Question about Car Audio & Video
Wiring color code
I need to find out what each different color wire is so i can install it.
  • 396 Answers
There is no "ALL" answer as car makers all use different wiring harnesses. You need a simple "Wiring Kit" available at Walmart, Kmart and all car audio stores. It contains the adapter that details for you the speaker, output and voltage wires to use. Search Google for Car Stereo Wiring and the reading should help with your install.
Posted on May 09, 2010
How to wire up a 1996honda accord alternatar
i am assuming that you have already got the old alternator tested and found it defective that's why you are installing a new or refurb one yourself. if it is a refurb, you shouldn't have any actual problems re-wiring it. simply follow the color coded wires. now it is different if you are installing aftermarket. best way to go about this is by using a digital tester and probing the wiring itself. normally, the difference lies only on the color of the wires,
Jun 03, 2014 | Cars & Trucks
Radio won't play
There may be differences between the color coding of the adapter wires and the color coding of the vehicle. Check to determine whether the wires were functionally matched, not just matched by color. Check for missing or poor connections
May 07, 2013 | Dual Electronics XD1222 Car USB Player
My car stereo was stole they cut the factory wiring harness from the durango i need to know the color codes of the wires please
That's hard to answer cause it depends on how far back on the wire harness they cut. Plus if you have a Bose system or not. I would highly suggest to take it into a stereo install shop to at least check it out but maybe install the new stereo.
There is a wiring color code that all vehicles use but if the wires have been cut to far back they will be different colors. If you have a factory amp then you will have to rewire for the speakers to bypass it.
I added below the color code. Make sure you disconnect your battery before you start wiring anything.
Please note: You can do major damage to your truck computer and other components if you wire it wrong.
Proceed at your own risk
moz-screenshot.pnghttp://i.ehow.com/images/a05/32/br/hardwire-car-stereo-800X800.jpg
Feb 26, 2011 | Dodge Car Audio & Video
Radio wires differ from the speaker to the radio
This is the most common problem with self installs.The best thing to do is to get the car radio installation plug,it will plug into the factory plug for your factory radio and will give you a color coded pigtail to wire into that usually matches up perfectly with new aftermarket car radios.If the wires are already cut then you best bet is to extend the wires so that they are easy to work with hookup the power,ground,antenna and try dirrerent combos to isolate each speaker and label the wires accordingly.
Jan 01, 2010 | 1998 Ford Windstar
Installing a trailer brake controller and need to tap the brake light wire. This is the wire that shows 12 only when the pedal is pressed. What color is the wire on an '05 Jeep Grand Cherokee Ltd? I could...
Don't bother with a schematic...they all differ. Use a simple test light and just probe the rear light harness with everything turned off except for the brake lights, only one wire should show power. You can also check the color of the wire coming directly out of the bulb socket. I own a jeep, can read and draw wiring diagrams and have yet to find a diagram that has the same color coding as my vehicle.
Sep 28, 2009 | 2005 Jeep Grand Cherokee
MY DRYER IS NOT HEATING UP. 220 VOLT CONNECTION ON BACK OF DRYER- NEED WIRING DIAGRAM OR WHERE DOES BLACK WIRE GET ATTATCHED IN BACK OF DRYER. THERE IS A BLACK WIRE HANGING THAT IS CONNECTED TO A BLACK BOX...
The following link explains how to correctly install a power cord to the terminal block of a dryer:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Take note of the difference between a 4-wire and 3-wire configuration. The color codes for both installations are as follows:
RED - HOT (120 VAC)
BLACK - HOT (120 VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - Ground
The main difference between the two configurations is how the Neutral wire and Ground wire is installed.
In a 3-wire configuration ground and neutral are connected together at the terminal block.
In a 4-wire configuration ground and neutral are INDEPENDENT of each other. Neutral is terminated at the terminal block, while ground is terminated on a ground lug on the equipment cabinet.
If you have any questions, please let me know. I hope you find this information helpful.
Aug 21, 2009 | Dryers
Speaker wiring color codes for a 1991 Subaru Legacy Wagon...
the wires with black stripes are the minus the ones with red stripes are plus
Aug 19, 2009 | 1996 Subaru Legacy
I need wiring diagram for a 1999 Ford f250 side view power mirror. I am installing 2003 telescoping side view mirrors and the color code in different.
make your self a jumper set of wires to test with. Find out what makes what move on the old unit,write down the color wire,then apply power and ground to the new unit onw wire at a time.Mark down the color and what function it did.after testing both units then match your research and put the wires together.I wished I were there.Good Luck!
Jul 23, 2009 | Ford F-250 Cars & Trucks
Color code for a dual xdma7715
You need to buy a ford wiring harness. They are about $22 at Best Buy. If you want to hardwire the unit to your car then you need to get the wiring colors from Ford. It is 100x times easier to just buy the wire harness.
Mar 24, 2009 | Dual Car Audio & Video
Car Audio & Video Logo
129 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
