Question about Refrigerators
Hi , I have problem a refrigerator ?KitchenAid? mod #106.53552201 . Ice maker won?t work .I replaced ?Ice maker control module? and ?Emitter and receiver icemaker control???..Steel does not make ice . I had been checked the water valve by multimeter , same Khom . I don?t have same idea . Can you help . Water won?t com to the ice maker ..(((((((.
  • ruslan pimutkin May 09, 2010
    See less
    Water com from the dispenser ,and indicator light's water filter on dreen.
    I will do it .Thank you .
  • 17,970 Answers
Once you have installed your ice maker parts, turned the water valve back on and made sure your freezer has been plugged back in to the wall socket, you will need to give your new ice maker parts a chance to work properly. This means allowing enough time for the water to move through the system, freeze, and be ejected as ice cubes into the ice tray. You could need to give the ice maker as much as two hours before you know whether you diagnosed the problem correctly. It's a good idea to do these repairs and replacement of ice maker parts on a day when you can hang around for the entire length of time it may take to make a new batch of ice. Doing so helps you recover from potential leaks and other problems that can arise from either a misdiagnosed problem or an incorrect installation or the ice maker parts that were replaced.
Ice cubs are stuck: If your ice maker is not ejecting the cubes properly, you should take a look at the ejector gear assembly. There are basically two kinds of ice makers; one version gives you access to all the replaceable or repairable ice maker parts. The other is what is known as a "module" ice maker. This type has all the parts grouped together in a unit. If you have this version, the ice maker parts you need to inspect can't be inspected or repaired. You can watch to see if the ice cube ejector blades are trying to work; if they don't, you will need to replace the whole control module. If you have the other type of ice maker, you can inspect your Kenmore icemaker parts, Frigidaire ice maker, etc. Look for a small box configuration with gears. The gears should not be worn or have teeth missing. If they are too worn, are cracked or are missing teeth, the gears should be replaced. Be careful when removing the gears. Some have fasteners that hold them in place; others simply sit on the shaft. Once you have the bad gear taken off, put the replacement ice maker gear part on and make sure the fit is good. Then try another batch of ice. The cubes should eject once more. If it doesn't work the first time, check the gears to make sure they are properly installed and try again.
Checking your water inlet valve: A filter screen on a water inlet valve is a Whirlpool ice maker part that can get dirty, block the flow of water and interfere with the operation of your ice maker. You can check the screen and test the inlet valve with an ohmmeter to see if it needs replacing. This Kitchenaid ice maker part is at the bottom part of the fridge in the rear. Shut off your freezer, and the water supply valve. The inlet valve has wires connecting it to the fridge. Disconnect them. There is a filter screen where the supply hose attaches to the inlet valve. Check and clean this ice maker part. If you find a lot of debris or other kinds of obstruction, this may well be your culprit. No additional ice maker parts will be necessary. If you still aren't sure this was your problem, you can test the inlet valve with an ohmmeter to see if the electrical portion has failed, but this Kitchenaid ice maker part can also go bad in a mechanical way. You may get a good reading on the meter, but still need to replace the valve if it has become mechanically defective. If your troubleshooting has exhausted all the other possibilities, replace the water inlet valve.
Other reasons why your ice maker may not be making ice: An icemaker has something called a fill cup, which holds the water from the supply hose as it is being drained into the ice mold. If this ice maker part is not aligned properly, water doesn't make it from the supply valve to the ice mold, and you don't get any ice. Check to make sure your fill cup is properly aligned. You can check this ice maker part by removing the ice bin and having a look, adjusting if necessary. If you have ice forming on the water spout, you could have a leaky water inlet valve, another ice maker part which will need to be repaired.
Hope this help as first step tp solve it.
Posted on May 09, 2010
  • 154 Answers
This happens all the time to me its when your filter gets clogged just change your filter in your fridge. easy fix
Ice maker stop making ice red light flashing inside freezer water dispenser still works kitchenaid kscs25
the emitter/receiver has gone bad and will need to be changed out. the part number is 4389102 at about 130.00
Feb 28, 2010 | KitchenAid Superba Architect KSCS25INSS...
The icemaker in my whirlpool side by side freezer is not working it seems there is no ice or water in the maker and the motor is not turning
If your ice maker is the type that sits sideways near the front of the door and you have a beam that senses when door is open the emitter and receiver have gone bad and must be replaced along with the ice maker control module located behind the front cover of the ice maker. The emitter receiver runs approx. 120.00 and the module about 80.00. Hope this helps.
Feb 13, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Keeps making ice, i can't seem to make it stop.
You have an emitter and receiver in the freezer section...Actually when you slide the lever on the right side in the middle of the freezer section, you break the beam...and it is suppose to stop the ice maker from harvesting ice anymore. If this shut off device fails, it can fail in the on position and continue to make ice. Replace this assemlby sold in a kit and you will be fine. In the mean time, if you can remove the ice maker head and unplug it, that will stop the ice until you can replace the emitter and receiver assembly. You can also shut the water off but the ice maker will continue to operate, just not dispense ice. If extending and waiting on this repair you should disconnect the ice maker.....
Mar 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker Stopped working
Hello, I don't know if this will help because the model I have is a 106.565(32)400. I have had my ice maker stop working many times because the fill tube was iced up. After about the 8th or 9th time that it did this I decided that I had to find a solution. What I came up with was that the door in front of the ice maker was keeping the tube too cold and making it freeze up. I removed the door to see if was correct. It never froze up again but the ice would fall out sometimes if you had the door open and it was in the dumping cycle. Then I drilled several 1/2" holes in the ice maker door and reinstalled it. I have had no more problems for over a year.
CYA, Gator241
Jan 05, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Kitchenaid # KSRA25C
Some precautions before diagnosing the icemaker optics system since there are two different sets of emitter-receiver optics boards and therefore two entirely different procedures for emitter-receiver optics board diagnosis. This could get really tricky especially when the appropriate tech sheet isn’t handily available. To determine which optics diagnostic procedure should be employed, open the freezer door and observe the right side (mullion or partition side) LED status light. If the red LED is NOT flashing two repeating pulses, this usually indicates the older style emitter-receiver optics boards are used and its specific diagnosis procedure should be employed. But then again, this could also mean that the new optics system IS used but the icemaker just happens to be in the harvest mode - OR - the LED (optics receiver) has failed in some bizarre twist of fate. However, keeping the above cautions in mind, we can assume that normally the older emitter-receiver optics system will NOT have its red LED status light flashing each time the freezer door is opened, while the NEW style optics WILL have its red LED status light double pulsing at each door opening.
Aug 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Thanks but, I knew this part was working
Iceman, here's a little deal I wrote, check it out, Catriver
Diagnosing Whirlpool and Kenmore s/s with ice bucket in door.
Upon opening of the door the emitter light should flash 2 times with a pause repeatedly. Then when holding the left side emitter flap down the light should stay on steady. If you have this scenerio, your emitter boards are working properly. If you do not, check the following:
First thing to check is the position of the ejector blades on the ice maker. They should be at rest in the 2:00 postion. If you find them in any other position than that, it’s more than likely a module failure. The module is located on the front of the ice maker. To remove the ice maker from it’s mount, remove the quarter inch screw holding the harness cover on the lower right side. Remove the harness cover. Now the ice maker will pull straight out. Unplug the harness. The module is held in by 3 screws in the corners and will pull off.
Often, the black fill tube located on the ceiling will freeze causing a no water fill. This can be fixed by thawing with a hair dryer or some sort of baster using hot water.
To jump start the ice maker do the following: Unplug the refrigerator. With the ice maker out of it’s mount but connected to the harness use a insulated jumper wire stripped a quarter inch on each end and place the jumper in the holes marked T & H on the module. Place the ice maker with the jumper in, on the shelf with enough clearance to close the freezer door. Close the freezer door. Plug the refrigerator back in and wait 50 seconds. Now open the door and see if the module is rotating. If so remove the jumper, put the cover back on the module and place the ice maker back in its mount. The water fill should take place when the ejector blades are at the 12:00 position. Note that on some models, after you have done the aforementioned proceedure you have to press and release the light switch 3 times for the module to start.
Dec 11, 2007 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not working
check to see if there is a bin switch one that checks for the amount of ice in the bin..replace or check that the nozzles arent blocked.
Nov 05, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
