Question about Bosch MUM4420UC Compact Series Stand Mixer
I bought a Model HA-3058, it came with everything but the manual, where can i get one?
Kitchenaid frozen bearing
Hi Thaddeus, What model is it? If you have taken it apart and checked the worm gear surely you would have stumbled on the frozen bearing if one exists. When you split the gear cases you are in a position to turn everything by hand so any frozen part is going to be pretty obvious.
Cheers Ross
Apr 24, 2016 | KitchenAid Food Mixers
Tengo una batidora y ya le cambie los carbones y no me funciona que puede ser
Hola LALOB_RO. Cuando cambió los cepillos (carbones), es posible que haya instalado uno o ambos de ellos para que los cepillos no encaja correctamente. Sólo hay un camino para que los cepillos que se ha instalado correctamente. La caracóncava del cepillo debe descansar por completo en el conmutador de la armadura. Siusted lo ha girado 90 grados demasiado, el cepillo no se asienta correctamente y elmotor no hay nada 'jugo'.
Le recomiendo la eliminación de los pinceles de nuevo para comprobar que ambosestén instaladas correctamente. La ilustración de arriba debe permitir volver a instalarlos pinceles con confianza. Buena suerte, espero que esto ayude. Howard, Burke, VA,EE.UU.
Si esta solución ha sido útil, por favor, valoren, gracias! - hslincoln
Feb 10, 2011 | KitchenAid K45SS Classic Stand Mixer
We just bought a Kitchenaid Pro 500. It was not
Hi JBKRIEGER, Happy New Year! Yes you can download both your Owners Instruction Manual and Parts List Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number and then select the appropriate files under Owners Manual for your Instruction and Recipe manual and the file under Parts List for your parts list manual.
The Parts List manual provides an exploded view for the disassembly and reassembly of your mixer, along with all the part names and numbers. (Definitely check to see it this matches your mixer). You may not need it now, but if your mixer is out of warranty and you want to attempt to troubleshoot and fix your mixer yourself if something goes wrong with your mixer, you’ll definitely need that parts list manual.
Good luck with your KA mixer, Howard, Burke, VA.
If this solution was helpful though, please rate it. hslincoln
Jan 10, 2010 | Food Mixers
Age of my a-200 mixer
if it has a spec.# instead of a ml.#it would have to be at least 25-30 yrs. old
Jul 04, 2009 | Hobart A200 Stand Mixer
Missing recipe book
Hi. Goto kitchenaid.com download the manual for your mixer model. Your recipe should be in it. If this solution has assisted you, please rate it
Mar 14, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Where do I get new blades for my Household Blending Mixer HA-3058
It seems you can no longer buy the MegaMixa HA-3058 however Bamix sell a similar product - in fact apart from a couple of aesthetic modifications it seems to be the same machine....
They sell many accessories and you can get blades. Check:
www.bamix.com
www.bamix-blender.co.uk
I have both machines and the blades are identical and inter-changeable between models.
Feb 23, 2009 | Food Mixers
N-50 service manual
Hobart keeps there service manuals for their techs only and do not provide them to the general public,Give me a little time and a fax number and ill see what i can do.
Dec 14, 2008 | Hobart N50 Stand Mixer
Kitchen aid 110v 450watt, I want to convert to 220v
Hi guys,
The only available Kitchen Aid stand mixers on the European markets are the Kitchen Aid Classic and the Kitchen Aid Artisan.
The best way is to contact a Kitchen Aid service center / repair facility in your area.
Here is the European website of Kitchen Aid: http://www.kitchenaid.eu/eu_EU/ka/ka_europe.htm
If you bought a different Kitchen Aid Stand Mixer (like the Professional series) you probably won't find the required parts to convert it to a European model. The only way would be to use a voltage converter.
I hope this helps.
Sep 24, 2008 | Food Mixers
Instruction for household blending mixer
This is part of a kit called the Thunderstick Pro. You may have better luck looking it up that way.
Dec 29, 2007 | Food Mixers
Bosch MUM4420UC Compact Series Stand Mixer Logo
118 people viewed this question
Top Bosch Food Mixers Experts
Oscar Netto
Oscar Netto
Paul Bade
Are you a Bosch Food Mixer Expert? Answer questions, earn points and help others
