Question about Intel Dot Station (INTC300AIO) PC Desktop
Hello, I'm Bhupendra. I'm facing problem while starting the PC. It glows power LED & new mail LED but does not boot for a long time. after 30 min.it automatically boots. I checked the sleep mode settings. Pl.suggest remedy.
    Problem Solver:
  • 10 Answers
Its probly a virus in ur motherboard
format ur computer
Posted on May 09, 2010
Phone is not booting (no display only LED glow)
Why don't U hard reset the phone. It may delete everything on it. But it will bring it back to the state when U bought it new. Good luck.
Here is how.
http://www.youtube.com/watch?v=yTcfCJmWU_U&sns=em
Feb 27, 2014 | Sony Ericsson W380i Cellular Phone
My pc Shut Off Automatically after few min(5-6),when pc is in boot screen options or booting from O.S. CD"
I missed your question, anyways. as it seems there might be the reason of over heating. I would suggest just remove the heatsink apply proper heatsink paste on CPU and replace your heatsink and fan. heat must radiate properly.
Nov 28, 2011 | ASUS P5G41-M Motherboard S775 Intel G41...
Does not boot up, fans start, internet plugs light, clicks on and off.....seems this is a common problem for these machines, what is the fix?
Instructions
  1. When you press the Power button to start the boot process, the LED lights glow while the computer verifies that there is sufficient electrical power to activate the hardware.
    Effect & Solution: When you press the power button, the LED lights on the computer do not glow or the LEDs blink briefly and then stop. There is no sound of the fan or hard drive spinning, and the screen remains blank. The computer will not start if there is insufficient battery or AC adapter power.
  2. The BIOS queries various hardware components used for the startup boot process.
    Effect & Solution: When you press the power button, the LEDs glow but there is no fan or hard drive sound. The LEDs may glow briefly and then go out.
    Or
    The LED lights blink, stop, and then blink a second or third time, but there is no sound from the computer and the screen remains blank. The sequence of the blinking lights indicates a specific error code.
    Or
    A series of beeping tones is heard. The sequence of beeping tones indicate a specific error code.
    If a hardware component has recently been replaced, or if the PC has been jarred or shaken, there may be a loose connection to the memory chips or hard drive which prevents the computer from starting.
  3. The BIOS loads the basic input (keyboard) and output (advanced LEDs / display screen / boot drives) devices into memory.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, but then the boot process stops and a black screen - with an error message - displays.
    The boot check has detected a communication error or conflict with a hardware component that must be corrected.
  4. The BIOS loads the Windows operating system and starts the services that allow low-level control of all of the background operations.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, the HP or Compaq Logo displays on a black screen, but then the boot process stops and a blue screen - with an error message - displays.
    The boot check has detected a hardware driver error or a software conflict that must be corrected.
  5. Control is transferred to the Windows loader to initiate the display of the advanced settings in the Windows environment.
    The Windows logo displays during this step.
    Effect & Solution: When you press the power button, the computer performs all the steps in the boot process, but after the Windows Logo displays, the moving Windows progress bar or the rotating cursor stops moving and the boot process stops.
    An error message may display on a screen with the Windows logo. In some instances, there is no specific error message.
    Or
    A black screen appears and the computer attempts to restart.
    The Windows self-check has detected a software conflict that must be corrected.
Jan 09, 2011 | Gateway GT4016 Desktop PC
3 beep sound
If a PC suddenly fails to boot properly, you should perform a hard reset as the first action. Performing the hard reset will correct many problems. If the computer still does not start properly, select your symptom from the list below to guide you to the recommended corrective actions.
  1. Disconnect all peripheral devices and remove all USB devices and SD media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain all residual power and restore default startup settings.
  3. Reconnect the AC power adapter (but do not insert the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a fan or other moving parts turning.
  4. If the computer does not start, the LED lights do not glow, and the display is black, you can perform one or more of the following actions to resolve the no power issue.
    • Verify the computer is receiving power from the AC adapter . Verify that the AC adapter is not damaged and is connected correctly to a working wall outlet plug. Verify AC power is connected to the system board by examining the AC adapter, wiring, and pin connection for damage. The keyboard LEDs will glow when AC power is connected to the system board. Damaged components, like the AC adapter or the pin in the power connector, may require an HP-certified repair.
    • Use a different AC power adapter . If you have access to a different AC adapter or power pack that is designed for the computer, connect it to the notebook and try to start the computer. If you own or have access to more than one notebook, verify that you are using the adapter which belongs to the notebook. CAUTION: Using a power adapter that does not meet the power requirements or has the wrong type of connector may damage the computer. On newer notebook models, connecting the wrong adapter to the notebook may cause the power LED lights to blink but not power the computer.
    • Remove the battery and boot on AC power only . A discharged or defective battery may prevent the AC adapter from supplying enough power to start the computer. To verify that power from the AC adapter is available for PC; remove the battery, connect AC power adapter, and press power button. If available, try using a different AC adapter, that is rated for the PC, and repeat this test.
    • Remove the AC adapter and boot on battery power only . A defective AC adapter may not charge the battery and prevent the computer from booting on battery power only. To verify battery power available for the PC; connect AC power adapter, allow battery to charge for 30 minutes or more, disconnect the power adapter and press power button. If available, try using a fully charged battery, of the same type, from another computer and repeat this test.
      • If LEDS do not glow and the fan or hard drive do not spin, battery may need to be replaced.
      • If tests of both the battery and the AC adapter fail, there may be a problem with system board requiring service by HP.
      • If LEDs glow and PC boots, the AC adapter may need to be replaced.
      • If LEDs glow, but PC does not boot go to LEDs glow, fan is heard, but display is black or blank section.
Nov 21, 2010 | HP Compaq d530c PC Desktop
Acer aspire e500, it will not boot up. one led work.(middle "CD")
Does it display the boot screen?
Do you hear a buzzer or a beeper go off inside?
Sometimes a boot can be stopped by the ram, this is generally made visable by a buzzer or a beeper going off, this will stop the computer to prevent damage.
If it is this, you can get a new ram for about £20, pc world etc, and if you keep the packaging in good condition, you can return it, and just say it didnt work, so you dont loose anything, but youd need to put it in your self, you just unplug the computer, take off the cover, release the ram clips, take the old ram out, and replace it with the new one.
2) Another weird thing which can stop the boot is the ....DVD drive.
I had the same problem before with one of my clients, and for some strange reason, when I removed the DVD player, the computer booted.
So try un connecting your DVD drives, and then try booting
3) Are there any sensors or buttons on the case?
Some PC's have sensors and buttons on the case, with cut of the power if you take the cover off while its running.
It could be that there is a button or a sensor not coming in contact with its connector, and therefore, preventing the computer to boot up.
I hope this helps you,
Jake
Mar 27, 2010 | E-Machines T1360 PC Desktop
Thinkcentre M55 8806 power on off problem
May be your computer motherboard wires connection get loose or getting moisture in wires. Or there may be some earthing problem in ur power switch. First, check the wires connection & tighten up properly. if problem persists, check the earthing by power tester. Check you RAM if it is properly tight in the jack.
Dec 26, 2008 | Computers & Internet
Ibm bios problem
ibm i845 bord date & time save nahi hota cell b change kia ha pls solve problem thx
Dec 17, 2008 | IBM (03R0329) Motherboard
Lenovo booting problem
so u;re saying that the BIOS tests are taking 10 minutes ?! Usually that happenes when the computer shutes down brutally (after power surges, by removing the battery ... by forced shut down). Try doing a BIOS update, and also set it so it will skip some tests or not to do through testing ....
Aug 08, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Intel Dot Station (INTC300AIO) PC Desktop Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
