Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Dacor ERD30 oven trouble
I disconnected the wiring to both switches. In their normal state there is continuity across the switch When you push in the red botton the circuit is broken. One of these has 120v when the bake button is pushed, the other has no voltage at anytime??
    Genius:
  • 1,665 Answers
See Page 8
http://www.dacor.com/Dacor.Website/WorkArea/showcontent.aspx?id=1297
1. ERD models must be connected to a grounded,
metallic, permanent wiring system. Alternatively,
a grounding conductor should be connected to
the grounding terminal or lead on the appliance.
2. ERG models must be connected to a grounded
receptacle. Failure to do so may result in an
electrical shock hazard.
3. Do not use an extension cord with this appliance.
Such use may result in fire, electrical shock, or
other personal injury.
4. Do not install a fuse in the neutral or ground
circuit. A fuse in the neutral or ground circuit may
result in an electrical shock hazard.
Posted on Apr 05, 2008
Howcan i switch a dacor erd30 from natural gas to propane?
it requires different jets and the air mixer adjusted
it is a job for a gas fitter and not a DYI
Mar 31, 2015 | Dacor Kitchen Ranges
I received a F1 code and beeping after a pot of water spilled on range. Also the oven lock engaged and continues to move back and forth not allowing the door to close flush. It sat over night and the...
F1 touch pad / ERC test This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound)
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Dec 17, 2010 | Dacor Epicure ERD30 Dual Fuel (Electric...
What does f8 on dacor self cleaning oven mean
HI. This will generally be an issue with either the wiring at the door switch mechanism, or the door switch itself. Check the door lock switches and wiring. If the wiring is connected well, this will lead to a failed door lock switch mechanism. Use my procedure below to confirm switch failure.
Before repairs or further testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. Once access is gained, set the latch to the "clean" position and test for circuit continuity at the terminals of the switch with your VOM's ohmmeter function. If there is no continuity, the switch is faulty. Use cuation when testing.
Jan 05, 2010 | Dacor Ovens
Dacor oven will no heat.
dacorservice.com very likely has your answers. Good Luck and Happy New Year!
Dec 27, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
HI,
Check if both circuit breakers for the oven are on.
The control board needs only 120V but it should be 240V for the heating elements to function properly.
Check if there is 120V coming to the thermal fuse.
when you get your meter . put the oven on bake and check your power on the bake element if you do not have 240 volts then your control board is bad. if you have 240 volts then you element is bad.
Goodluck,
Please don't forget to rate the solution.
Mar 25, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Oven enamel chipping
Never heard of such a problem, you are the first to post it. There is no fix for this.
Apr 03, 2017 | Dacor Epicure ERD30 Dual Fuel (Electric...
ERD30 will not reach or maintane setpoint
read your owners manuel and follow the instructions for adjusting the oven temp set it 15 degrees higher
Dec 31, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
F1 error code, continual beeping all other oven functions work properly
Here are the error codes for Dacor:
DACOR
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 Clock pushbutton is stuck in a depressed position Check clock buttons F1 Element relay circuit failure Control board may be bad F2 Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only) Call for service F3 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F4 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F6 Failure in the EEPROM check comparison (only time of day and timer will operate) Call for service, electronic clock control is usually the cause of the problem F7 Failure of the self- clean automatic door latch system Check door latch and switch(es) F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking in self-clean mode Check door lock motor and door latch
Nov 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
173 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
