Question about Dayton Audio Dayton Speedaire Air Compressor Filter Mini 4z344 35
I have a speedaire 3z182 compressor. It has had very little use the past few years, when I put it back into service it appeared to function well. Now sudddenly it has no air pressure. When I hold my hand over the intakes one feels to be sucking air the other pulsates. (Valve problem?)
  • Anonymous Mar 16, 2014
    wont hold air pressure.nead manual
    Brigadier General:
  • 4,090 Answers
Try spraying some WD40 into the air intake to release the stick valve?
Please rate my help++++Thanks for using FIXYA
Posted on May 09, 2010
When compressor is running and gets 110 psi it slows down and stops. try to resart and will not turn but a couple times
Posted on Jun 25, 2010
Need a belt for my model#3z355h
If you have a Speedaire 3Z355H, that uses the same belt as the 3Z355J. This site lists the 3Z355J parts: http://www.mastertoolrepair.com/air-compressor-parts-3z355j-p-53576.html . The belt is part 33 on the diagram. The belt part number is BT005400AV and is ~$25 from this vendor. An after-market version is available at Amazon.com https://www.amazon.com/Compressor-REPLACEMENT-Market-SPEEDAIRE-3Z355H/dp/B01AYST7XI .
I hope this helps.
Aug 06, 2016 | Air Tools & Compressors
How can I adjust the torque settings?
PDF]SD Compressor Service Guide - Sanden
www.sanden.com/productlibrary/manuals/sd_service_guide_rev_2.pdf
6.6.2 Suction Gas Condition. 6.6.3 Ambient ... Internal compressor pressure can be relieved by removing shipping caps ... Never leave PAG oil exposed to air for a prolonged time. Tightly ..... Place rotor pulley shaft protector (Puller set) over the exposed shaft. 4. ... Replace retaining nut and torque to specification. 1/2-20: 20- ...
Speedaire Air Compressors - About Air Compressors
www.about-air-compressors.com/speedaire.html
when i try to start my gas compressor it backfires why 5.5 speedaire by dayton, serial ... cant find cylinder head torque specs for 35w347 need the torque specs to properly break .... I also need to know how to change the oil on the 1z943b motor ...
[PDF]80 Gallon Industrial Air Compressor - Mi-T-M Corporation
Dec 08, 2015 | Air Tools & Compressors
I need Pressure Regulator for Speedaire 3Z355H
The pressure regulator does not have to be specific for your compressor. You just need to get the right line size and pressure range you are needing. You might be able to get one from Home Despot or Lowest, but I would look on Amazon. I am sure you can get it from Grainger, but you will pay a premium price. If you are on a budget, check Harbor Freight if you can.
Aug 27, 2012 | Dayton Audio Dayton Speedaire Air...
I need i shop manual for a dayton speedaire model 3z244d
The dayton brand is sold by Grainger.
Check for the manual at grainger.com they also have a cust. service number that maybe can help you...
heatman101
Sep 28, 2010 | Dayton Audio Dayton Speedaire Air...
Parts lists (i.e. rods, crankshaft, rings) for
Information about your unit can be faxed to you by calling the number below:
From the USA, please contact us at 1-800-323-0620
It may be easier however to look for the model number of the pump only as the 3z497 reference number is of the the complete unit. Look for model number or information on the pump itself and check that number at www.grainger.com. I believe that you have a two stage pump that may still be sold seperately. Good luck on your repair.
Jul 22, 2010 | Dayton Audio Dayton Speedaire Air...
Hi - While being moved, Speedaire compressor (model 32180) fell on its side. Side opposite pulley and dammaged unit directly opposite of pulley. I have no idea what the unit is called or its function. Was...
Lee,
I'll email you the breakdown. The pump is probably actually a 3Z180, made for Speedaire by Champion. If you are looking for the assembly sticking out of the back of the pump, it is probably the centrifugal unloader, which vents the pressure after the compressor shuts down. You can get the parts from Grainger parts (888-361-8649), or your local Champion compressor distributor.
Nov 06, 2009 | Air Tools & Compressors
Can't find parts for a Speedaire Model 5Z705
not sure of a relay you are referring to but check Grainger for speedaire which they are sold there.
Apr 09, 2009 | Air Tools & Compressors
Hitachi TV: 35TX30B Window in upper left view that won't go away
you using a digital desk top box with it ?
an old school tv
solid state old analog
what you are seeing is called picture in picture
one of those split screen functions of years past
remote may have a function button on /off for that
user manual for one
Hitachi 35TX59K 35TX50B 35TX30B Manuals
Apr 06, 2017 | Hitachi Televison & Video
CLOGGED AIR DRYER
I use my shop vac. Feed the hose in to the line (disconnected from the rear of the dryer). Keep working it back and forth until the line comes clean. Also feed the vac line in from the outside dryer vent. I also use it to clean out the back of the dryer where the vent connects as well as the lint trap.
If its real heavey stuff you may need to clean the vac a few times or unplug the vac hose.
Nov 12, 2008 | Air Tools & Compressors
Dayton Audio Dayton Speedaire Air Compressor Filter Mini 4z344 35 Logo
503 people viewed this question
Top Dayton Audio Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Dayton Audio Air Tool and Compressor Expert? Answer questions, earn points and help others
