Question about Hunter Dryers
I have a Hunter ceiling fan in the house I just bought. The pull chain for the speeds never worked; it was stuck on low. I finally took it apart, and the chain was broken at the switch. I replaced the (4 wire) switch exactly as I took it off, and now (and possibly always) high and medium do nothing, low works, and off works. What do I do? The wires which I put back the way I found them are black(L), gray(1), brown(2), green(3).
  • chriskleinsa May 09, 2010
    Is that something I can replace?
  • 2,841 Answers
L — Black 1.— Grey wire 2.— Brown wire 3.— Green Wire I have been told that you will have to get the speed control from Hunter and that a universal fan speed switch will not work. How true this is I do not know.
Posted on May 10, 2010
  • 10,319 Answers
The fan speed resistor inside the motor has gone bad since it is wired correctly.
Posted on May 09, 2010
Bad hunter ceiling fan light pull switch
I don't know what you mean, longer stem/chain housing to hold light fixture. You should be replacing a two wire switch only.
Feb 15, 2014 | Hunter Dryers
Ceiling fan stuck on low
in order for the remote control to work properly the fan has to be on its highest speed using the pull chain ... after setting the pull chain in the proper position you can tie up the chain or remove it to prevent others from changing the setting .. the remote will control the speed from then on ..
Jun 07, 2010 | Hampton Bay 24002 Ceiling Fan
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
New hunter fan makes about 5 clicks per revolution at any speed (5 bladed fan), Worse in one direction. No chains, wires in blades. Moving the housing by pushing on the light makes no change. Whats up?
I would pull it apart if necessary (depends on the model) and look for a small piece of packaging material in the air vents on the top of the motor. Good luck.
Jan 03, 2010 | Hunter 52" Ceiling Fan With Light And...
Fan stuck on LOW speed
It seems to me you have a faulty switch or the internal wiring is wrong. You can access the switch from the bottom of the fanwhere the light kit is connected. the wiring could have gotten mixed up when the light kit was installed.
Jun 22, 2009 | Hunter (25417) Ceiling Fan
Fan won't turn on, dont know where switch is
I looked up the owners manual for your fan at the following site: http://www.hunterfan.com/search.aspx?search=20763
Click on the pdf file labeled owner's.This manual indicates there should be a pull chain for turning on and off the fan. Maybe the chain has broken off up inside the fan. You can follow the instructions in this manual to take the fan apart and replace the pull chain.
May 30, 2009 | Hunter 20763 52'' The Stratford II Ceiling...
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
Hunter ceiling speed.
A fan that old has a muilti speed capacitor. It could be that or the swicth. First thing to do is test the swicth with a voltage tester to see if power is switched to different posts if it does switch it is prob. the cap. Good luck trying to find one.
Apr 06, 2008 | Hunter Low Profile III 20807 Ceiling Fan
Dryers Logo
156 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
