Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
Jandy LXI gas heater. no power to the universal controller interf
I have power to all of the diagnostic points in the manual but the control panel will not energize. is it the PC board or the control panel? using a RS wireless system
    Top Expert:
  • Jandy Master
  • 6,465 Answers
Wireless system to aqualink heater must be hard wired to aqualink by either 4 pin connector or firemans switch
Posted on Jan 30, 2016
PartsCenter
  • 125 Answers
SOURCE: inside control panel displays 6522 rev GG
Aqualink Guide book
Posted on Feb 26, 2009
  • 246 Answers
SOURCE: Jandy aqualink RS handheld went out during
GO TO THE MAIN PANEL AND RESET THE SYSTEM
Posted on Oct 13, 2009
  • 246 Answers
SOURCE: My Aqualink RS Wireless says Pool Heater Jandy
AT THE HEATER PRESS THE BOTTOM TO TURN THE HEATER ON LINE IF NOTHING HAPPEND THE HEATER MUST DE WIRE CHECK YOU MANUAL FOR THIS ONE
Posted on Oct 15, 2009
  • 6 Answers
SOURCE: jandy lite2 heater has fl5 error code, all voltages look good
If all voltage test points are within range, then it's 1 of 3 problems: Power Conversion Plug is faulty; Power Control Board is faulty; or Controller is faulty. Jandy says there is no way to test any of these directly. They recommend that you replace both the Power Conversion Plug (~$35) and the Power Control Board (~$230). Apparently when one fails, it can cause the other to fail as well. They said that unless the Controller has a lot of corrosion on it, then it probably is not the issue.
Posted on May 20, 2010
rickspool
  • 20 Answers
SOURCE: I have a Jandy Aqualink
On the RS system there is a small fuse on the back of the circuit board. That may have been burnt. It acts as a safety for the transformer. Make sure ALL of the power is off, then check that fuse. Do not keep the shorted valve actuator plugged in. Replace it, or leave it disconnected. Then replace the fuse. Then re-apply power to the unit. Otherwise your transformer may go out next. If the fuse is not burnt, which would surprise me, you may have a burnt transformer.
Posted on Apr 04, 2011
"fault check ignition control
turn heater off then turn back on make sure gas is on
Jan 04, 2014 | Jandy LXI 300 PROPANE POOL HEATER -
Control panel is blank and the gas company checked the pressure, it is at 5. The heater is not activated.
first of all, if the inlet gas pressure was only 5 inches water column the heater will under fire once it runs. that pressure will have a slight drop once the heater is running. So, the gas company should have known that and realized the gas line may have been undersized. Secondly, if the control panel is blank you probably have a problem with the transformer inside the heater. The secondary side will send out 24 volts, the control panel also runs on 24 volts.
Sep 18, 2013 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Jandy LXi gas heater error message "ignition control failed
if ignitor is glowing try changing position of the shutter 1/2 to 3/4 open should lite
Dec 22, 2012 | Jandy Laars LX Pool Heater / 250,000 BTU /...
The heater won't light up on my Jandy LXi400n Lxi heater
make sure red light is on for calling for heat if so make sure 24 volts ac on both sides of pressure switch if ok make sure gas is on
Jul 13, 2012 | Jandy LXI400N Lxi Pool & Spa Heater -...
Jandy lxi heater low pressure warning
check filters if ok check pressure switch and tube going to it
May 17, 2012 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Won't ignite
make sure wiring is correct for 220 vs 110 wired for 220 from factory if 110 see inside panel move wires ignitor is not getting hot enough
Jun 02, 2009 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
159 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
