Question about Canon PIXMA MP150 All-In-One InkJet Printer
Paper not going through feeder paper going off to one side of printer
    Brigadier General:
  • 4,090 Answers
Usually this is caused by a piece of torn paper occulding the paper path. or a shiny area on the paper feed rollers.
1) for paper jam: Use a peice of stiff card and place it in the printer use word pad to print a single full stop and that will start the card to begin to roll through the path. apply some push to it to keep it straight in the effort to snag that paper and have it ppushed out of the rollers
Yse a plastic polly mit and run over rollers to slightly roughen them and remove the ink shoine on them, especially the side that has the problem.
Feed a new piece of paper into the printer and check that it is now printing correctly
Please rate my help++++Thanks for using FIXYA
Posted on May 09, 2010
Soulvisitor
  • 1113 Answers
SOURCE: Paper feed problem
Sound like something foreign is in paper path
Posted on Dec 24, 2007
pagebor
  • 2785 Answers
SOURCE: feed problem
dear colmaj
your printer paper sensor is strucked or malfunctioned.please open the printer and check for any dislocation of the sensor.or you send your printer for service
Posted on Apr 08, 2008
Ajkill
  • 2035 Answers
SOURCE: LEXMARK 2470 PAPER FEEDER PROBLEM
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck....
Posted on Sep 13, 2008
sys_admin
  • 829 Answers
SOURCE: paper feeder on epson cx5500 won't grab double sided paper
Hi ,
No You cannot there is limit for the printer to take on the paper , For heavy duty printer you need to check on some other printers.
Posted on Feb 01, 2009
SOURCE: canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Posted on Jul 10, 2009
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
The printer keeps telling me it's out of paper, which it isn't
1> Open the sheet feeder cover and pull out the paper support.
Set paper, aligning the right edge of the paper to the cover guide with the paper's print side facing up.
Pinch and slide the paper guide to the paper's left side.
Note: Make sure to set paper lengthwise. Setting Credit Card sized paper long-side down by mistake may cause a paper jam.
Pull down the paper output tray supporting with both hands.
Pull out the extension completely.
Ensure that the Power lamp and the Auto Sheet Feeder lamp light.
Note: If the Cassette lamp lights, press the Paper Feed switch to light the Auto Sheet Feeder lamp.
If the Auto Sheet Feeder lamp does not light even after pressing the Paper Feed switch, Paper Source in the printer driver may be set to the setting other than Paper Feed Switch.
Nov 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
My epson stylus r265 wont feed paper it just chews it up
Most printers now are made of plastics and very light…when you store your printer in hot enclosed place that will affect the printer, and you can see the result on the prints, paper feeds, etc. you need to clean the printer if you did not used for over one week by conducting software head cleaning and open the door for the paper feeder and clean all around the inside…you have a jammed paper in the back that push the feeder out from the track and end up been shredded, make sure that all the doors closed very good and that the paper tray has the side track very close to the paper from the sides so the papers do not move side way when they go inside the feeder… Let me know if this what you are looking for, and please rate my service so I am able to continue serving everyone and improve on it.
Sep 21, 2009 | Epson Stylus R265 InkJet Photo Printer
Hp deskjet 5550 is grabing the paper but paper prints crooked
You may have a paper jam (small paper cut) in the feeder ytry to check it and see if you can clean it...or you may bent the feeder...open it and let me know
Sep 13, 2009 | Office Equipment & Supplies
Canon mx300 printer feeder pulls unevenly causing paper jam
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Saying paper jam dcp-135c brother printer
 Hello there,If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for Laser printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
do not forget to rate this solution....good luck
thanks for using FixYa
Jan 30, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Paper feed on Canon i 350n ink jet printer
Ensure that:
The paper is a recommended paper for inkjet printers.
May 13, 2008 | Canon i350 InkJet Printer
Paper jam
I removed paper from jam, red light will not quit flashing, I turned
printer off and on again, but it will not print and red light will not
quit flashing, What can I do?
May 12, 2008 | Office Equipment & Supplies
Jammed paper
Ensure that:
Apr 28, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Paper jam
Ensure that:
Jan 04, 2008 | Lexmark X1240 All-In-One InkJet Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
149 people viewed this question
old marine
old marine
