Question about PNY 4GB microSD High Capacity Mobile Media Kit
Is a PNY SDHC 4 GB Memory Card compatible with a Canon PowerShot A530 camera? The card currently in the camera is not a HC card.
    Brigadier General:
  • 4,090 Answers
I think the maximum size card you can use in the power shot is a 1Gb card unless nes firmware has been istalled to allow 2Gb card.
Using large capacity cards also delays the write recovery time. So if you are trying to capture moving objects , often you get one shot and then it takes almost 20 seconds to recover for the next pic. Too late for most things that move
hope this was of some help
V
Posted on May 09, 2010
I have Canon SX200 IS camera with 4 GB flash memory,and want 2 upgrate its expendable memory upto maximum limit.The camera will support upto which GB?
Hello
In addition to SD, SDHC and MMC memory cards, the PowerShot SX200 IS supports MMCplus and HC MMCplus card formats upto 32mb.
Good Luck
Jan 15, 2011 | Canon PowerShot SX 200 IS Digital Camera
Brand new 4 GB Sony memory card. I get a card locked/memory card failure.
The A530 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and won't work. You need to use cards 2GB and smaller with the A530.
Dec 15, 2010 | Canon PowerShot A530 Digital Camera
I have inserted a new PNY optima SC HC memory card and window in camera says "memory card error". Does the canon not take this card?
Correct. The A510 uses SD cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work.
Nov 02, 2010 | Canon PowerShot A510 Digital Camera
New digital memory card inserted and camara reads memory card error
1. Try to format your memory card using a PC/Laptop.
2. Now, insert it in camera and check whether its working!
please rate this advice if it helps....tc! :)
Jan 02, 2010 | Canon PowerShot A530 Digital Camera
A530 has message "memory card full". tried 2 cards same results.
1. First, try to format both the memory cards using a PC/Laptop.
Dec 21, 2009 | Canon PowerShot A530 Digital Camera
My canon sd600 is not reading PNY sdhc memory card. msg says card is locked. it's clearly not locked
HC or High Capacity is not compatible with this camera. You have to buy a memory card which says only "SD" and NOT "SDHC". Cards of 2Gb and less are usually "SD". Cards of 8Gb and more are always "SDHC" for technical reasons. Cards of 4Gb can be either, but the SDHC kind are much more common, because they're cheaper and newer.
Jun 22, 2009 | Canon PowerShot SD600 Digital Camera
Canon camera won't accept SD memory card
It's a good bet that anything 4GB or greater is a SDHC card (look on the card, see if SDHC is written there). Your A530 was designed before the new SDHC format came out. Sorry, but your camera will not recognize this type of card. Recommend instead that you get a 2GB standard SD card. They're relatively inexpensive these days.
Jun 07, 2009 | Canon PowerShot A530 Digital Camera
I bought two 4 GB PNY Optima SD HC 60 HD cards for my Canon PowerShot SD 800 IS Digital Elph for a very special event. It captured all of the photos as my other cards have, but when I went to download the...
pny does not supply card readers w/memory cards-sandisk on certain cards includes reader because file format is different on sdhc cards -try downloading direct from camera w/usb or get a card reader that absolutley supports sdhc type cards-not all readers do!
Jun 25, 2008 | Cameras
PNY 4GB microSD High Capacity Mobile Media Kit Logo
176 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
