Question about Cobra 148 GTL 120-Channels Base CB Radio
Hello, I dusted off my old Cobra 2000 GTL and plugged it into the wall and it will not power on. The clock is on and adjustable. It was last working before I boxed it up a few years back. Is this a known problem? Power switch? Please advise. Robin
  • 1 more comment
  • rzelych May 09, 2010
    I've done some additional troubleshooting and the results are as follows;
    1. hooked up 12v instead of 120v and results same, power to clock but no main power on.
    2. disassembled and hooked up voltmeter to power supply. I get 16 vac on the output of main transformer. I get 0 v from the output of the bridge rectifier, therefore I conclude that the bridge rectifier is bad. Can anyone confirm or deny my findings? I have not had to troubleshoot a power supply for some time and am rusty.
    Robin
  • rzelych May 14, 2010
    Thanks for your feedback. The problem got resolved in another manner.
    As I was probing around the power supply section measuring voltages, I moved a wire connected to the output of the bridge rectifier and the system lit up. Cold/old solder joint thing.
    Genius:
  • 1,274 Answers
Try this, plug it all up and turn it on, let it set over night, then try it, after a radio has been put away for a while, the capacitors lose charge...hope this was helpful....
Posted on May 12, 2010
How to fix cobra 1000 gtl Powers up,meters stuck, no rx just static, All lights work, A mic will Key the on the air light,
have you checked the voltages inside the radio?If you have to much or to little it will not work properly.
Jan 19, 2014 | Cobra 2000 Gtl / 1000 Rf Pwr / Signal...
Cobra 200 gtl dx only does 12 watts on high
Open radio up and adjust rv9for am fm high power or rv 14 for ssb for high power,do not use a screwdriver,a matchstick would be better.board information is available from cb tricks.com
Dec 17, 2011 | Cobra 200 GTL DX 4-Channels Base CB Radio
Reset on the back of cobra gtl 2000 cb radio
the reset button is used to reset the cpu when doing mods.try replacing with momentary press switch.
good luck
ken
Apr 04, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Can I take phinals out of my cobra 29 mobile and put them in my Cobra 100 gtl base
no, they are completely different finals. The cobra 29 only has one, the 1000 has 2, one for side band and one for am.
Jan 12, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 148fgtl low power on am/ssb no swing all finals ok
try adjusting the L36,L38 to the highest reading on the external meter and then adjust VR10 TO 4 watts. If this doesn't cure the problem, you have a weak final transistor. Good Luck
Feb 06, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra gtl 148 seems to have no power til i push on mic connecter.
cobra 148 shows no wattage output on external meter but does show good modulation.
Dec 08, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 150 gtl?
RV12 is the modulation adjust for the 150. Check with cbtricks.com for physical location.
May 20, 2008 | Cobra 150 GTL DX Base CB Radio
Cobra 200
Hello Jim. These radios do not work well with any power mic including the power echo mics because they have good modulation boards in them. But if you still want to try then check http://www.cbtricks.com/radios/cobra/200gtl_dx/index.htm
Mar 26, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Cobra 148GTL
Hello k007,
It sounds like you may have damaged the RF power amplifier stage of the CB. Since you were adjusting the antenna characteristics. Did you have a SWR (Standing Wave Ratio) meter connected while you were tuning the unit? If you did you might have noticed the needle go past the 1.2 mark when you were adjusting the antenna or the unit itself. In any event I think that the RF power Amp is shot.
Thank you,
Shuttle83
Nov 04, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
126 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
