Question about SanDisk Wirelss Lan SecureDigital Card SDWSDB-000-768 802.11b
Looking for the device FRE 0826J FR 100-1 - SanDisk Wirelss Lan SecureDigital Card SDWSDB-000-768 802.11b
My HD SAMSUNG HM500JI not work any more bad sector that cany be fix...!!!
Well.. I'm SAD to inform you..your drive has encountered a serious error.
There's a couple of options..none of which you will like.
Drives (SMART) report errors, but sadly don't fix anything. Once a bad-sector has been encountered, its usually an indication of major failure (google/39% of all drives w/bad sectors major failure..etc)
Your options.. Is your data super important--if so, STOP using the drive, send it to a DRC (Data recovery Center), expect to spend $600-1k for the data.
If you've backedup, good news-- drives are cheap.. buy another, plus your drive into tthe 2nd slot, copy off what you can..
the drive itself is having a major failure (meaning it cannot relocate the bad sectors any longer, hence the smart failure)-- meaning-- drives "TRY" to relocate (when they detect failures, they'll move the data else where, mark the bad area, and use a new spot)... Your drive has probably done that.. ALOT. And now... it's gone critical.
BEST solution for you, to save $$ and time.. but a drive ($80-150 bucks)... install your os... put the other drive on the other cable, copy off what you can..and call it a day.
A DRC won't do much more to be honest... if its SUPER critical, contact www.deepspar.com and see if they will recommend you to a DRC locally to you, or do it them selves...again $$$
Oct 16, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
SAMSUNG HM500JI
Bro, when you see "SMART overall-health self-assessment test result: FAILED!" then this hard drive is either dead or dying. There isn't much you can do other than replace it now.
Aire acondicionado no trabaja bien
Si no lo est? haciendo bastante fr?o r?pido, habla con el comerciante, no hab?a una soluci?n para esto hace a?os problema. Necesidad de comprobar el nivel de fre?n demasiado, puede ser que necesite algo. Si se trata de hacer ruidos, los rodamientos son malos, debe sustituir el compresor completo.
Apr 05, 2011 | 2005 Chevrolet Trailblazer Ext
Fre sim lgkp500 unlock code
You can get the Unlock code at here
http://www.theunlockspot.com/lg-kp500-/rs10wp9/ and free Sim from Network lock...
Jan 27, 2011 | Cell Phones
I cannot locate or download those components to my laptop ex.Modem device on high definition audio bus,and two base system device i already go to acer support and download but its not there also my...
I would contact Acer.com and look for what you require there. At least the drivers will work if you get it all from the manufacturer and fre of charge!
Hope this helps.
Dec 10, 2010 | Acer Aspire 4520-5950 Laptop
When i download yahoo it says no fre disk make 100 mb fre disk to download
Check what free space you have on your C: drive.
You need at least 3 to 4 GB of free space for windows to work properly.
Download and use CCleaner ( if you have windows XP, put a tick in the delete hottfix uninstallers), run the cleaner, the registry cleaner and then go to tools/ uninstall and delete as much as you can, all those programs you have not used in ages.
If you cant download due to lack of space, just goto control panel and find the uninstall programs, and delete stuff from there
Aug 30, 2010 | Intel Computers & Internet
Dsl wont stay connected
try asking for a new modem from your isp...
May 31, 2008 | D-Link DES-3550 (D85116) 48x10/100 Mbps...
I have a Canon FR-100 Floppy Disk Still Image Recorder, but have not connected it to my latest PC as I no longer use diskettes. But I still use my Canon ZR10 Digital Video Camcorder, and have recorded some...
Yes, you may require....Visit www.canon.com for support.
Sahaja Yoga is the Only Gateway to the Divine and is FREE OF CHARGE. THIS IS THE ONLY WAY TO SAVE THE WORLD : ww.sahajayoga.org
Mar 30, 2008 | Computers & Internet
SanDisk Wirelss Lan SecureDigital Card SDWSDB-000-768 802.11b Logo
909 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
