Question about Motorola Mobility RAZR2 V8 Cellular Phone
Charging problem my razr is not getting charged when i insert the charger .i have to always fix the charger in some way after then it starts charging.is it any software problem
  • 438 Answers
It will not be a software problem...charger pin may be having loose connections inside the phone!
Posted on May 09, 2010
Set is not getting charged
Hi, when a phone does not charge, possible cause forphone not charging is,
: The charger,
and the charging port.
The charger might cause phone not to charge if it is damaged.You can test the charger with another phone if it will charge to confirm if the charger is working.
The charging port can also make phone not to charge, it's located at the low end of the phone where the charger is inserted in the phone.
You can check both to confirm which is faulty.
I think that will help.
Take care.
Oct 02, 2010 | Motorola Mobility RAZR V3x Cellular Phone
My phone won't charge
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if the charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Sep 14, 2010 | Motorola Mobility RAZR V3
Charging no respance
Hi, problem can be solved. When charging a phone and it does not respond,it means that either the charger or the charging port where you fix your charger in is faulty.
First you can try and use another charger to check if phone will charge. If it charges, that means the charger needs to be replaced,but if not charging,charging port will need to be replaced .
Take care.
Jun 09, 2010 | Motorola Mobility RAZR V3i Cellular Phone
My razr does not charge
when your phone doesn't charge,three things might be the problem,namely;the charger,the charging port of the phone or the battery.to be sure its not your charger,try using the charger to charge another phone of its kind,if it charges another phone then you can be sure the charger is not the problem,but if it doesn't,it means the charger needs replacement.
you can insert the battery in another phone and charge to know if the battery is the problem,if it charges then you can conclude the fault is not from your battery and the charger but rather the charging port of your phone is bad,you'll need to take it to a qualified technician to help you fix it
Feb 28, 2010 | Motorola Mobility RAZR V3
Razr will not charge with wall charger
Your charger is faulty. If your phone is able to charge off of other sources (computer, car charger, another wall charger) Then, the charger needs to be replaced. Some mobile companies have a 90 warranty on accessories like the charger and battery. Then the mobile manufacture (Motorola) has a 1 year warranty on the charge and battery. I would check on that, and get those replaced.
Feb 04, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Motorola V3 RAZR won't charge!!!
i think due to over charging your cell s capacitor is gone so it not getting charged...
this repairable by replacing capacitor...
so just visit technician................
Feb 11, 2008 | Motorola Mobility RAZR V3
hmm well i suppose u try with a new charger 1,, b4 you throw it away
Feb 05, 2008 | Motorola Mobility RAZR V3
Mobile Phone - Flip
"unable to charge", "insert sim". is your phone been dropped or got wet? if unable to charge, when using a wall charger, try different outlets. if using onl one charger, tr different chargers. if it won't work, try other compatible batteries if you would get a charging message. if does not work, have your phone checked with a service center
Sep 01, 2007 | Motorola Mobility RAZR V3c Cellular Phone
SIM not recognized
I had the same problem with charging, I found that my car charger and via USB charged the phone but not my home charger. Give that a try, if it works with either one of them you will have to send it to Motoservice center and they will fix the internal connection problem. (save your money on buying new batteries and chargers) Make sure that the phone is not locked to a network, or make sure that the SIM has not expired and has plenty of credit.
Jun 13, 2007 | Motorola Mobility RAZR V3
URGENT: INSERT SIM - UNABLE TO CHARGE
dear for not charging first check ur charger if ok then check and clean charging jeck. even not ok chen the status of solder of jeck if it is unsolder then sold it. even if not ok then check the charging fuse 0 ohams if meter shows continuty then ok other wise replace fuse. for inser sim card check connection from sill card ic(like combice resistor)
Mar 25, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR2 V8 Cellular Phone Logo
99 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
