Put a new projection bulb in.. whats the green
Put a new projection bulb in.. whats the green line across the bottom, did i install it wrong or is it the bulb? Its a Sony Wega KDF55-E2000 55 inch
    President:
  • 3,130 Answers
It is very possible you did take out the bulb housing and make sure you installed the new bulb correctly inside the housing and double check the way you slide in the bulb housing slowly making sure you do not force it in then make sure you reinstall bulb cover properly also!
techman
Posted on May 09, 2010
Have green lines running across my rca tv
Would this be a rear projection TV? If it is, you may be due for a good cleaning, and a new projection bulb.
Sep 20, 2013 | D-01-10 AdaptivMount Horizontal Control...
Red stripe across the top after lamp replacement
I have the EXACT same problem with the same model TV. I just searched online to find a solution and found this post. If anyone knows the answer, please let us know. Thanks!
Jan 21, 2010 | Sony Grand WEGA KDF55E2000 55" Projection...
Blue lines on screen...
Try Encompass Parts 1-800-638-3328
Dec 14, 2009 | Televison & Video
Screen turn green tv is 57 rear projection
Good Day,
It appears that you may have a green drive issue. Try adjusting the Sreen Control it is located in the front of TV.
1) Remove Speaker Grill (it just pulls off) start at one end, 2) Remove cover (5-6 screws), 3) Adjust control. The control is located on lower right side towards bottom. A small black device with 2 rolls of controls, adjust the center control on bottom row counter clock wise, until you get a black and white picture.(adjust with color control to min).
If this does not work you light bulb (CRT) is bad about a $750.00 repair.
Good Luck, Big Irish.
Dec 07, 2009 | Toshiba 57H83 57" Rear Projection HDTV
Green diagonal lines across picture on Mitsubishi WD-52725 TV
If the lamp light turns red and the set wont power up put the V26 Power repair kit in and that should take care of it. The kit contains the capacitors and detailed instructions on CD
Jul 22, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Color lines in tv screen
it's an lcd filter fault it's betwine lamp and screen before mirror, seems like u will need to replace it but it hard to say without look at it.
Mar 22, 2009 | Philips 55PW9363 55" Rear Projection...
Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Dec 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green lines
This is the convergence amps going bad. You would need some tech experience. But could do it if talked throu.
Sep 11, 2007 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
