Question about Kenmore Vacuums
I have a kenmore whispertone 300, model 116 28612791, serial # DH0809803. I need to take the power head apart to clean it but can't figure out how. I don't have the manual for it. Is there a page of instructions I could print out? Thanks Lisa Coster valcoster@yahoo.com
SOURCE: Whispertone powerhead handle release replacement
Take a butter knife and/or flat head screwdriver and press forward on the four tabs that retain the pedal.
Posted on Jun 02, 2008
Agent Don
  • 310 Answers
SOURCE: The shaft on the motor
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=661780
Generic problem for all Vacuums
Posted by tsnater on Jun 10, 2008
The shaft on the motor for rotating the brush is not moving. It is a Kenmore Whispertone 12 V Model 116 3521290.
I am suspicious of the Belt Protection system.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that you have a motor that is froze up and would be in need of some type of service, whether it be the fan(s) on the end of the motor, the carbon brushes are sticking and bound up, or the armature would be the last thing. Just be careful that the repair cost and labor do not exceed the cost of a new motor. The motor shaft should @ all times should spin freely. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 11, 2008
SOURCE: Need the manual for this vacuum cleaner
Try this link also
http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action
Posted on Jun 14, 2008
SOURCE: Hoover Floormate H3000-050 power head/taking apart
I didn't find this as difficlut as red devil 6, however, having 2 people helps. Remove the brush assembly using the 2 brush release buttons. Remove the front nozzel by sliding the 2 nozzel release clips away from the unit. Do NOT remove any screws from the underside of the floor mate base.
Before you begin....on the new wheel assembly, locate the "spring loaded lever" that is attached by the 2 brass screws. Notice that it can be pushed to the side and it locks in place. If pushed again it releases. This is important when you go to make sure the wet/dry pick up indicator is working near the last step of the process.
The top grey cover on the base of the unit lifts off accessing the hubs that hold the handle to the base.
To remove the top grey cover, there are 6 clips that you have to move to one side or the other with a narrow flat blade screw driver. All 6 of these clips are accessed from the underside of the base unit. Work gently...red devil 6 was correct, you can break things easily.
GENTLY pry up the top grey cover exposing the 2 black hubs holding the handle to the base. Remove the 4 screws holding the hubs to the base. I found it easier to have the handle in the down position to remove the cover. I found it easier to have the handle up for 2 screws and down for the other 2 screws.
This is where 2 people come in handy. One person (me) holds the handle and base apart while the other person (my wife) installs the wheel assemlby. It is a little tricky to get in place. My wife found it easiest to install the nubs first (yes nubs, like a little axel that holds the wheel assembly to the base) at the back of the wheel assembly, then slip the pin at the front of the wheel assembly into its position (where the old one came from).
Reset handle and hubs into the base and tighten 4 screws.
Before you go any further, make sure your dry/wet pickup indicator works.....The INDICATOR is the thing that has two red spots on it and tells you if you are on wet or dry pickup. GENTLY TRY to work the wet dry pedal with you HAND to see if the indicator swithces between wet and dry easily. If you are not GENTAl and you force it, you WILL BREAK it. If it does EAISLY go back and forth between wet and dry you have to reset the indicator. Push the indicator stem (the stem that sticks down into the base) up through the base and push the spring loaded lever (see before you begin above) assembly on the wheel assembly to the side. Reinstall the indicator stem and make sure the little spring end is positioned over top of the plastic stub. Recheck GENTLY the function of the wet/dry pickup foot pedal, but use your HAND.
Finally, reinstall top grey cover. It's a little tricky but we found it helpful to have the handle in the down position. Make sure it snaps back into place.
You did it!.
This took my wife and I about 45 minutes to 1 hour....but at least half of the time was spent going slow to ensure I didn't break anything else.
Good luck.
Posted on Apr 06, 2009
SOURCE: I have a bad connection on my powercord on my
seems like a personal problem,
Posted on May 11, 2009
Manual for kenmore whispertone 300
Which specific model in the WhisperTone line do you have? The manual may be available from Sears Parts Direct. Start here: http://www.searspartsdirect.com/partsdirect/user-manuals .
The manual for the Kenmore 116.27512790 canister vacuum is available here: http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0807641.pdf . This may be useful if the vacuum is similar to yours.
I hope this helps.
Dec 21, 2014 | Kenmore Vacuums
The power head of my 1165581590C Kenmore Power mate Whispertone 12 amp vacuum won't open. It is an older model and it desparately needs a clean!
I am not 100% sure of the model number but most of their powerheads come apart quite easily if you know how. There is a light lens cover on the top of your powerhead. On each side of this cover there is a little clip that holds it in place. You can usually see that spot by simply taking your thumb and pushing the light cover to one side or the other. Place a small flat head screwdriver in that slot and gently pry upward.
Once that cover is off, you will see two screws. Remove those two screws. Now simply grab each side of the cover towards the bottom and back of the nozzle and pull out. This should release it from the base. It will lift from forward from back to front..
Reassembly is pretty easy. Just reverse the instructions.
Let me know if this helps.
Dec 30, 2012 | Vacuums
I just need to get the power head apart to replace the belt. The two side tabs by themselves don't release the plastic...it is still firmly attached in the middle.
Look for a few screws under the machine, they will probably have Philips (star) heads. Remove these and the power head should come apart so you can access the belt and pulleys.
Feb 17, 2011 | Kenmore 23313 Whispertone Bagged Canister...
Help! i have a whispertone 300 model 116 28612790. the retractable cord is jammed & i could only get the front part of the canister open that houses the motor, etc. there are only 2 screws to open it...
even if you get it apart chances are it needs a new spring but it requires a special tool to get the rubber molding off that separates the top from bottom and sears repair guys and vacuum shops have them. I would take it to a used vac store and get them to fix it before you try yo remove the rubber seal as it will not go back on well and that will cause the machine to not get aproper seal and lose airflow.
Oct 06, 2010 | Kenmore 23313 Whispertone Bagged Canister...
I don't have my manual, but the carpet nozzle doesn't work and I want to replace the belt, but can't figure out how to take the nozzle apart.
the top headlight cover should just pop off and there will be two screws underneath. then on the sides there are clips, just use a flat head to pop it off. also try hitting the reset button on the top of the nozzle
Jan 03, 2010 | Kenmore 23313 Whispertone Bagged Canister...
Power cord broken inside reel
the reel doesn't come apart, its a replaceable item. the only place that you can get another one is through sears.
Jul 19, 2009 | Kenmore 23313 Whispertone Bagged Canister...
I have a kenmore whispertone 5.1 and need to find out if it has a hepa filter. I don't think so..... Thank you!
Hi If its the same as the one shown here:
http://cgi.ebay.com/KENMORE-WHISPERTONE-12AMP-HEPA-VACUUM-WARRANTY-AVE_W0QQitemZ310151428708QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4836773a64&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1205%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
That model has a HEPA filter.
Otherwise the older models don't have them and rely purely on Allergy bags that you can buy for your vacuum.
Jun 27, 2009 | Kenmore Whispertone 23312 Bagged Canister...
Use a flat blade, it just prys off, a new on will press on.
May 24, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore whisper tome model # 116
If this uses a cogged belt, it should not fall off unless it is the wrong one. Give me the whole model #, then I can look and see what you have. The number of the power head is needed.
May 23, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Vacums
check belt not broken - could have happened when you caught tassle in head
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
196 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
