Question about Sony Playstation 3 (PS3) Console
When i try to play a game it freezes out of no where and it is hot from overheating i can still turn it on but its still freezing
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
I would set it up in a place were you can put a fan then face the fan to the back of it so i dosnt overheat and freeze.
Posted on May 09, 2010
When playing Red Dead Redemption the game freezes
If a game freezes, then the problem is usually due to the PS3 overheating. The PS3 needs good airflow through the vents so make sure that you don't put it in a corner or in a place where the hot air won't linger around for long like near a window. Also, don't play for too long; give your PS3 a break every once in a while (1 minute breaks don't count) :)
May 30, 2011 | Sony Playstation 3 (PS3) Console
My ps3 keeps freezing during games
Problem: Your Playstation 3 console is freezing during gameplay. There are usually two problems that would cause your Playstation 3 to freeze during
gameplay. I will start with the most common problem:
1. The Blu Ray Laser is wearing out. This is a common issue among the newer video game consoles. The laser is constantly lighting up to read the discs while you are playing your Playstation 3 whether you are playing games, Blu Ray movies, or DVD movies. Eventually the laser will burn out. As it starts to wear out, first the games or movies will freeze. After a while, it will not read Blu Ray at all. Finally it will quit reading anything. You can find lasers at the following website starting at $49.95. The same website also performs repairs of the Playstation 3 console:
http://store.richspsxparts.com/pl3paac.html
2. Overheating. This is less common. If your PS3 freezes and you shut it off and back on and it comes on ok, it's probably not overheating. If heat is the problem, it will freeze right away if you turn it back on right away without giving it time to cool off. If it turns on OK with no problem and doesn't immediately freeze up, the laser is your issue. If you turn it back on and it freezes right away, your PS3 may be overheating.
If your PS3 is overheating, the best thing to do is to make sure you do not keep it in an enclosed area. Playstation 3 systems and XBox 360 systems run very hot. You must keep it in the open so it gets as much cool air as possible! You can also upgrade the fan inside of your Playstation 3 with the Whisper Fan which increases cooling. You can also find it at the following website:
http://store.richspsxparts.com/newpl3ps3taw.html
Apr 19, 2011 | Sony Playstation 3 (PS3) Console
Game freezes after playing for a while but no red rings appear
Games freeze for two reasons. Overheating and the hard drive locking up. If you have your games installed, you most likely eliminated the overheating problem.
Since you are not getting Red Ring, it probably isn't overheating. That leaves the hard drive. Turn of the console and unplug it. Remove the hard drive. Now is a good time to clean any dust from the connectors or vents. Reattach and play. Some games like Fable 2, Fallout 3, and others are more prone to freezing when accessing the hard drive that others. If it is freezing more times than not, you have an issue with the hard drive.
Jun 09, 2009 | Microsoft Xbox 360 Console
Ps3 keeps freezing on games only
Try using a can of air to blow out the fan area. Even though its well ventilated it may be full of dust. It sounds like an overheating issue. Also look into aftermarket fan/cooling solutions, that dont plug directly into the PS3 and have there own outlet power plug.
May 17, 2009 | Sony Playstation 3 (PS3) Console
Games freeze. red light flashes when i turn on
see if youre disk is cracked in the circle and make sure all the cords are plugged
May 02, 2009 | Microsoft Xbox 360 Arcade
N64 freezes while playing
The Nintendo 64 is notorious for overheating problems.  This is a very common problem.  With my N64, I play it while a fan is blowing on it.  This usually prevents the problem.  Try this method.  It should work.
Hope this helps!!
Please give feedback.
Apr 14, 2009 | Nintendo 64 Console
My playstation3 keeps freezing and wont let me play some of my g
It is freezing because your playstation is to close to the tv and its getting to hot...it is due to overheating you are having this problem ... so try moving it to another spot....you must take care to keep it properly vented.......
The system is prone to overheating, particularly if you happened to have bought older stock.
One way to deal with this is to stand it vertical, and put a small desk fan behind it.Turn on the fan when you turn on the game. I know it's an annoyance but it is a very simple and effective way to work around the problem.
DO NOT use an intercooler fan or any cooling device that gets power from the playstation. It just makes it worse.
when thermal compound fails it gets overheated so you need to look into this too ...replacing the thermal compound on the heat syncs and it should only cost about $5.00 to fix your playstation.
Feb 08, 2009 | Sony Playstation 3 (PS3) Console
Problem can you help and dont say contact Microsoft!!!!
overheating can cause problems like that, and 360s are prone to overheating
Oct 12, 2008 | Microsoft Xbox 360 Console
PS3 freezing and overheating
read my blog as my problem is similar but mine does not freeze it just turns off
Aug 30, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
65 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
