Question about Bugaboo Cameleon Stroller
My Bugaboo Cameleon pram has been stored for over a year. Tried to reassemble it & found that the white buttons that pushes in to adjust the seat angle is not "clicking/popping" back out, so it's not catching & the seat cannot be fixed. It's swinging up/down. How do I get these buttons/knobs on the seat frame to work again? Thanks.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 274 Answers
Take it into www.buggypitstop.co.uk they will do a great job restoring your pushchair, and they are the only company that repairs bugaboo chassis
Posted on May 21, 2010
Hello Am having great difficulty reassembling our bugaboo after fixing white buttons. Am aligning lower leg with the ramp inside button. When I screw it all up again the lower leg and the outside of the...
With the seat unit face down push down inside the lower leg unit with a screw driver, The white button should pop out. If it does not either the button is stuck or the locking splines on the outer sides of the button unit are not sliding freely into the spines of the outer ring. When you push down with the screwdriver your force only pushes the back of the button unit. It is the inner spring that has to move the white button and the locking splines so any burrs or roughness can stop its movement. www1.fixya.com/support/r7805137-fix_bugaboo_white_seat_buttons
Oct 19, 2011 | Bugaboo Cameleon Jogger
Tip
HOW TO FIX BUGABOO WHITE SEAT BUTTONS
To fix it yourself, you need to disassemble the buttons, which can be done with two screwdrivers one a thin slot type the other a Phillips. Here is the process: 1. On the other side of the white button unit is a screw. Remove it using a Phillips screwdriver.
2. You'll now have a black housing with a white button held in by three white tabs. 3. Free the white button from the housing by pressing inwards on each of the three tabs with the slot type screwdriver.
4. You'll now have a black base, a spring and a white button. Pay attention to how the two black parts align to each other so you re-assemble it correctly.
macnutz_28.jpg.
5. Pop the white button out of the upper black surround. Sand the circumference of the white button evenly until it slips easily in and out of the black surround. A little silicon spray is a good idea.macnutz_27.jpg
6. Reassemble unit and check it has full movement (see photo below). macnutz_30.jpg
7.
On the underside of the button unit a ramp shape should lineup with an opening in the bottom edge.macnutz_33.jpg
8. Fit button unit back into upper seat leg, Fit lower seat leg aligning it to the back of the button unit so the push rod in the lower seat leg pushes on to the ramp on the button unit. Note the seat button will not come out and lock until the seat is fitted back on to the chassis pushing the rod up to push the button out to the lock position. Once you have fitted the back screw in you can use a large screw driver to push down the inside of the lower leg to check the white button pops out and locks. If you have any resistance dismantle again to check alignment and the condition of the interlocking teeth of the button and the outer rings. Sand of any burrs and use a little silicon grease. Reassemble and test again.
Repeat operation to the other side if necessary. Buttons are not interchangeable so doing one side at a time avoids mixing them up.
If the tabs on the white button are broken you can buy a new button unit as a part www.babycare.nl/bugaboo-cameleon-seat-frame-push-buttons-p-2664.html
on Jan 14, 2011 | Bugaboo Cameleon Jogger
I have a bugaboo frog stroller that the seat recline buttons are not working. They will push in, but do not pop back out. Any thoughts?
To fix it yourself, you need to disassemble the buttons, which can be done with two screwdrivers one a thin slot type the other a phillips. Here's the process: 1. Behind the white button is a screw. Remove it using a phillips screwdriver. 2. You'll now have a black housing with a white button held in by three white tabs. 3. Free the white button from the housing by pressing inwards on each of the three tabs with the slot type screwdriver. 4. You'll now have a black base, a spring and a white button. 5. Sand the circumference of the white button evenly until it slips easily in and out of the black surround. A little silicon spray is a good idea. 6.Reassemble and repeat for the other side. If the buttons are broken you can buy them as parts www.babycare.nl/bugaboo-cameleon-seat-frame-push-buttons-p-2664.html
May 16, 2011 | Bugaboo Baby Gear
My bugaboo cameleon chassis 2007 model won't open,
Go to www.buggypitstop.co.uk they are the only company that repairs bugaboo chassis
May 19, 2010 | Bugaboo Cameleon Jogger
I have a bugaboo chamelon pram , the two round white knobs at the side for reclining seem to be stuck and wont click back into place !! making the carrycot?pushchair unstable
If the Cameleon is under two years old then it is covered by the warranty. The best thing to do is to contact the retailer you purchased the pushchair from or contact Bugaboo direct (www.bugaboo.com). They should arrange for a set of replacement buttons for the seat frame and instructions to be sent to you. If it is out of warranty, you'll just need to purchase these spare parts from them.
Sep 15, 2009 | Bugaboo Cameleon Jogger
Hi, my bugaboo is now 16 months old and recently the round white buttons on the side that lock the seat into three different positions got stuck instide, so the seat is not locked in any position, which...
call bugaboo customer service (1-800-460-2922), give them your stroller's serial number, and they will mail you the replacement kit (the new round buttons) and instructions for free and very quickly - I had the same problem and was very satisfied with how it was resolved.
Apr 05, 2009 | Bugaboo Cameleon Jogger
Bugaboo frog and cameleon handlebar
take the pram to your nearest baby shop as they will be able to do it for you .
Sep 15, 2008 | Bugaboo Frog Stroller
Bugaboo Cameleon Stroller Logo
362 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
