Question about ASUS Computers & Internet
Motherboard p3v4x : during bootup i get a system
Motherboard p3v4x : during bootup i get a system hung for improper frequency combanation ? what is the proper frequency combo for my board /or/ how do i determine correct frequency combanation thanks mike
    Novelist:
  • 113 Answers
This error is usually caused by an incorrect setting of either bus speed or multiplier (or sometimes processor chip operating voltage). These could be set either by software ie in BIOS or by changing tiny switches mounted on the motherboard.
Have you consulted your motherboard manual?
Try here: http://www.motherboards.org/files/manuals/1/p3v4x-102.pdf
or try the ASUS website and look under support or the discussion forums.
This will help: http://support.asus.com/cpusupport/cpusupport.aspx
These freq and voltage settings are set under BIOS which is usually accessed by hitting the DELETE key on your keyboard after turning on your computer.
Sometimes a quick fix is to enter BIOS as per the above instruction and selecting LOAD BIOS DEFAULTS or something similar to that and then save and exit BIOS and allow the computer to reboot.. That may get you to the point of booting up without the improper freq comb error.
If you have no luck playing with the above info, shut down your computer and remove the left hand side cover on your computer box or tower, so you can access the inner workings of your computer.
Remove the cooling fan from your processor chip. It will be a large square or circular (black or silver colour).
Take a look at your processor chip. Note the part number printed on the chip, which is only visible after you remove the cooling fan. For example it may say for example SL52P or something else. It may also be an AMD chip.
Search the internet for its specifications ie search for SL52P.
For example, if it was a Pentium 3 chip running at 800 Mhz go to google and search for specs of P3 800 Mhz processor with the part number SL52P.
Google returns the following info (based on the example above) of:
http://processorfinder.intel.com/details.aspx?sSpec=SL52P
ie its a chip that runs at 800Mhz speed with the memory running at 133 Mhz (800 mhz processor speed obtained by having the multiplier set to 6 but actually means the memory is running at 133 MHZ but the processor running at 6 times the speed of the memory bus ie 133x6=800 MHZ (one of the settings you need to get right in your BIOS settings)
So if you had this chip, in BIOS you would select 133 bus speed, with the multiplier of 6 usually locked down on the processor physical internal wiring.
If your BIOS doesnt allow you to play with the processor and memory bus settings (commonly done to make the processor overclock to a faster speed) the other option is that you have the DIP switches on your motherboard set to the wrong settings. Again, refer to to your motherboard manual. The DIP switches are tiny plastic switch blocks on the motherboard with a row of (usually) white sliding switches.
Intel chip info: http://www.intel.com/p/en_US/support?iid=hdr-AP+support
http://processorfinder.intel.com/List.aspx?ParentRadio=All&ProcFam=483&SearchKey=
Also Try this: http://processorfinder.intel.com/Default.aspx
Cheers,
Steve (Melbourne, Australia)
Posted on May 11, 2010
  • Steve May 11, 2010
    Update:http://www.motherboards.org/files/manual...
    Read pages 13 thru 19. All will be revealed about what setting is required for whatever processor you have installed.
    Good luck,
    Steve (Melb, Australia)
Chipset heat up while bootup
ur sata/pata drives are gone bad.try to replacing the drives
Apr 28, 2014 | ASUS Computers & Internet
I have giga byte motherboard during startup it show system property in black and white it look ugly is any way that to bypass this
Well, that is the system BIOS that you see on any pc that starts up. It may be possible (depending on the motherboard) to enter BIOS or POST setup and move through the pages and look for something like "Show Logo on bootup" and check that feature.
Other than that, your stuck like the rest of us. :)
Cheers!
Oct 10, 2010 | Microsoft Windows XP Professional
Had a power failure in my area, my dell desktop was on at time. When I turned it back on I got blue screen which I know is not good. Decided to install new/bigger harddrive since I need to install windows...
Hi, you need to change your primary boot device, try pressing the F1 key during bootup, this will take you to the BIOS screen, from here you can change your primary boot device from HD to CD, save your changes, reboot, selecting boot from CD when it appears during bootup.
Hope this helps
Jul 21, 2010 | Dell (E210882) Motherboard
Not totally hung-up but lag during gamming
you have far too low system memory..... modern games use huge amounts of system mem as for your system, widows itself is taking up most of your 1Gb memory let alone any Anti Virus / firewall software installed
a quick mem upgrade should help as a first step.
Apr 23, 2009 | ASUS P5PE-VM Motherboard
During last bootup, your system hung for improper frequency combination. Your system is now working in safe mode. To optimize system performance & reliability, make sure the frequency combination ...
this is only a warning of computer bios., this usually happens if you overclock, or a power failure during POST of bios.. Just press the Restore/Default Setttings.. I think its F2 in some boards, itwill just reset the settings, it should be fine
Feb 02, 2009 | ASUS P4B533-VM Motherboard
Sony pcg-fx140 bootup problem
1. check bios for first boot option to hard drive.
2. If xp, run repair from cd (enable cd boot in bios).
Jul 03, 2008 | Sony MBX-49 ASSY Motherboard
Sound
If under guarantee call the problem to Asus on line / if not covered
You may buy sound card w/ Installation CD a sound driver .
Jan 05, 2008 | ASUS VIA Apollo Pro133A Chipset P3V4X...
Asus P3V4X/S370-133/Tualatin 1.2Ghz
It turns out that while the BIOS will not appear to recognize the Pentium 3 1.4GHz Tualatin CPU (SL6BY) in my Asus P3V4X motherboard, Windows XP does! I apologize for my delay in posting this.
I have five extra SL6BY processors that I'd like to sell if anyone is interested. I need to make some money to upgrade the memory in this antique to 2GB (turns out that low density 512MB RAM does work in the P3V4X, by the way).
Thanks,
Eric
Nov 22, 2007 | ASUS (S370L) Processor Board
Computers & Internet Logo
259 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
