Question about Microsoft Windows XP Professional
Good day, My microphone seems dead, How can I check if the computor is finding the driver or how can I switch it on if it is off thanks joe
  • 70 Answers
[Start],[Run], mmsys.cpl
3:rd tab "Audio"
2:nd Heading "Recording"
1:st button "Volume"
Make sure volume for microphone is at about 50%
and that it is selected.
[Start],[Run], sndrec32.exe
Press record
Make sound in the mic, should get waves on graph.
Playback.
Posted on Jul 31, 2010
2003 Camry 4cyl. Smoked when first started. Removed head and did valve job including new oil seals. runs perfect. Every 3 days the ses light comes on with p0301. still runs perfect. swapped coil,plug and...
P301 is mis fire in the no 1 cylinder 1st start with compression then check fuel injector wire to in ejector fuel pressure.bad computor.clogged fuel line.coil could misfire. Bad plug.let me know
tuff to find sometimes.shop Forman at dealership best bet if you can't find.bad computor hard to find.lose,wire.good luck sorry
ck ck ck.
Feb 21, 2015 | 2003 Toyota Camry
Dead battery two days in a row dome light wont go off signal lights dont work
Hi Joe, I believe you have a defective door switch (if you didn't leave the door open?) Check the switch. Regards John
Oct 19, 2012 | 2006 Chevrolet Impala
Windows Movie Maker
try this ant use windows dvd macker to burdn you cd or dvd
Apr 12, 2010 | Microsoft Windows Vista Home Premium...
Camcorders
You can connect your Canon analog camera to your PC with the "cinch or S-Video" cables that came with it when it was new. Your Digital PC will have to have a compatible video card for the above mentioned connections. You can upgrade your Graphics Card if your PC's isn't compatible.
Jun 06, 2009 | Canon Video Cameras
Have changed computors and have lost my install cd for the hp deskjet 940c. is there a download that I can get off the internet.
Hp is very good for being able to download drivers to their products. Go to www.hp.com and to support and then drivers and select your make and model to download thr drivers for it.
Joe
May 21, 2009 | HP DeskJet 940c InkJet Printer
No sound coming from wireless mic
check the battery, if dead replace new. check the switch might be a cold solder or loose wire and finally check the condenser mic by placing a multitester to the two connectors of the mic with one wire from the mic desoldered. if there's a continuity, then its good. if there's no continuity the mic condenser is busted. go to radioshack and find replacement mic condenser.
Mar 28, 2009 | LeadSinger LS-3222 Consumer Microphone
Microphone not working on Dell Laptop
If you can hear windows booting up then the sound card is ok..you can double check it in Device Manager. To ensure the device drivers are up to date. Just find the sound card in the list of devices in Device manager and click on the "+" to expand it. Then right click on the sound device and click on update drivers. You can also uninstall the drivers and reboot. Plug and Play will pick up the correct drivers..double-check the cables also...good luck. Let me now if you have any questions
Mar 22, 2009 | Dell Inspiron 1525 Notebook
2001 Dodge Grand Caravan Sport around 70k miles. 3.3L V6 Radiator fan sometimes stays on until battery is dead. Sometimes it stays on when engine is shut off, sometimes the fan starts up on its own many...
It is activated by a temperature switch. It's probably bad. Just runs the fan at any time for no reason or there is a short in that part of the system. I hate that the computor was changed first. Find that sensor and swap it out and see if your problem doesn't go bye bye.
Good luck
Feb 27, 2009 | 2001 Dodge Caravan
No speaking ability
The mute button on these is the little black button on top of the earpiece. It will only be on if you turn it on during a call. If you turn the headset off, the mute button goes off as well.
Check the compaibility 'wheel' on the side of the base station. The most common setting is 1 but some phones use 2,3 & 4. Just try it on each setting until it works. Other than that, check the microphone volume adjust setting underneath the base (ABCD switch) and see if changing that makes a difference. Of course there is always a small chance that the microphone is dead.
Oct 31, 2008 | Plantronics CS50 Wireless Headset
Headset problems
check ur driver ,microphone cable ,pin, condenser microphone ,and socket
Feb 18, 2008 | Shure Head Set Microphone Microphone
Microsoft Windows XP Professional Logo
42 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
