Question about Garden
2002 20hp. 48" cut M# U609H . twin cyl. B&S. Turns over but no start ! Only one cyl. firing! Ran great aweek ago! Plug gunked up on one cyl., but other plug good tan color
  • 284 Answers
Should actually run on one cylinder,but noticeably rough and lack power.
anyway Remove plug from fouled cylinder clean it or replace it next put plug in spark plug boot and ground it near the cylinder against metal ,get on mower and attempt to start as normal and watch the plug for spark? yes ? put plug back in and torque to 18 ft.lbs and gap at .030. if no spark you may have a bad ignition coil for that cylinder or a blown cylinder piston connecting rod or piston ring issue.Find a compression gauge and insert it in that cylinder and turn engine over as if you were trying to start it and watch the gauge, and to determine what reading you should have check the known good cylinder first,if you dont have a gauge put your finger over the sparkplug hole on the supposed bad or fouling cylinder and have someone crank the engine over,you should feel air coming out on compression stroke pushing against your finger and with a small flashlight look into the sparkplug hole to see if the piston is moving back and forth in that cylinder
try to use common sense with this procedure so no one gets hurt !!!
Posted on May 09, 2010
Is there a quick fix, easy fix if no, tell me the right way.
it sounds like there maybe jets within the carbs that maybe blocked.
Im not familiar with the carbs you mentioned but they all work in a similar way. The jets are small tubes that screw into the body of the carbs (internally) and have small pin holes in them similar to a sieve that let the fuel pass through, the tiniest speck of debris from the tank or fuel lines can block these.
Is the bike fuel injected? if so it could be the injectors, they also have a very fine mesh over the end where its inserted into the cylinder head, these could be faulty or possibly blocked.
Hope its of help
tony
Jan 22, 2016 | Yamaha 97-98 Mountain Max Vmax Sx Sxs Xt...
My 2002 chevy 1500 van , 4.3 liter v6, will not fire. ran great, no signs of trouble leding up to now. Cranks,cranks, & cranks but no sputter, fire, anything
I would check and be sure I had fire to the plugs and fuel to the throttle body. I read what you wrote about the fuel pump but then on the end of the description where you put gas in the van the pump might not be working. If so you could have a bad wire to the fuel pump or a plugged fuel filter. Once you verify those items I would pull the 02 sensor ahead of the catalytic converter in the exhaust and make sure the cat or muffler is not plugged. If they are it will put back pressure on the engine and not allow fuel into the cyl. to fire.
May 23, 2017 | Chevrolet 1500 Cars & Trucks
My intek 22hp 441777,0284e1 uses oil it has 155-160 psi comp. on both cyl.new oil ,new air filter,crankcase check valve working fine and clean, plug on left from front i think#1 was fouled cyl.heads were...
either the cylinders are glazed[ does it do much idleing?]or you need to use a heavier grade of oil which is the simple solution . 200 hours is nothing i`v had honda`s that will do that in 3 weeks.and you wont toutch them for 18 months or more.give it a light hone or go to a20w/50 oil
Oct 22, 2009 | Briggs & Stratton Briggs Stratton Intek V...
125 twin recent rebore 1000 miles ago one exhaust
Its a little hard to tell without seeing the exhaust color.Black is oil.brown is fuel.If the bad cyl. still has a good plug it may not be oil.Check the smoky exhaust carby.It may be you do not have complete firing on the bad cyl.MAYBE.Does the bike run well once you get the revs up under load?Check for inlet leaks that may change the fuel mixture on the suss. cyl.There is a few more things but start at these things 1st.After a complete rebuild,these problems do start.I hope this helps
Aug 23, 2009 | 1972 Honda CB 250
Changed glow plug relay in sunny florida still can start
sounds like you have no compression amego 7.3 do that but check the glow plugs with an ohm meter, if the glow plugs to shine it won't run, and whil your at it check your oil level if it's high your fuel pump just craped out.
Jun 25, 2009 | 2001 Ford F350 Super Duty SuperCab
Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
May 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
