Question about Maytag Atlantis MAV6451 Top Load Washer
How to fix
Hello Wilbur,
Thanks for your respond.
The washer is 3 year olds and on a solid level surface, all 4 corners/levels adjusters are good.
  • 185 Answers
Hello huynguuyen, grab the middle or the base of the agitator and move it to the front back and side to side doe it move without hitting the cabinet on any of the four sides
Posted on Mar 28, 2008
SOURCE:
How can I adjust an upright freezer door ?
Hello there,
It is always the feet and their adjustment and floor must be level
From the user guide it says
;The freezer must have all bottom corners resting firmly on
a solid floor. The floor must be strong enough to support
a fully loaded freezer.
NOTE:It is VERY MPORTANT for your freezer to be level in order to function properly. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems.
To level Upright Models:
After discarding crating screws and wood base, use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, half a bubble higher, so that the door closes easily when left halfway open. ;
User guide here
http://crosley.com/assets/product/1707/useCareGuide.pdf
Sep 24, 2014 | Crosley CFUM21LW 20.6 cu. ft. Upright...
Was installed on a solid, level floor, adjustable legs flat at their lowest level and cannot wash a load of clothes due to the shaking vibration and banging around of the unit.
GE thats rare///Is the unit solid frount to back corner to corner can;t be any movement there at all///more inportant to be solid then level grab corner of machine and see if there is any movement from rear corner left to front corner right and then the other side also are the shipping bolts and spacers 4 removed from the rear of unit..hope this helped.....good luck if I helped you please vote
Feb 06, 2011 | General Electric WCVH6800J Front Load...
Washer will not stop shaking during spin cycles, we have removed akll shipping bolts
Place a load in the machine use a good level to get machine perfectly level. Now put machine on spin and check the feet. Find the one that is not solid and slowly adjust it until it stops shaking. PS place level on flat top surface and level side to side and front to back.
Jan 26, 2010 | LG Washing Machines
Vibration during spin cycle - "walking" across floor
dear sir/mam
please check the floor level of your washer by using the spirit level,if there is difference please adjust the level by screwing the legs of the washer,then vibration will be stopped.
Jun 01, 2009 | Whirlpool Inglis IP4400 Washer
Noisy washer and jumps around
It could be a few different issues. Check to be sure your washer leveling legs are set correctly. Also many newer washing machines have what they call shocks, stabilizing struts. Those can fail over time and cause your machine to be off balance and walk the floor/vibrate. When is the machine nosey? If when its filling with water it could be a water inlet valve. Or during the spin cycle it could be a drum roller, belt, pulley, Or top bearing glides to name a few things.
May 24, 2009 | Whirlpool WTW5300SQ Top Load Washer
Leveling Maytag Neptune
Leveling a washer can be a pain sometimes.
1. You must have a solid foundation. The floor where it sets must be good.
2. Use a level. When adjusting the legs keep the washer as close to the floor as possible.
3. Problem inside the washer. Look inside for anything obvious i.e. loose springs, loose counter weight.
Dec 21, 2008 | Maytag Neptune MAH6700A Front Load Washer
Walking Washer
due to weight and normal motion during wash/spin a very sturdy floor is necessary under front loads also some floors are a little slick and sliding may occur ck for weak floor and maybe some kind ok rough cushion under feet to reduce sliding also if on pedistals even more vibration may occur be sure all screws in pedistal are secure usually 4 from top onto bottom of washer also adj legs to lower unit as close to floor as possible and tighten lock nuts
Apr 25, 2008 | LG WM-2277HW Front Load Washer
Whirlpool duet sport..vibrates during spin and "walks"..on pedistal.sitting on tile
I just bought this washer and had two problems with it. 1 the vibration at medium spins and 2. a squeeking spring (every time the drum rotates a little squeek, but when spinning the squeek sounds constant.
What I discover in solving both my problems with the same solution. I had to ensure all 4 feet well on the ground and that the top of the washer was perfectly level. At one time I was out only about 2 mm on one side, but the bubble was slightly to one side on the level but still in between the level's markers. I tested with a load, and both problems were still there. Turn feet 1/2 turn on the side needing adjusting. Ran another load and you guessed it, no squeak, no vibration, spinning was quiet, I had to go over to check to see if the machine was going through the cycles. I couldn't believe that a few millimeters could make such a difference.
Now I am pleased with the performance, not to mention how clean the clothes are and the savings on water and drying.
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Off Balance
1. Check all the filtration system...ie pump and all hose's and connetions there after...one of the most common is a coin where the drain hose connects to the back of the machine.
2. Age of the machine could mean the suspension is getting soft...only fix is 4 new suspention rods.
3. Balance switch Adjustment..most modern washers do not have this thou...not sure for your model
Jan 03, 2008 | Admiral AW22 Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
62 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
