WILL NOT SPIN DVD - Televison & Video
  • mikestar Apr 05, 2008
    tryed cleaning lens, still will not spin. Starts to spins slowly then stops. Will try to start again then stops.
  • Malignus May 23, 2008
    My player suddenly has developed the same problem.  Won't spin any DVD or CD I put into it.
  • 82 Answers
Try cleaning the lens.
Posted on Mar 27, 2008
Dvd player just ticks and doesn't register a dvd
1.The DVD Drive makes two-three times noise than stop spin the media CD or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray, close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Nov 23, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
I have a supersonic dvd player and it won't spin at all.Model no sc-178 dvd
sorry to say but most likely case is bad motor or turntable issue of some type. unless expensive unit cheaper to buy a new player.
Nov 03, 2012 | Televison & Video
Dvd will not play i opened it up and the dvd will spin then slow down then spin again- it will not load the dvd no matter what kind of dvd i put in. can u help me
Check for fingerprints or dirt on your DVD. Wipe it clean and try again. Also check for scratches. Try another DVD and see if your system reads it.
Dec 02, 2010 | Samsung HT-P38 System
Cd player on my dell will not spin
check that power cable to rom is plugged in....if still no spin, then replace cd rom unit
Dec 29, 2009 | Computers & Internet
Panisonic DVD RV-31 Wont read any DVD...shows a "Ho2" code
The motor is on its way out - the H02 code indicates motor failure as in it cannot spin the disc. You can sometimes fix it but for how long is anyone's guess. Disconnect from the power, remove the three rear screws and two screws on each side (total 7) and lift off the outer cover. Now if you carefully reconnect the power BE VERY CAREFUL NOT TO TOUCH ANY PARTS INSIDE THE CASE and put a DVD disc in as per normal, you'll will see that when the tray closes, the upper platen (a honeycomb disc) that sandwiches the DVD to the lower platen does not spin - it should. Give a gentle spin clockwise and it should spin up and the DVD will play. You may need to restart if you missed your chance first time. If you switch off and on, eject and close the tray, the spin should happen as normal. If it doesn't, your motor is knackered and not an economical repair. Buy a new player. If it spins time and time again, you may well have temporarily fixed it for a while.
Jan 10, 2009 | Panasonic DVD-RV31 DVD Player
Dvd player wont spin disks
Sounds like a bad motor or motor controller inside the unit. Does it have fresh batteries?
nssms
Sep 15, 2008 | GPX PDL805 Portable DVD Player
DVD player will not read any disc
The motor is on its way out - the H02 code indicates motor failure as in it cannot spin the disc. You can sometimes fix it but for how long is anyone's guess. Disconnect from the power, remove the three rear screws and two screws on each side (total 7) and lift off the outer cover. Now if you carefully reconnect the power BE VER YCAREFULLY NOT TO TOUCH ANY PARTS INSIDE THE CASE and put a DVD disc in as per normal, you'll will see that when the tray closes, the upper platen (a honeycomb disc) that sandwiches the DVD to the lower platen does not spin - it should. Give a gentle spin clockwise and it should spin up and the DVD will play. You may need to restart if you missed your chance first time. If you switch off and on, eject and close the tray, the spin should happen as normal. If it doesn't, your motor is knacked and not an economical repair. Buy a new player. If it spins time and time again, you may well have temporarily fixed it for a while.
Jun 17, 2008 | Panasonic DVD-RV31 DVD Player
Televison & Video Logo
164 people viewed this question
Top Televison & Video Experts
