble, unfortunately this is not an easy one to fix.
    If the oven is cold then the sensor is telling the control it that oven is still hot or the control is stuck in the hot position.
    There is not an easy way to unlock the oven without pulling the unit out and taking the top off to get to the latch.
    I have attached a link to the service manual if you wish to attempt it.
    If not I would suggest turning off the circuit breaker to the oven and letting it sit overnight. See if that will reset the issue, if not you will have a big job ahead of you or a costly repair.
    Sorry I do not have good news for you on this one.
    maytag_library/docs/16010191.pdf
    May 09, 2010 | Jenn-Air JGW8130DD Gas Single Oven
    Can I clean a TruTemp oven with soap and water without ruining it?
    Yes you could clean it.
    Check few details :-
    t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
    How to self clean
    If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
    The oven door must be closed and all controls set correctly for the cycle to work properly.
    Before a Clean Cycle
    For the first self-clean cycle, we recommend
    venting your kitchen with an open window
    or using a ventilation fan or hood.
    Remove any broiler pan, broiler grid, all
    cookware, probe and any aluminum foil
    from the oven—they cannot withstand the
    high cleaning temperatures.
    NOTE:
    If your oven is equipped with nickel oven
    shelves, remove them before you begin
    the self-clean cycle.
    If your oven is equipped with gray
    porcelain-coated oven shelves, they may
    be left in the oven during the self-clean
    cycle.
    Soil on the front frame of the range and
    outside the gasket on the door will need to
    be cleaned by hand. Clean these areas with
    hot water, soap-filled scouring pads or
    cleansers such as Soft Scrub®. Rinse well
    with clean water and dry.
    Do not clean the gasket. The fiberglass
    material of the oven door gasket cannot
    withstand abrasion. It is essential for the
    gasket to remain intact. If you notice it
    becoming worn or frayed, replace it.
    Wipe up any heavy spillovers on the oven
    bottom.
    Make sure the oven light bulb cover is in
    place and the oven light is off.
    IMPORTANT: The health of some birds
    is extremely sensitive to the fumes given
    off during the self-cleaning cycle of any
    range. Move birds to another well ventilated
    room.
    NOTE: Use caution when opening the upper
    oven after the self-clean cycle has ended.
    The oven may still be hot.
    How to Set the Upper Oven for Cleaning
    On models with Gas/Control Lockout,
    touch and hold the Gas/Control Lockout
    pad for 3 seconds to turn it off.
    NOTE: The surface burners must be turned
    off prior to the self-clean start time.
    If your model has a latch, latch the door.
    Touch the Self Clean pad.
    Using the number pads, enter the
    desired clean time, if a time other than
    4 hours is needed.
    Clean cycle time is normally 4 hours. You can
    change the clean time to any time between
    3 hours and 5 hours, depending on how dirty
    your oven is.
    Touch the Start pad.
    On models without a door latch, the door
    locks automatically. The display will show
    the clean time remaining. It will not be
    possible to open the oven door until the
    temperature drops below the lock
    temperature and the LOCKED DOOR
    light goes off.
    The oven shuts off automatically when the
    clean cycle is complete.
    When the LOCKED DOOR light is off,
    slide the latch handle to the left as far
    as it will go and open the door. If your
    range does not have a latch, the door
    will unlock automatically.
    The words LOCK DOOR will flash and
    the oven control will signal if you set
    the clean cycle and forget to close the
    oven door or forget to latch the door
    on models with a latch.
    To stop a clean cycle, touch the Clear/Off
    pad. When the LOCKED DOOR light goes
    off, indicating the oven has cooled below
    the locking temperature, unlatch the door
    (on models with a latch) and open the door
    How to Delay the Start of Cleaning
    Make sure the clock shows the correct time
    of day.
    the door.
    desired clean time.
    Touch the Delay Start pad. The earliest
    start time you can set will appear in the
    display.
    Using the number pads, enter the time
    of day you want the clean cycle
    to start.
    locks automatically. The display will show the
    start time. It will not be possible to open the
    oven door until the temperature drops below
    the lock temperature and the LOCKED DOOR
    light goes off.
    The words LOCK DOOR will flash and the
    oven control will signal if you set the clean
    cycle and forget to close the oven door or
    forget to latch the door on models with
    a latch.
    pad
    (on models with a latch) and open the door.
    After a Clean Cycle
    You may notice some white ash in the oven.
    Wipe it up with a damp cloth after the
    oven cools.
    If white spots remain, remove them with a
    soap-filled scouring pad and rinse thoroughly
    with a vinegar and water mixture.
    These deposits are usually a salt residue
    that cannot be removed by the clean cycle.
    If the oven is not clean after one clean cycle,
    repeat the cycle.
    You cannot set the oven for cooking until
    the oven is cool enough for the door to
    unlock.
    While the oven is self-cleaning, you can
    touch the Clock pad to display the time
    of day. To return to the clean countdown,
    touch the Cooking Time pad.
    If the shelves become hard to slide, apply a
    small amount of vegetable oil or cooking oil
    to a paper towel and wipe the edges of the
    oven shelves with the paper towel.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
    Jenn-Air stove locked
    After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
    Dec 10, 2008 | Ovens
    Oven door won t open after self clean cycle
    Frigidaire CGEB27S7CB built in wall oven. Set to clean oven yesterday and after cycle door stays in locked position. Can not open door. I tried re setting clean cycle and cancelling but will not unlock door.
    Dec 22, 2007 | Frigidaire GLEB27S7A Electric Single Oven
    Jenn-Air JGW8130DD Gas Single Oven Logo
    179 people viewed this question
    Top Jenn-Air Ovens Experts
    Dan Webster
    Dan Webster
    Oloyede Monsuru
    Craig Butler
    Craig Butler
    Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
