Question about X2Gen MW22U Monitor
My monitor powers up then screen goes white - X2Gen MW22U Monitor
Dell monitor screen suddenly went white. Can it be fixed?
I have a strong suspicion that you have burned a capacitor or two on the monitor. You will need to bring this in to have it serviced as it will require the monitor to be opened up and new capacitors replaced/resoldered.
Mar 18, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
Hi, I have a Dell 23 in monitor. Everything was working fine but one day we turned it on and it's completely white. The whole screen is just white. Is it there a simple solution?
please remove the vga cable from the back of the monitor, make sure that you don't remove the power cable from the back of your monitor.
If you see the power on self test or any other pattern of colors in the screen, if the screen display remains white or goes black it would mean that the monitor has gone bad.
Hope it helps.
Thanks and Regards
Anand Sachan
Oct 25, 2010 | Computers & Internet
Samgung pc monitor has a plain white screen when turned on. Also goes off after a short while and the blue power button blinks.
plain white screen means loose conecting the lvds cable to panel. reconect it.
if its goes off then check power board +5v or +14v filter capicitor.
Feb 17, 2010 | Samsung Syncmaster 940BW LCD Monitor
When I power off my LCD monitor, the screen goes all white, but once I turn the monitor back on it goes right back to displaying whatever it should on the screen. Or when I shutdown the computer it also...
If this has happened to two monitors on the same computer, then i dont think the problem is with monitors, i think the problem is with the graphics on the computer, i suggest uninstalling the driver for the graphics card in device manager and then restart the pc to see if that makes any difference. The divice manager in in the properties of my computer icon, just right click and choose properties, then device manager.
Feb 06, 2010 | Sylvania L181 18.1" Flat Panel LCD Monitor
Monitor goes white.
if the monitor turn white but the power light is stay on with green, then probably the back light tube was defective, and it will happen randomly in beginning and getting worse after while.
Jan 14, 2010 | BenQ FP71E 17" LCD Monitor
White Screen
sounds like a faulty monitor,time for a new one,is it under warantee???
Aug 16, 2009 | Dell SE198WFP LCD Monitor
White screen
You could have a faulty or loose video cable/connector.
Reseat the video cable/connector that attaches to the motherboard.
Jul 16, 2009 | Sony VAIO VGN-CR220E/P Notebook
Screen turns white only
http://www.daniweb.com/forums/thread17104.html
check out his forum thread. I think there is good information posted. I hope it helps.
Sep 20, 2008 | Acer AL511 15" Flat Panel LCD Monitor
White screen covers desktop
Ah A simple one. simply unplug the power adaptor and take itno a repair place or radio shack and ask them to measure the output to see if theres 12 volts DC on the plug?? Good Luck
Jun 14, 2006 | Princeton Digital LCD17 17" Flat Panel LCD...
X2Gen MW22U Monitor Logo
638 people viewed this question
Top X2Gen Computers & Internet Experts
Sandy Moore
Sandy Moore
William Alequin
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
