Question about Dryers
I can't find my manual. How do I use the sweater
I can't find my manual. How do I use the sweater drying rack?
  • Jyackle5
    Jyackle5 May 11, 2010
    May I get the model # of the frigidair dryer to help you.
    New Friend:
  • 84 Answers
Just go through The Higher Shop get you choose sweater and use long time for all male and female clothes. If you would like buy more different types of clothes here only.
Posted on Apr 20, 2015
  • 10,319 Answers
Http://laundry.manualsonline.com/manuals/device/clothes_dryer.html
Posted on May 09, 2010
It's my fox ( name brand) sweater . the fabric is acrylic . All I did was machine wash it then when I took it out I saw that it looked and felt different. So I wet it in cold wash try to get as much w
I have an acrylic blanket that feels different when wet, sort of tight. But when it dries out, it is soft and sort of spongy like before. Hopefully this will be the case for your sweater.
Feb 16, 2013 | Clothing
Realistic TRC-459 manual
  • Hi Marc. There really is no free users manual online for this CB. But if you go here http://support.radioshack.com/support_electronics/26577.htm there will be options you can click on. It's basically the manual split up into links. It will tell you everything about your radio and the pages are printable just the same. You will see what I mean.
  • Hope this helps.
Nov 25, 2011 | Radio Communications
Hi, I have a Bond Sweater Machine, I need to recalculate the stitches and cm. from a hand-knitted sweater with a knitting machine. I know it can be done, it's something to multiply and divide, get the...
Hi. I have a Bond, too. Even if you get a formula to recalculate the numbers of stitches per inch/cm I would suggest that you do a gauge swatch with the Bond before you start knitting the actual sweater. There is a terrific group of fellow Bond machine enthusiasts and experts here: https://groups.yahoo.com/neo/groups/incrediblesweatermachineclub/info
They have free patterns, tips, and advice. They have some manuals posted, too. :)
Jul 10, 2011 | Bond-America Ultimate Sweater 01008-9
How do I use the dryer rack?
The dryer rack is used for laying out clothing that you don't want to get tossed around. Example: Sweater or tennis shoes. It sits in a groove behind front door and sits in groove at back of tub.
Sep 27, 2010 | Samsung Dryers
I have a whirlpool duet dryer.. I need to know how to put in the rack for the tennis shoes.. HELP
Hi dear.Here is some help from the user manual.I hope that helps.Thanks. DryingRack
To use the drying rack
Do not remove the lint screen.
1. Open dryer door.
2.
Place drying rack inside dryer drum, positioning the back wire
on the ledge of the inner dryer back panel. Push down on
front edge of drying rack to secure over the lint screen.
3.
Put the wet items on top of the rack. Leave space between
the items so air can reach all the surfaces.
NOTE: Do not allow items to hang over the edge of the rack.
4.
Close the door.
5. Select a timed drying cycle and temperature, or an air cycle
(see following chart). Items containing foam, rubber, or plastic
must be dried on a clothesline or by using the Air Only
temperature setting.
6. You must select a time by pressing MORE TIME or LESS
TIME. Reset time as needed to complete drying. Refer to the
following table.
7. Press (and hold) HOLD TO START button (about 1 second).
NOTE: You must remove rack for normal tumbling. Do not use
automatic cycles with the drying rack.
This chart shows examples of items that can be rack dried and
the suggested cycle, temperature setting and drying time. Actual
Rack Dry Setting Temp. Time*
Wool Sweaters
Block to shape and lay flat onthe rack.TimedDryLow 60
Stuffed toys or pillows
Cotton or polyester fiber filledTimedDryLow 60
Foam rubber filled
N/A Air Only(noheat)90
Sneakers or canvas shoes N/A Air Only(noheat)90
drying time will depend on the amount of moisture items hold.
Aug 30, 2010 | Whirlpool Duet Front Loading Dryer Rack...
What is the rack for
The rack is to dry things like sweaters or shoes that you would not want tumbling around. When used the items are stationary and the drum rotates around them. Low or no heat can be used to facilitate drying without shrinkage or damage.
Eric
Jul 15, 2010 | Maytag Dryers
How do I install the drying rack. i have never used it and can't find my manual
i dont have your model # , but on most models you take out lint filter and pu the rack inside the dryer drum.the one end of the rack that looks like it goes into something goes into the filter housing. hope that helped you ....
Sep 13, 2009 | Dryers
Is fading and shrinking my clothes
low temperature and low rpm of motor,must try this.
Feb 16, 2009 | Frigidaire FTF2140F Front Load Washer
Dryer Rack
On mine, nothing "clamps down". There are 3 positions in the plastic rack into which you can insert the wire rest - "F", "H", and "A". God knows what they mean (I think the one rack is intended to be used in various dryers, of different depths), but if I use the rearmost position = "A", the back end of the wire rest rests on the non-moving rear of the drum, and the front of the rack rests on the lint screen holder. Seems to work, but the instructions leave a lot to be desired.
Dec 09, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
171 people viewed this question
Top Dryers Experts
