Question about Cosco 02-442
Take carseat cover off
I need to wash carseat cover off to wash. how?
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 17, 2010
4 Suggested Answers
SOURCE: Can't remove carseat cover
There is a trick to this. All the straps are kinda connected together. The main harness is one piece, a clever clip on each of the lap section. (one on each side) needs to be removed to allow the belt to slide through the seat and cover openings. Once here the strap needs to go through the actual seatbelt buckle. Once the buckles are off you can pull the harness through the shoulder opening. The note to take here is that the harness runs through a loop on the adjuster belt (a narrower belt that runs from the back of the chair under the it to and through the adjusting fastener) Once through the loop you can pull the main harness strap free from the chair. Now the next part, depress the release clip of the adjuster and with the other hand pull this belt free from adjuster. It may require a bit of two handed work as belt nears the end. You should now have a wide belt, a narrow belt, 2x clips and 2x harness buckles. All you need to do now is remove the adjuster which usually requires the manipulation of a metal 'B' buckle which is sewn into the loop to be twisted sideways to allow it to pass through the opening. You are home free now. The cover should be elasticated around the edging and easily removed for washing.(you can also put the straps in too) Now is also a good time to just give the actual seat a good clean too. Refitting is reversal of removal. However REMEMBER and NOTE the way clips,buckles and which openings the straps went through when removing. There are usually a couple. Mark the items with a marker if you think you'll forget. On refitting you might want to put it to the next one up. (as a child grows ie. the shoulder straps should be above the shoulders when the child is seated, equally important is they must be the same on both sides.) I think there might be a couple of slots for the adjuster strap. You might want to move that one out too. Have your child seated in the chair before you start the reassembly and mark out the openings the staps need to pass through which would be most comfortable for the him/her. Good Luck.
Posted on May 30, 2007
  • 55 Answers
SOURCE: cosco summit how do you remove the carseat
Hi there
You might be able to download a manual for your carseat from the Cosco website:
http://www.coscojuvenile.com/usa/eng/Instructions
Blessings!
Posted on Jun 29, 2009
  • 4 Answers
SOURCE: Putting carseat back together after washing..
Here's a manual:
http://www.coscojuvenile.com/usa/eng/DJGFiles/ProductDocuments/43583614D.pdf
Hope this helps!
Posted on Jul 01, 2009
Replacing washed cover of I toddler car seat
Hi
Instructions on removal of carseat fabric can be found in your User Manual. If you no longer have the User Manual visit www.maxi-cosi.com and select the country you're in, then choose the carseat you have and click the Service tab to download a replacement copy.
Sep 14, 2013 | Maxi-Cosi Cabrio Red Flame Reflection...
Can you remove maxi cosi car seat covers
All Maxi Cosi carseats are designed with easily removable covers for washing. Instructions on how to remove them can be found in your User Manual for the carseat. If you need a replacement User Manual please visit www.maxi-cosi.com and select the country you're in, then choose the model carseat you have and an option will appear for viewing or downloading a replacement User Manual.
Apr 07, 2012 | Maxi-Cosi Baby Gear
Hi i have got a maxi cosi cabriofix car baby car seat and cannot seem to remove the cover at the bottom where the grey circle is how do i do this and can i was the cover in the washing machine once...
Good Morning
The grey tensioner strap appears to be stitched in place but it isn't. Follow it around under the bottom of the carseat and the strap is in a piece of plastic catch shaped like an H on it's side. Wiggle one way then the other to unhook from this catch, and the carseat fabric can be removed (where the grey circle part is the fabric is tucked underneath slightly, once you've unhooked the tensioner strap you'll be able to get the fabric off easily).
Hand washing is recommended, but if you have delicate or handwash cycle on machine this is also suitable. Use a mild detergent and maximum temp 30 degrees for washing. Do not tumble dry: Do not leave in direct sunlight to dry. Ensure fabric is completely dry before putting it back on for use as damp fabrics may result in mould or mildew growth.
Remember never remove the harness straps from the carseat, the fabrics can be completely removed while the harness remains in place!
Aug 04, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
TOOK THE STRAPS OFF TO WASH THEM AND AM NOT SURE HOW THEY GO BACK ON
Good Evening
Have you removed the harness from the carseat? This is unfortunately not something you should do even to clean them, as if they are re-fitted incorrectly it can cause safety implications.
Please contact our customer service department on 01284 413141 (Mon - Fri, 8:30 am to 4:30 pm) to book in the carseat for chargeable repair by our engineers. Standard charge is £50 and this includes full safety checks following the repair and courier delivery of the carseat back to your address. In addition you will need to make arrangements and cover costs for courier delivery of the product into the engineers.
Jan 17, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I have a maxi cosi cabriofix car seat and I have washed the cover but I'm having trouble re-fitting the straps. I've looked at the website for them and everywhere on the net but no luck with instructions...
Good Evening
The harness should not be removed from the carseat. Incorrect re-fitting of the harness may cause safety implications so the carseat does need to be returned to our engineers for full inspection and repair work required.
Please contact our customer service department on 01284 413141 (Mon - Fri, 8:30 am to 4:30 pm) to book it in for this. Standard charge is £50 and will include courier delivery of the product back to your address. In addition you will need to make arrangements and cover costs for the carseat to be sent to our engineers.
Jan 06, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Cosco summit how do you remove the carseat
Hi there
Blessings!
Jun 29, 2009 | Cosco Summit High Back 22-260
Need instructions to put harness in carseat back together
my mom has an eddie bauer carseat for my daughter and washed it how do you put it back together
May 24, 2009 | Eddie Bauer Baby Gear
Why is britax not offering the "bodyguard booster" on its website
They retired the Bodyguard carseat back in 2005 so do not offer covers for this carseat. I was looking for a replacement carseat cover myself. If you know a good seamstress you may want to get one made The carseat, otherwise, is still great. I have a Parkway also that I'd like to get a replacement cover for and they retired that carseat in January of last year. It's too bad they don't carry the covers longer. Hope this helps you!
Dec 31, 2008 | Britax Bodyguard - Fiesta
Want to change the carseat cover to wash it
most of the car seat covers do have jip or under tied knots under the seats please do check in there and you can remove it for wash or change. check out for different seat covers in local dealers shop hope you will fine the best maching(color and texture) there. all d best.
Sep 28, 2008 | Evenflo Aura 3s Co Stroller
Cosco 02-442 Logo
218 people viewed this question
Top Cosco Baby Gear Experts
Jennifer Rock
Jennifer Rock
thegtw
noel
noel
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
