Question about Homelite ZR10926 16" Chain Saw
Hi how to tune homelite 330 chain saw carby, idle
Hi how to tune homelite 330 chain saw carby, idle and high & low settings
    Brigadier General:
  • 4,088 Answers
Before adjusting anything, check the fuel filter, air filter, and muffler for plugging. Check the condition of the fuel lines for decay or other damage. Tighten all carburetor fasteners. Make sure you have fresh fuel mix in the tank. Does the primer bulb pull fresh fuel into itself when pumped? Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and should allow the engine to start and run. Start the engine and allow it to warm up, then pull the throttle full on. Adjust H needle CW until the engine starts to speed up, but still 4-stroking. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for fairly good idle, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
Posted on Jul 15, 2010
  • John R
    John R Oct 09, 2014
    What is meant by 4-stroking?
My stihl chain saw runs full out without pulling the trigger? what can i do?
carby idle adjustment or a carby kit and clean needed
carby has a high and a low rpm jets
STIHL MS 290, 310, 390
https://www.stihlusa.com/.../instructionmanuals/stihl-ms-290-310-390-owners-instructio...
Instruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! ..... model. Safe use of a chainsaw involves. 1. the operator. 2. the saw.
Oct 13, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
My Homelite ZR10926 16-Inch 33cc Ranger it is starting, idling, it dies when I accelerate it. I assume is the carburetor, maybe ? thank you.
It probably is not getting enough fuel. Check the filter in the tank. If it has been sitting with stale gass this filter plugs up.
Try running the engine with some choke. If this helps, try adjusting the carburetor high speed screw.
Jun 04, 2011 | Homelite ZR10926 16 Chain Saw
Adjust carburator on homlite chain saw
Hi
If its an old Homelite you should have 3 screw on the carburator.
First bigger screw for adjust idle on the butterfly.
The 2 other for the mixture. One screw is ''L'' for low rpm mixture an other screw is ''H'' for high rpm mixture.
First the idle screw. It should just open a little bit the carburator butterfly.
Second full close both ''L'' and ''H'' screws (turn clockwise).
After open both ''L'' and ''H'' screws 1/2 to 3/4 turn (conterclockwise)
Normally the saw should start. Tune the ''L'' screw to have the motor running at idle if idle is to fast at this point is not important. After motor is running by itself at idle tune the ''H'' screw.
Full throttle tune the ''H'' screw to be able to pass from low rpm to high rpm with no lag.
Than at full throttle open again a little bit the ''H'' screw to make the high rmp mixture more rich.
Becarful if ''H'' screw is not adjust correctly the mixture will be to poor and motor damage can occur.
It may be necessary to re-tune a very little bit the ''L'' screw and idle screw after the correct setting of the ''H'' screw.
If it still not working carburator kit may be needed,
On some newer model there is no adjusting screws in this case see if a carburator kit is available for your model.
Feb 07, 2011 | Garden
How to set the hi- low screw on a homelite xl chain saw.model number 10655
set them both at 1 1/2 turns out from bottom and then fine tune it from tgere when it is running. This will get you really close. Hope this helps.
Sep 14, 2009 | Homelite Garden
I have a Homelite model 20 chain saw. It will
on your machine may be on the side of it that led into the carb should have H for high L low L is for the idle H is for all out ball to the wall you will need a small long screw flat head . put in the H ,turn out for more gas in for less good luck
May 12, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
I have a homelite chain saw and is out of setting.
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn.
May 01, 2009 | Homelite ZR10926 16 Chain Saw
Need to adjust carburetor jets of homelite chain saw
what is the adjustment for high and low settings on a homlite 330 ?
Jan 11, 2009 | Garden
Homelite ZR10926 16" Chain Saw Logo
2,045 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
