Question about Jandy AQUALINK RS TELELINK KIT
I have a Jandy aqualink one touch that controls my pool and spa. I fliped the cover today to adjust the timer for the landscape lights and noticed the system is dead. Nothing at the control panel lights up. Any help????
  • 84 Answers
If it is just the remote and the Jandy PowerCenter is still working normally, I would first check that the 4 wire cable to the one-touch is intact using a continuity tester. If you verify that the wiring to the remote is fine, then there is a problem with the one-touch remote which can be fixed.
If see other problems when controlling the pool with the Jandy PowerCenter, then the main problem is probably that the powercenter is not getting the power to the one-touch. Hence the powercenter would need to be repaired.
These Jandy boards can be repaired at www.fixyourboard.com.
Hope this helps
Posted on Jun 11, 2010
6520 rev hh
check red 4 pin connectors to see if any wires touching if not make sure wires are tight also make sure wire isnt cut or knicked sometimes landscapers do it not knowing seems like shorted wire if you can take controller with shorter wire and try next to aqualink if it works bad wire if not bad controller
May 01, 2013 | Jandy Aqualink RS6 Pool Only/Spa Only...
Jandy RS 6 panel not working. After pressing reset button, all lights on panel come on and there is no effect from press panel buttons. panel reads "Rev 6700 C." Have pulled out red 4-wire panel...
check wire going from 4 pin to controller see if by 4 pins wires touching or try controller with short wire by system wire sounds like shorted sometimes cut by landscapers
Mar 30, 2013 | Jandy AquaLink RS2/6 All Button Dual...
How do i go to auto timer settings with a jandy pool remote
leave on auto go to system setup go to programming high lite what you want then add times if you want 24 hours go 2:00am to 1:59am it will shut off for 1 minute then reset
Jun 28, 2012 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
How do i go to auto timer settings with a jandy aquapalm
go to system setup then go to programs high lite what you want then add times
I have Jandy 8157 and one touch button unit in the house does not repond but the timers still works. I can control the unit from main pannel at the filter out side. Do i need a new mother board.
take the top front panel see if the red 4 pin connector is connected and tight if so check to see if the wire has been cut (sometimes by landscapers) if connected see if you have at least 10 volts or more at the plug if so check the red plug at the controller in house if not the same bad wire if 24 to 10 volts bad controller you can also try by system with jumper wire to see if it works
May 19, 2012 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Jandy hand held just says wait wont connect. I tried reset and fliped circuit breaker
This is a common problem with the communication between the RS Aqualink remotes and power centers. These can be fixed quickly and reliably at www.fixyourboard.com
May 13, 2010 | Jandy Aqualink Rs4 One Touch Control...
I have this jandy aqualink one touch rs control in my pool, but suddenly start to turning on and off by itself
GO TO THE MAIN PANEL AND OPEN IT DISCONECT THE SPA SIDE SWITCH LEAVE OFF AND SEE WHAT HAPPEND FOR A FEW DAY IF OK REPLAACE SWITCH
Oct 14, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy AQUALINK RS TELELINK KIT  Logo
314 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
