My computeris running but I have notany image in my monitorand the light is showing that the hard drive is working, what is the problem?
  • 2,418 Answers
This is a virus. I am not sure how to remove it just yet as a friend of mine has same problem, we have been working on it. Thats all I can say right now.
Posted on May 09, 2010
Clicking and not showing up
There are different software available. Try Spinrite if you can. If it works, it'll help fix your hard disk.
May 18, 2010 | Western Digital Passport WDXML800UE...
Hp pavilion dv5000 hard drive problems
It is rare that you get notice of impending harddrive failure so heed the warning now. If it were me, I would back up all files to an external drive, and better yet, use a program such as Norton Ghost or Acronis and make a drive image. That way you can blow the image back on a new drve and be up and running right away. The alternative is to back up docs, pics, etc and reload every program including operating system, which is very time consuming.
Apr 29, 2010 | HP Pavilion dv5000t Notebook
Free Agent 1.5TB external inaccessable
well to start sometimes when a computer crashes or
freezes the HDD image that is stored on the unit will
be wiped clean since it uses the RAM to store that image , so it may need to have its software reinstalled
also check to see if the HDD is at its limit of storage
run a check using Belarc Advisory which you can download from Google make sure to say yes for the Belarc updates , you will be amazed on how much info the Belarc utility will uncover , and remember to list your OS your OS bit amount for future help .
Jan 14, 2010 | Computers & Internet
My 1T just started acting up. It is not reading the files. The files are showing up. But once in a while, briefly, it will show up. What's going on?
there are two relationships to your IT 1 your hard drive 2 your ram , the ram places an image on the hard drive
that the CPU reads , in order for the hard drive to except this image , it needs to retrieve the image from from the
ram so check the RAM , to do so you'll need some RAM that you know is good then try in in as many slots that you have ( all of them ) , you should find the problem
Jan 11, 2010 | Computers & Internet
It has been working for a year, but now my drive is showing up as a CD partition, instead of a hard drive. Any thoughts?
make sure there is no image on it that would represant a cd image . like a iso file. try using a differnt port, hmm hope this helps a bit.
Dec 03, 2009 | Acomdata HybridDrive E5 Hard Drive
MY HARD DISK DOESNT WORK PROPERLY
This may be useful to you:
It is never a good sign when hard disks start to make notice. It means that your drive is starting to fail. Although there are variations, most drives are completely silent when they're running.
The tipoff is either a new noise are an intermittent noise. If the drive has always made a slight clicking noise when accessing data, that's probably nothing to worry about. If it just started clicking, or if it only clicks occasionally, this means something has changed. Change in a hard drive is a Bad Thing.
Grinding or squealing noise is definitely a bad sign and usually means the drive is on its last legs.
There are two ways to protect yourself against a failing drive; the first is to create a backup image of the disk and the other is to move all everything from the failing disk to a replacement drive. Also, make sure you have an up-to-date rescue disk so you can boot your computer even with a failed primary hard drive (the one with the operating system on it).
Creating an image won't stop the disk from failing, but it will give you a starting point from a known, good configuration if the disk fails. Cloning the disk to a new drive not only moves everything off the damaged drive, but it moves it in total so that you can start working on the new drive immediately.
If you suspect a drive is going flaky, it is relatively easy to cone your disk. Please see Drive to drive: Bring in the Clones for step-by-stepinstructions on duplicating your disk.
Using your image file, you can also deploy a new drive by restoring that image onto the new drive. Acronis True Image provides necessary tools to create and deploy a new drive.
The good news about discovering a potential hard drive failure today is that hard drives are inexpensive these days and installing a new one is easy. Many retailers and web sites sell high-capacity hard drives, up to 200 Gb, for $100 or less. If your drive shows signs of failing, replace it immediately, your data is far more important than the price of the disk drive.
Rate this!!
Aug 16, 2009 | Quantum Fireball 1.2 GB SCSI Hard Drive
My PC is not recognizing Aluratek AHDUB250 External hard drive
There is conflit on the drive path.
Try changing the drive path-1st {diverce manager} then {disk management}locate your drive change the drive path
Jul 21, 2009 | Aluratek AHDUB250 USB 2.0 Hard Drive
Multibooting
nope not if its in vista u would nee dto dual boot dl alll latest drivers software for vista then mosttime it works on older stuff
Oct 14, 2008 | Toshiba Satellite A135-S2276 Notebook
Drive Not Ready
typical of external drives overheating.
i sell external case with fan at my store.
Nov 03, 2007 | Fantom Titanium Hard Drive
Scanner cannot communicate with computer
Please check weather windows services "Windows Image Acquisiton(WIA)" is started,
You can check out by opening the windows services from control Panel > Administrative Tools > Services
or by typing the command "services.msc" in run or at command prompt
check weather "Windows Image Acquision(WIA)" is started and set to startup type "automatice"
Then Install your Scanner Drivers and Softwares
Then Have Fun
Enjoy!!
Still any queries contact Me
ranjith_sutari@yahoo.co.in
Oct 24, 2007 | Lexmark X5470 All-In-One InkJet Printer
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 Cloud storage services are great for sharing files with friends and families, keeping documents in sync between all your devices, and so much more. Free cloud storage is even better! Several backup services offer free online backup plans. DataAlign is known for having the finest free cloud data backup software in the world! Not just being simple and automatic it can be customized to a large extent and not to forget the scheduling capabilities that allows it to run at any time of the day. With several years of experience in its kitty, DataAlign is the trusted innovators in free online backup solution. DataAlign is proud to be known as a market leader in providing Server Cloud Backup Solution based storage and individuals is our primary motto. Our innovative platform has been designed while keeping you in mind. To provide Cloud Backup For Small Business optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Unlike other companies, there are no catch with DataAlign free cloud backup solution. With the kind of experience, you get with DataAlign, we strongly believe that you will eventually upgrade your account to a bigger one. And that makes us give awa Online Backup Pricing accounts as a free version with no strings attached. So drop your worries and and setup your free cloud data backup account with DataAlign. Just to clarify we will not ask for your credit card details upfront when you sign up for a free account. Keep using your free account as long as you need it. DataAlign has been designed with you in mind. You wouldn't require any technical skiil or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 28, 2018 | The Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
