Question about LG WM-2277HW Front Load Washer
Soap drawer is filled with water
When i open the drawer to add detergent etc. The drawer and compartments are full with water already. How can I fix this?
Our 2 year old washer just started seeing this problem. After removing the detergent dispenser drawer from the washer, cleaning it and cleaning the slot it came from we stopped seeing water retention.
Posted on Sep 19, 2010
Water leaking from detergent drawer
The first thing to do is take note of what the washer is doing when water leaks out in order to help pinpoint the cause. Does it only leak when filling? Is it leaking during wash or rinses? Or is it leaking only when it goes into spin?
Only leaks when filling
  • Water pressure that's too strong. Some dispensers can't cope with high water pressure. Make sure the washer is level as one leaning forward can leak if combined with high water pressure. Try turning the tap on the washer down. Only suspect this if you know the water pressure is high and it looks like it's gushing in quite fast on fill
  • If there is an optional detergent flap fitted in the drawer for holding liquid detergent make sure it is removed or drawn into the up position if using powder otherwise it prevents detergent running down into the drum
  • A build up of grease and slime in the nozzles at the top of the dispenser where the water flows in causing water to spray at the front and run out when filling. Check this article -black jelly-like substance in soap dispenser and on soap drawer (In extreme cases I've had to replace the dispenser.)
  • A build up of undissolved detergent in the base of the soap dispenser under the drawer (depending on the design). Remove the soap drawer and check the bottom of the soap dispenser for a build up of detergent that could allow water to run over the lip of the dispenser
  • Blocked dispenser hose: Some washing machines can flood water out of the soap dispenser if the hose leading out of the dispenser into the tub gets blocked. Blockages can be something put into the drawer by a child or a chunk of undissolved detergent tablet. Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and it wasn't wide enough. Undissolved powder from a tablet or lumps of detergent through poor water pressure can block this hose solid causing water to back up. Unplug machine, remove lid and feel this hose carefully for obstructions.
  • Overfilling: If the washer starts to fill and never stops it will flood out of the drawer eventually - Washing machine overfills
Leaks out of drawer during the wash or rinse cycle
  • Too many suds? If you can see the door glass is white with foam up to the top it could be foaming out of the dispenser. Too much foam in the washing machine
  • Overfilling: If the washer starts washing but the water doesn't stop coming in it will eventually fill the drum so much it will start to pour out of the soap drawer and other places. If this is the fault you should be able to see the drum is so full of water it's making a different sound, maybe labouring under the load, and the door glass full to the top with water. You should also hear that water is still running into the machine and be able to detect it by opening the drawer. However, in most cases an over filling washing machine should trigger an error code long before it gets to this stage but if you suspect overfilling check this page - Washing machine overfills
  • Surging: There are (often intermittent) faults that can cause the motor to spin out of control on wash or rinses. Instead of turning slowly the fault causes the motor to surge into spin instead which throws the laundry and all the water about violently. Water can then be forced out of the soap dispenser drawer. This fault should be relatively rare these days but if you observe this behaviour call an engineer to diagnose the cause.
Leaks from drawer only when spinning
  • If it only comes out on spin it can be caused by a partial blockage preventing the water being pumped out fast enough resulting in excess water being thrown around on spin and backing up into the dispenser. This fault is similar to the surging fault described in the last list but different in that the problem only occurs when it's on a proper spin cycle and much of the water has been pumped away. Troubleshooting this fault is all about finding out why it isn't emptying the water properly which is usually due to a partial blockage. Follow the same troubleshooting as described for a washer not pumping any water out at all - Washing machine won't empty water
  • If water is being forced out of the drawer when the washer is spinning but it is on wash or rinse and shouldn't be spinning follow the procedure for surging in the previous section above
Dec 23, 2016 | Washing Machines
I need a manual for Spectra TL3635 INOX washer
The manual doesn't appear to be available online, but you don't really need it.
Remove the drawer by pulling it out, and then lift and pull. Are you sure it isn't marked what goes where? My Whirlpool washer is marked in raised writing.
The detergent is one large compartment that is open at the back.
The bleach dispenser is usually in the middle and is small.
The fabric Softener is full depth, but has a system which siphons the softener out when water is added to it. In other words it is a reservoir that holds the fabric conditioner until needed.
With the drawer removed, turn the machine on to do a small wash. Water will come down on the section for detergent at the very beginning. towards the end of the first fill, another jet of water will come down to add bleach to the already filled machine. After the rinses, when it gets to final rinse, a jet of water will hit the Fabric Conditioner compartment. Get ready to insert the drawer if the water splashes out, or plug the front with a tea towel.
Aug 12, 2015 | Washing Machines
The middle compartment in my drawer of the washing machine keeps filling with water and the water stays in there and won't empty by itself
This isn't unusual in the fabric softener compartment but in the other compartments it could be caused by soap residue build-up. It is wise to remove the drawer completely after every few washes and to check both the drawer and the aperture, especially the outlet holes that are exposed once the drawer is removed. Any blockages here could cause a flood while the washer is filling.
Liquid detergents cause fewer problems but many users prefer to place detergents directly in the drum with the laundry these days rather than using the drawer dispensers.
If in doubt I suggest you spend time reading the instruction leaflet and it is wise to add a white appliance engineer to your circle of friends for inside information and reasonably-priced repairs.
Feb 08, 2015 | Washing Machines
How do you use the tub clean?
Read these instructions carefully before
beginning the TUB CLEAN cycle.
Open the door and remove any clothing in
the wash drum.
Open the dispenser drawer.
Add liquid chlorine bleach or tub cleaner.
Some powder or tablet tub cleaners which
are manufactured for this purpose can be
used.
(NOTE : Do not add any laundry detergent
or fabric softener to the drawer when using
TUB CLEAN.)
- If using liquid chlorine bleach
Add liquid chlorine bleach to the bleach
compartment of the drawer.
(NOTE : Do not exceed the maximum
fill line and do not pour undiluted liquid
bleach directly into the wash drum.)
- If using powder cleaner
Remove the liquid detergent cup and
add powder cleaner to the main wash
- If using tablet cleaner
Add tablet cleaner to the wash drum
directly.
(NOTE : Do not add tablet cleaner to the
drawer.)
Close the drawer and washer door.
5
Select TUB CLEAN and press START.
NOTE : It is recommended that TUB CLEAN
should be repeated monthly.
If mildew or musty smell already exists, run TUB
CLEAN for 3 consecutive weeks.
After TUB CLEAN is complete or when the washer
is not used, leave the washer door open for better
ventilation and drying inside of the washer
Jul 05, 2014 | LG WM2701HV Washer
My dishes and the inside of the dishwasher are covered with soap scum
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
May 18, 2011 | Whirlpool Dishwashers
Bosch dishwasher dw44zp/16 dishes have soap residue and are not clean
Hi
Daniel
Apr 02, 2011 | Bosch Dishwashers
I have a Whirlpool Duet and the water is over flowing from the soap drawer. I have already cleaned out the soap drawer and tried flushing the opening that leads into the machine with a hose. Any other...
This is inevitably caused by a blockage. The small fabric conditioner compartment in the soap dispenser drawer has a removable plastic cap. This cap fits on the top of a tube which has a hole running through it where the water should siphon through.
When the time comes for the fabric conditioner to be released, cold water enters the small compartment and just washes the conditioner over the top and down the dispenser to the tub. When the water stops flowing, all that is left is the clear water. This water should siphon up the inside of the cap and down the tube.
This tube often gets blocked with the conditioner and if you remove the dispenser drawer and take off the cap you can give the whole thing a good clean out. If the cap is missing, the siphoning will not occur.
To test the function, hold the soap drawer under the tap and allow the water to fill the fabric compartment to overflowing. When you turn off the tap, the remaining water should slowly siphon out of the hole under the cap.
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Eurotech washer Leaking water front detergent drawer
I'm not familiar with your machine but usually there are nozzles above the soap drawer which squirt the water on to the detergent compartments at the appropriate times . If you can take out the soap tray have a look to see if the nozzle bit has come loose and is pointing towards you...also check that the outlets from the soap tray are not clogged with...soap.
Failing that, you could partially turn off the water supply to the machine so the pressure is reduced. Sure it will take longer to fill, but you won't get so wet.
Hope this helps. If this "fixes ya", I'd appreciate a rating for my reply, If not, please delay the rating and add a comment with any extra info you have and I will try to think of something else.
Thanks, D
Jun 11, 2008 | EuroTech EWF172 Front Load Washer
Water in soap holder after washing.
my washer is about 1 year old. It started leaving water in all the the compartments,soap,bleach and softner. I tried everything also. Nothing seemed to work. I finally took the hoses off the back of the machine, and the cold water hose screen was clogged up going into the machine. I cleaned all the screens and haven't had that problem again. I think there wasn't enough water pressure to flush out the containers. I dont think its gravity or suction, its water pressure. unless you get a blast of water into these compartments, there will always be water left in these containers.
Oct 27, 2007 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
1,433 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
