Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Timer on dishwasher not working
By cainsts on Mar 27, 2008
Our dishwasher timer is not working through the cycles completely and won't drain the water. It keeps getting stuck in cycles and I have to open and close the dishwasher to make it start again. Is it the timer assembly and is it hard to replace?
Comments:
Mar 27, 2008
- The model number is 36314527 and it is a Kenmore. It's only about 5 yrs old. It seems to stall shortly after it starts washing and before rinsing. It also will not go to the cycle to let it drain. Thanks for your quick reply!
Clarification Request
Posted by tech17 on Mar 27, 2008
what is the brand and model number timer stalling could be caused by a heating deley by a bad thermostat or bad heater depending where its stalling when you use the washer you should always get the water as hot at the sink as you can before starting the wash and make sure the water is at least 125 f
Solution #1
posted on Mar 27, 2008
Not Rated)
tech17
Rank: Guru
Rating: 88%, 1531 votes
ok start the washer after it fills and starts washing open the door again and turn the dial to drain shut the door see if it drains if it does then open the door and turn it to heated dry shut the door and get you a small glass of warm water let it sit in heated dry for about 3 minutes open the door and pour the water on the heating element and let me know if it sizzles
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
kitchen aid model number kudco31vbs is it good
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
spade connector crimp broke off the pressure level switch. got a new crimp but which 2 terminals do... (More)
Answer
I bought a used Jpx-160, it worked for 2 weeks, now it won't fill. The hose is full of water and... (More)
Answer
I have dishdrawer pair. When 1 of them is draining the pump ( ? ) is very noisy( not the main... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in , FL
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
