Marantz SR7400 Multi-Room with Sonamp 2120T MKII
I have a multi-room (outdoor speaker set) hooked up to my Marantz SR7400 driven by a Sonamp 2120T MKII. I recently moved and re-installed everything, including my outdoor speakers. The day it was first installed, the outdoor speakers worked but the Multi-Room system on the Marantz stayed on all the time--causing it to heat up. I was able to turn off the Multi-Room, but now when I turn it back on, the Sonamp won't kick on as it should--and so therefore no outdoor speakers. I believe I pressed some buttons accidently on the Marantz or the remote--and now the Sonamp doesn't get the audio signal from the CD line out and won't kick on. Do you have any suggestions?
Thanks,
Liz Walker
  • Liz W Mar 27, 2008
    I've read both manuals cover to cover and done everything. I'm sure I'm missing something. Do you have a specific suggestion?
    Thanks,
    Liz
    Mmm...that's not very helpful. I've not made any changes to the cabling since the system did work the first time. One possibility would be a bad wire from the Marantz output to the Sonamp. But I want to make sure I have the settings correct on the Marantz before I start unplugging. It's very complicated and hard to get back there.
    Liz
    Brigadier General:
  • 3,614 Answers
A possible overheating on the device has cause the unit to malfunction. It's possible that because of that overheating on the unit some parts have given up, and broke.. This happen occured when overheating on the unit, and sometimes it may go to shut down and not powering on..
Posted on Mar 30, 2008
  • 3,037 Answers
Try this
It is the manual and page 23 might help you out, if it doesn't, then browse around and let me know if you still can't figure it out.
Hope this helps, good luck and have a good day
Posted on Mar 27, 2008
  • 2 more comments
  • Benjamin Patri
    Benjamin Patri Mar 27, 2008
    try rewiring the speakers that aren't working into a different slot that works if possible and let me know what happens
  • Benjamin Patri
    Have you tried contacting the manufacturers about this problem, I will give you the numbers and maybe they can help you, I will keep looking and trying to figure this out though
    Here is the contact info for Sonance tech support
    • 1.800.582.0772
  • Benjamin Patri
    Marantz Contact Information
    Main support number (630) 741-0300
  • Benjamin Patri
    I'm going to say it might be either a fuse problem, power supply problem, or switch problem.
    Master:
    Sergeant:
  • 482 Answers
I would start over, unplug them and start over.
SOURCE:
Marantz SR-7200 volume -29dB blinking
Check Speaker connections at BOTH ends and double check to see that they are on the right terminals.
If you need a manual . the Marantz site will have one . PLus they may have FAQ notes for that receiver
Cheers
Mar 01, 2014 | Marantz SR-7200 Receiver
Marantz SR5500 B speaker setup problem
are all the speakers connected 1.5s
all the same watts helps
is that one with an inbuilt amp ?
what a mess or connectors at the back of one of these
Model SR5500 User Guide - Marantz
us.marantz.com/DocumentMaster/US/DFU_SR5500_Final_Eng.pdf
Apr 16, 2017 | Marantz SR5500 Receiver
I have connected the audio from 3 devices into the 3 optical inputs on my Denon AVR-3300. Audio for each device plays perfectly through main speakers but not through the multi-room output (which goes to...
the unit is ok. User manual on page 42 says that the digital sources can not be output trough multisource output.
Try to use VCR-1 VCR-2 audio output jacks instead.
Sep 24, 2011 | Denon AVR-3300 Receiver
Multi room will not play any digital input, just analog. I.e. Video 1 when analog connection plays in multi room, but optical 1, when set as input for vid 1 will not play in multi; works fine in main...
I have a Marantz 7.1 AV receiver (sr5500) and I run a 5.1 set up for home theatre and use the 2 extra channels to run a pair of outdoor stereo speakers... When I first set it up I also found I could not get a digital signal output, only analog, after reading the manual(!) I discovered that it can only output an analog signal...so I have used the phono outputs on my blu-ray player into the CD input of the AV amp and play CDs outside through this and it also outputs the optical digital signal into the AV amp through the DVD input...my iPod also plays through a dock and it's analog output to the speakers outside through another (CD-R) anolog input on the amp... Hope this helps
Dec 24, 2010 | Harman Kardon AVR 335 Receiver
I have a Sonamp 260 MKII. The red light is on but the green light does not come on. I've unhooked all speaker wires and input wires. Now what?
The red light will stay on without speakers connected.
Make sure your speakers are good and try again
If it still fails then there's a power supply failure internally
Aug 02, 2010 | Sonance Sonamp 260 MKII 2-Channel...
I have a Denon 2309 and i hooked up a pre amp to use for my multi room. the issue i'm having i hear the radio station for my multi room, but when i put on my ipod. my multi room still plays the radio...
The iPod signal has to go to the pre-amp as well as the living room amplifier.. You'll have to move the iPod connection so it replaces the radio signal to the pre-amp as it does with the living room amplifier.
Nov 22, 2017 | Denon AVR-2307Ci Receiver
Multi Room Function on marantz SR-19
Hi..
Put a RCA (phono cable) splitter at the pre-out /main in.
That way you can go to both amps with the same signal
Jan 14, 2009 | Marantz SR-19 Receiver
Sonance 275 no getting sound to speakers
The Sonamp 275 has Signal LEDs on the front panel, above the Volume pots. If signal is present at the RCA inputs, the Signal LEDs will be blinking.
Most likely, there isn't any line level audio signal coming from the receiver. Hook RCAs to Tape Output or MD output and check system using the Tuner which is an analog signal.
Jan 11, 2009 | Sonance SAT275 2-Channel Amplifier
137 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
