Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
My kenmore 10658026800 does not cool... where is the defrost timer?
  • Kenmore Master
  • 4,654 Answers
I found the parts page but Kenmore does not have the parts listed. You refrigerator was made by Whirlpool and Sears changed the model number. Looking a the sears photos your model does not have a defrost timer but does have an Adaptive Defrost Control located inside the fresh food compartment and behind the control panel where you set temperatures. Defrost failures and compressors stopping as you said in your post are common for the ADC I will continue to try to cross it over to the Whirlpool Model but most likely that is the problem. When an ADC fails strange things begin to happen. Once you start to look for the ADC unplug and remove the top shelf to help lower the control panel. I will return soon to leave you more contact information and what the part looks like. OK your model came with three different styles of defrost controls located in same area. Timer and two different ADC boards. I will need you to look and read the numbers off of what you find. If a timer we can test, defrost boards usually have burn marks on front or back when damaged. Let me know what you find and we go to next step. Is ice building in freezer rear wall or is just lights on? Sea Breeze
Posted on May 09, 2010
Kenmore sidebyside 53552200 stoped cooling and defrosted completly light still works both frezer and refrigerator not getting cold
It could be stuck in defrost. Check your defrost heater, and see, if it is still hot. If it is, then the defrost timer is stuck. When it goes into defrost, everything, stops working, but the defrost heater and light. As long, as the defrost timer is on, nothing else will work, as far as the compressor, freezer fan, and any cooling/freezing.
Sep 07, 2014 | Kenmore Refrigerators
We have a top freezer Kenmore refrigerator which is at least 12 years old. It is cooling intermittently. It will cool everything just fine for three or four days and then it will defrost completely.
That sounds like your defrost timer is beginning to failm moving slower and sticking into the defrost cycle longer than it should. WR9X520 Defrost Timer
The defrost timer can be found inside and behind the control panel where you adjust temperature. Item 648 in this diagram is your defrost timer=> HERE Let me know should you have questions I will be here to answer them, Thanks Sea Breeze
Nov 15, 2012 | Kenmore Refrigerators
Kenmore fridge leaks water on floor and then stops cooling. Tech said it needed heater/defroster and would cost $500. Does this sound right.
Ah no. If the fridge was not defrosting then water would not be leaking out.
It sounds like the defrost timer is not completing it's cycle. You may need a new defrost timer.
The cost of a new timer, call out, fitting and testing could be around $375
Mar 31, 2011 | Kenmore Side by Side Refrigerator
My freezer gets cold but fridge stays warm i have defrosted and the problem continues kenmore model# 9704284 any suggestions
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 24, 2010 | Kenmore Refrigerators
My side by side will not defrost. Kenmore 1999.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 05, 2010 | Kenmore 57029 Side by Side Refrigerator
Refridg... (kenmore) wont cool
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 25, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator model 106.54592400 wont cool
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Nov 16, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore won't cool down.
I you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 15, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
The refrigerator side is not cooling and the freezer side is working fine. Two weeks ago this same problem occured and I moved everything to my backup frig and allowed the kenmore to defrost over night....
it indicates the problem with defrost timer.actually the defrost timer sends the command to defrost the ice formed inside the tube after every particular time interval.if the timer is faulty.it wont defrost at all and the ice will keep clogging the tubes and so some sections of fridge wont get cooled due to clogged vents until its manually defrosted. to fix this problem you will have to get the defrost timer replaced.this will definately solve the issue.
thanks.
Jul 08, 2009 | Kenmore Refrigerators
Water was leaking out of the freezer so I cleaned the ice build up on the freezer and now the frigerator is not cooling. I have a Kenmore side by side
check and make sure the timer is not stuck in defrost mode. if you can turn the timer by hand past the current point it should advance past the defrost cycle and begin cooling. The timer is usally found near the bottom of the refrig located in the front side.
Jul 07, 2009 | Kenmore 72102 / 72104
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
213 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
