Question about Microsoft PowerPoint 2003 for PC
Need to print 1 letter in 1 page normal size
What is the setting and/or fix for no prompt at tray 1 for special media?
Set tray 1 paper size to "any size/any type". print out a configuration page to make sure that this setting took. set manual feed prompt to " unless loaded". That should work. Good luck !
May 14, 2014 | HP LaserJet P4014n Printer
At work I have a LaserJet and for some reason it will only print from "tray 2" opposed to the normal "tray 1." How do you switch trays?
first what size is tray 1 set for and the type. generally tray 1 is set for letter size and the type is plain and usually is the normal default configuration.
also check the tray guides for proper setting letter size..
Also if possible run a configuration page to see how your current paper handling settings are being read by your printer.
the MP Tray is generally setup as ANY Size and ANY type always.
check your paper handling setup settings..there are additional steps, let me know.
Aug 21, 2010 | HP LaserJet 2300d Printer
Need larger print size to aid reading materals.
down in the bottom right of your webpage you will see 100% theres a little triangle to the right of that click on that and select what size you want it increases the size of web page and you can go back to normal just as easy.....but is it on web page or when your printing a letter...if its printing a letter put the mouse to the left of the sentence you want to make bigger click once to highlight it it should turn blue then go to the size at the top of the page and click on the drop down menu on the little triangle to the right of the number and select size it should get bigger the higher the number you select hope this helps
Aug 11, 2010 | Compaq Presario 5000 PC Desktop
After printing 1 page or a test page the attention light blink i check there is no paper jam everythings fine
Probably you are printing for a legal size paper on letter paper. Check the paper size and be sure you have letter 8 1/2 X 11, or whatever real paper you are loading on the printer.
Aug 13, 2009 | HP Office Equipment & Supplies
The letters pinted by my printer are very small.
just select the page to be printed by pressing --ctrl + A----then on the top of the page there is a option to increase the size of the letters.just select the size u want.normaLLy the printing size for a document is 12.
Dec 06, 2008 | HP Office Equipment & Supplies
Konica/Minolta majicolor 2300DL printer
pleas check the driver settings, maybe there is a setting fit to paper or something.
May 07, 2008 | Konica Minolta magicolor 2300DL Laser...
Tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
"always getting check paper size"
the paper size you are using is incorrect.
1- when you take out the tray is the the paper snug in the tray? is the paper adjuster set to LETTER, is there a switch for custom and letter? is it set to letter?is it set to letter in the menu?
Dec 08, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
Keep getting "11 load letter in tray 1" message
Are the print jobs being sent to printer all the same page size?
Are they all print jobs sent letter page size and your printers cassettes are set for A4 or something?
Your printer is asking for letter size paper, because any paper it has is not set to letter  and document that it is trying to print has been sent as that size.
Check what options you have on print driver on pc as far as Tray defaults, paper type and size settings
Check printer settings via its keypad as to tray defaults, paper size set for each tray and paper type, some printers have paper size switchs on their trays too.
Oct 26, 2007 | IBM Network Printer 12 Laser
Microsoft PowerPoint 2003 for PC Logo
29 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
