Question about Black & Decker Bread Machine
Bread machine sparked when plugging into wall outlet
This is an older bread machine. When I went to plug it into the socket there was a visible spark. None of the fuses where blown yet now the machine will not work at all. The screen will not display anything.
    Brigadier General:
  • 4,090 Answers
The power supply of the breadmaker has been compromised. In aa few of the early B&D's tyhere was an internal fuse. However, one has to know why it fused when connecting which begs the question what has happened while it lay dormant since the last usage.
Moisture is usually the fiorst thought, but mice piddle has to be considered too if it has any areas on it that mice could get in. Bare wire on the cord itself is also not to be under estimated as a cause.
Please rate my help++++Thanks for using FIXYA
Posted on May 09, 2010
Washer is not grounded properly
have the outlet checked by an electrician or qualified person to be sure the ground wire on your outlet is properly connected or that you have a good working outlet
Feb 08, 2014 | LG WM-2277HW Front Load Washer
Is special tool needed to change spark plugs
YOU NEED A LONG EXTENSION WITH SPARK SOCKET.YOU ALSO CAN BUY LONGER SPARK PLUG SOCKET AT ANY AUTO PARTS STORE OR SNAP ON HAS IT.
Jul 12, 2010 | 2000 Ford Windstar
This Model likes to shoot electrical sparks between the plug and wall outlet when plugging in. I'm afraid I'm going to burn out an outlet.
This sounds might hazardous! Worry less about burning out an outlet, and more about the risk of electrocuting yourself!
There's an electrical short-circuit somewhere, and the first place to look is the flex. Flex often gets damaged, usually just where it leaves the plug or where it enters the machine, especially if it's been pulled a lot. Damage is not always visible externally. I'd get it looked at by someone competent to deal with electrics. Better safe than sorry!
Feb 13, 2010 | Hoover U8311900 WindTunnel 2 Vacuum
Does it require a special socket to remove RF and LR plugs VT750C
make sure you use either a factory spark plug removal tool or a thin walled socket. if you don't have a thin walled socket you can make one by putting one against the bench grinder.
Jan 05, 2010 | 2005 Honda VT 1100 C2 Shadow Sabre
Change the spark plugs
you need a special socket for your car. its deep socket with thin wall. what i did was to bring my socket to a machine shop and made my tool thinner
Jun 02, 2009 | 1999 Mitsubishi Galant
Freezer Just Stop Working
You should not run your freezer from a strip plug, only from a wall outlet. It is OK for a small spark to occur since the freezer is trying to start the compressor as you plug it in. If there is a big spark that kicks out the circuit breaker if you plug it into a wall socket, then there is a short in the compressor or light circuit in the freezer. A strip plug in probably will not have the capacity to run the freezer. Plug it into the wall socket and try that. If you have a circuit breaker kick out, then it's your appliance. Hope this helps you, Rick
Apr 25, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Pc won't power ( turn on)
The green light is most likely your lan card/port. If the cord/outlet are sparking when you plug it in, I would say try plugging something else into that socket, if you get the same spark, I'd call an electrician. Also try plugging the pc into a different outlet. As far as the computer, if its not the outlet then it is the power supply, your motherboard may be fried in the process but if this isn't an issue with that outlet, then you should take it in to a shop.
Mar 16, 2009 | HP Pavilion a450n PC Desktop
Computer shut down
The sparking has probably caused your circuit protection inside the AC adapter to turn off the current.
Also, when you are plugging an adapter in,,do not have it plugged into the wall power outlet when plugging into the laptop,,,plug into the laptop first and then plug into the wall.
Jan 29, 2009 | Compaq Presario Notebook
Spark plugs
with a spark plug socket, goto autozone, walmart, oreillys, etc and ask for a spark plug socket... You can also just use a thin wall deep socket, there are several different sizes of spark plugs...
Aug 29, 2008 | 1997 Toyota Camry
Will not start again.
If the cord sparked, then it is bad and needs replaement. If it sparked at the plug end, then replace the plug.
Feb 23, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
Black & Decker Bread Machine Logo
55 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
