Question about Kenmore 98702 Stacked Washer/Dryer
I replaced the dryer shaft and bearing assembly on my Kenmore stacked washer/dryer. As I was reassembling the unit, I discovered a red and black wire running from the front of the dryer toward the rear that is disconnected. What could this wire be and where should it be connected near the back?
  • 2 more comments
  • 5huskies May 09, 2010
    I'm sure manuals and wiring diagrams would show me the answer, I do not have those materials. The problem is a single wire that is red and black, not two wires. I just need to know where to reconnect that wire.
    The wiring diagram provided might have been helpful but it would not print. Further, when I try now to reopen the diagram it will not open. Anyone else have a solution?
    I have located the correct wiring diagram and I see the red/black wire in the dryer diagram indicated "to L1 connector". I see in the washer diagram a black wire indicated "to dryer L1 connector". I see no disconnected black wire anywhere. The red/black wire appeares to have been connected to a crimped connector/connection.
    For your reference, the model number is 417.94812301. The red/black wire is connected on one end to a large connector block, perhaps the L1 connection. The other end, however, is the disconnected end which also suggests it may go to a red wire. I have examined all of the blocks I can see and find no obvious openings.
  • Kenmore Master
  • 8,220 Answers
If your dryer has the sensor strips that could be to the sensor strips.Do you have the sensors inside the drum under the filter?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 10, 2010
  • Kenmore Master
  • 1,606 Answers
What is the complete model number of the unit ? Need the first 3 followed by the period and all numbers after .
Posted on May 09, 2010
  • Mike Smith
    Mike Smith May 09, 2010
    check the terminal block for an empty connector and use a new terminal to reconnect to the same terminal . Strictly the same terminal on the block .
    President:
  • 1,554 Answers
Refer to this wiring diagram for your reference. It is recommended to print it out for a clear view of the wiring labels.
  • Kenmore Master
  • 12,061 Answers
Http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%203979540.pdf
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0309533.pdf
Ok, there are the service manuals, you should be able to find everything out from those manuals, they have circuit diagrams etc. Red & Black, usually go to the Thermal Cutout, but please check. It's in the manual.
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
Can I change the 220 plug on the stackable unit from a 4 prong back to a three prong.
Yes you can. Green in the middle and red and black to the matching sides coming in from above the block where your connecting the cord
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 07, 2012 | Kenmore 98702 Stacked Washer/Dryer
Dryer drum will not move on model 417 938 022 00. Found 3 screws inside?
Hi, Could be a bad bearing on the drum. Also check for lose or missing shaft screws.
Aug 23, 2011 | Kenmore 98702 Stacked Washer/Dryer
Loud squealing sound when the basket first spins up this is a Kenmore stacked set, washer on the bottom, and dryer on top
Your problem could be a bad bearing...The drum rides in a bearing at the rear middle of unit..Its basically a plastic insert...When the dryer is first started the bearing will squeal until the plastic warms up..Normally you will hear the squeal at the back middle of dryer...Your problem may also be the belt tensioner...Again a plastic wheel with a metal bearing inside...Normally this squeal will be from start to finish..
Apr 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
Need to change wiring from 220V to 110V
Black or red is hot; green is ground; white is your neutral. The black should be for 120 and the red for 220.
Jun 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
I AM REPLACING THE BASKET ASSEMBLY ON MY KENMORE FRONT LOAD WASHE
The shaft on the spin basket assembly is not lubricated. The shaft is inserted through the sealed bearings located in the rear outer tub shell. Placing any grease on the shaft would end up in your wash and damage your clothes.
Apr 03, 2009 | Kenmore 42822 Front Load Washer
Kenmore stackable dryer makes squealing sound. need to find out where to get replacement belt. heard people say open it up and replace the belt but we dont know where it opens up.
probably not belt most likely rear drum bearing which means a complete tear down of dryer from front console,rop and front panel will have to be removed then drum will need to be lifted up out of bearing cup belt removed part is avaiable from sears .com or local parts house unit is made by fridgedaire
Dec 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer Squeals
my sears kenmore 417 stacking get things caught every time in the dryer and leaves some brown stuff on all my clothes.
How can I keep things from getting caught??
Jul 13, 2008 | Kenmore 98702 Stacked Washer/Dryer
Reassembly help
try kenmore website for 800 customer service number
May 23, 2007 | Kenmore 94702 Front Load Stacked Washer /...
Kenmore 98702 Stacked Washer/Dryer Logo
79 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
