Question about White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit
We changed the batteries and now it appears we cannot get the panel to work in terms of turning on the heat. We would like to troubleshoot.
  • 99 Answers
After you changed the batteries of your thermostat you need to reset the unit to operate properly. You may call homeowner techline at 18002842925 they will assist you if the above procedure did not work.
Posted on May 09, 2010
Can turn on the tv from front panel swith. component inputs work. composite inputs and remote control do not work
Point the remote at your cell phone camera and press a button on the remote. You should see a purple pink light appear in the image of the camera. If you don't, the remote is bad.
Feb 05, 2016 | Televison & Video
2006 buick lacrosse heater core change
THIS IS A JOB FOR AN EXPERIENCED MECH. TAKE IT TO A MECHANIC WHO DOES SIDE WORK.
Oct 24, 2014 | 2006 Buick LaCrosse
Please is it normal for my phone to get hot when i play game, watch video or when connected to the internet?
Yes it is very normal but it also depends.This is so because at that point in time the phone processor is at constant work just so you can have a great game play or whatever you are using your phone for.
Some processors do quite will in not heating quickly compared to others.....cannot go much into that for now cause there are so many of them.
Another thing to note is that the battery is also at work discharging at its maximum rate just to meet up for the power consumption rate, this can also cause heating in phones.
Processor frequency scaling can be applied to mostly rooted android phones with customized roms. The lower the processing rate the less likely to have a heating phone but this comes at a price in terms of having a really smooth running phone...I tend to do this mostly and hardly have heating issues on android platform.
Note also that phone heating can be termed normal only if the rate at which it heats is not too quick or much. A phone that heats even when you receive calls for a continues 5-10 minutes is something that i do not term normal at all.
Such a phone will need to be sent back for replacement cause it can have a lot of effects on the phone.
Phones normally get hot the most when you have Wifi turned on and browsing with it whiles other apps are in working in the background so be sure to close programmes that you are done using.
Jun 06, 2012 | Lands Phones
How can I turn off heated dry on my kenmore ultra wash quietguard
We had the same problem and called a local service center for some advice since the dishwasher was no longer under warranty, Sears 1-800 number would not troubleshoot with us. The local technician suggested we open the panel behind the keypad (with the power disconnected) and unplug the main "ribbon" for 10 seconds. After plugging the ribbon back in and restoring power the keypad had reset itself and the lock button was no longer an issue :) I hope this helps someone else that may be in the same boat someday. (I apologize if the term ribbon is vague here but when you look at all of the wires running around the back of the panel it's easy to see, ours was various shades of grey and appox 2" wide)
May 03, 2012 | Kenmore Dishwashers
My televsion turns off after 10 minutes by itself and it takes a few minutes to turn back on. Its a westinghouse 2005 model LTV-32w1
Sounds like either the Power supply unit or heat related problem. if you keen to take it apart you could check the power supply to see if there is anything obvious in terms of signs of over heating.
May 11, 2011 | Televison & Video
Not working
HI, Troubleshooting an Aprilaire Humidifier
Aprilaire, a manufacturer of indoor air quality products including thermostats, air cleaners and dehumidifiers, also offers a line of whole house humidifiers. Installed in your existing heating and cooling system, humidity is produced by a supplied water source that flows over a water panel before being distributed throughout your air through the heating and cooling system. Issues you may need to troubleshoot with your Aprilaire humidifier include error messages and the unit producing too little or too much humidity.
Things You'll Need:
Replacement water panel
Turn down the control dial by one setting if condensation appears on your windows or walls.
Turn up the control dial by one setting if there is a lack of humidity, often indicated by dry skin or peeling wallpaper or paint.
Turn the control dial to "Test/Reset" if the humidifier does not run. Verify the heating and air conditioning unit blower is operating. If the heating and air conditioning unit is not operating or you are unable to resolve the issue contact a heating contractor.
Contact a heating contractor if you turn the control dial to "Off" and the humidifier continues to run.
Contact your Aprilaire dealer (see Resources) if you notice an error code on the display and the "Call Dealer for Service" light flashes.
Turn the control dial to "Off" and turn off the water supply if the yellow "Change Water Panel" light flashes. Lift the front panel off of the humidifier. Slide out the water panel. Insert a new water panel. Replace the front cover. Turn the control dial to "Test/Reset" until the "Humidifier On" light flashes. If you feel uncomfortable changing the water panel, contact a heating contractor.
Tips & Warnings
Purchase replacement water panels through your Aprilaire dealer or a heating contractor.
You can get parts from the link below:
arnoldservice.com/humidifier_parts.htm
Hope it helps.
Thanks for using fixya....
Nov 17, 2010 | Aprilaire 700 Humidifier
Hi, we have a Honeywell ducted heating thermostat model t8602c2069. It has recently stopped working. This display panel is working so it's not the batteries, however when we turn it on heat does not come...
We have exactly the same problem as dmlauder! (posted 6th September)
What does the square symbol mean?? We have to keep resetting the outdoor heating unit...it works for a few minutes then stops
cate
Sep 06, 2010 | Honeywell Heating & Cooling
ABS Light went on, followed by check brake light, engine started running a little rough. Pulled over brakes and fluid OK, Tried to start car turned over slow, and fired, Tach very erratic and at 1500...
A bad electrical connection can cause a number of lights to come on, have any lights returned since cleaning and reinstalling the terminal? if not then the loose connection probably caused all that you saw. Hope this helps, let me know.
Aug 04, 2010 | 2004 Ford Taurus
When i turn dishwasher on it goes to 1 and just stays there.one time a tech reset my old one by pressing three of the buttons but i cant remmember which ones. its a queit partner 1v
Normal-Heated Dry, Normal-Heated Dry, Normal-Heated Dry, Normal-Heated Dry.
OR (depending on the model)
Hi-Temp-Heat Dry, Hi Temp-Heat Dry, Hi Temp-Heat Dry.
Hope that work`s. Keep in mind there is a underlying problem to cause the "1" to appear in the display repeatedly, so this is only a short term cheat.
Good luck.
macmarkus :)
Dec 08, 2009 | Whirlpool Dishwashers
Casio Exilim EX-S880 will not turn on
The problem is the spring terminals inside the camera are not making good contact with the battery. I had to use a screw driver and gently push them to the left to make better contact with the battery terminals. There are three connections. I stress that you be gentle. This not the long term fix but you will be able to take pictures in the short term.
Feb 25, 2009 | Casio Exilim EX-S880 Digital Camera
White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit Logo
707 people viewed this question
Top White Rodgers Home Security Experts
Nicholas Bannister
Tom Chichester
Are you a White Rodgers Home Security Expert? Answer questions, earn points and help others
