Question about Directed Electronics D600 Car Amp
Boss d600.2 goes in pertect mode when volume turned up at 2ohms. why its suposed to be 2ohm stable
  • 5,603 Answers
Unfortunately, 2 ohms isn't necessarily 2 ohms.
A speaker's impedance varies with frequency AND the enclosure.
NEVER believe these manufacture's specs for auto audio things.
If you overdrive a speakers so that he cone moves out too far, the impedance drops.
Posted on May 09, 2010
Got 2 woofers, 2ohm stable each. If I get 1ohm stable monoblock amp, will it split that 1ohm equally in 2ohms for each speaker, or would I have to buy another 2 speakers that r 1ohm stable each?
Connecting the two 2 ohm speakers in parallel will create a 1 ohm load. Connect the positives of both speakers to the plus output of the amp, both negatives of the speakers to the minus output of the amp.
Sep 19, 2015 | Car Audio & Video
I have 2 12 inch kicker rt dual 2 ohm subs. On a kicker cx1200.1 i want to kno how to hook it up to 2ohm to the amp. And if i can add another 10 inch kicker rt 2ohm sub in the future.
Do to the impedance Of your sub u can't run it @2ohms its going to either be @1ohm or 4ohms and your amp isn't 1ohm stable and u will risk damaging your amp. So your only option is to run it @4ohms and on a good note your sub is 100-600 watts RMS and your amp will push 400-500 watts RMS @4ohms. Now if you want to run 2 sub's in the future That amp will work perfect because it pushes 1,200watts RMS @2ohms and to wire your 2 sub's @1ohm just follow the steps in the image below. Hope this helped.25345194-v0hbouy2nvquqteoroa5j5rq-3-0.png
Dec 30, 2014 | Car Audio & Video
Is a boss audio RIP 695 amplifier 2ohm stable on bridged mode?
no, it is 2 ohm stable in stereo for 700x2. the 1400 b ridged power assumes 2x2 ohms=4 ohms bridged @1400 watts
Aug 19, 2014 | Car Audio & Video
Alpine x is not reading proper ohm resistance amps blew
the gmax amps are only 2ohm stable. it is odd that they both blew at the same time but if the impedence is too low to amps will fail.dual 4ohm dvc subs wired in parallel should read around 2ohms. allthought impedence varies with frequency and isnt truly stable.
Feb 12, 2010 | Alpine SWX-1042D Car Subwoofer
I just want to know if running this amp at 2Ohms is ok
unless the amp says 2ohm stable dont somethings gonna fry try to get it to 8ohms you equipment will last alot longer
Jan 27, 2010 | Solid Audio Formula Series F41 4-Channel...
What amp do i need to power a Polk Audio db1040DVCin brigded connection, i only plan to run one sub, i want to bridge the sub for better sound quality, and i'm buying straight polk, what do i need
Hello oran1891,
OK, you don't bridge subs. You bridge amps, if they are capable of being bridged (not all are).
Bridging is a method of connecting the channels of a multi-channel amp in such a way that the amp delivers the output of 2 stereo channels into a single mono load.
The Polk DB1040DVC is a sub with dual 4ohm voice coils. You can wire the voice coils to present a final 2ohm load (parallel) or a final 8ohm load (series). The rated power range is 50-270 watts RMS. Since you can parallel the voice coils and have them present a 2ohm load to the amp, you are looking for an amp that provides a minimum of 50 and a maximum of 270 (round it up to 300) watts into a 2ohm load. The Rockford-Fosgate Punch 300.1 shown here for $170 seems tailor made for your Sub. If you can make do with less power and want to spend a little less money, the Orion Cobalt CO500.1 will deliver 250 watts RMS at 2ohms and you can buy it for $140. The punch is a better deal. If you decide to add another sub later, it will power them both with 150 watts each, a little low, but still decent. If you want a 2-channel bridgeable amp, I'd recommend the Kicker 08DX3002 shown here for $200. Note that in bridged mode, it is not stable at 2ohms, only down to 4ohms.
Hope this helps.
Jul 17, 2009 | Polk Audio DB1040DVC Car Speaker
How do you wire 4 kicker cvr dual voice coil 4ohms to a 1500.1 kicker mono block 1 channel amp, they sound distorted when i turn them up, how should i wire them?
Hello antjobe,
According to Kicker the 1500.1 is only stable to 2ohms. So you will want your 4 CVR's to present a 2ohm or higher impedance to the amp.
The best configuration would be to wire the voice coils in series (each sub 8ohms) and then parallel all of the subs to the amp (2ohms). Here's a link to the diagram.
Hope this helps.
Jun 08, 2009 | Kicker CVR12 Car Subwoofer
Got a 12"kicker L74ohm sub and sony xm-D9001GTR mono amp
Hello juan_penaloz,
The Kicker L7 has an RMS power range of from 50-750 watts and a maximum power handling capability of 1,500 watts so your Sony amp will power it OK. A more powerful monoblock like the Alpine MRP-M1000 or the Kicker 08ZX750.1 would provide even more power and could operate safely at 2ohms.
You have the voice coils wired properly for the Sony amp. It's OK to have the sub impedance higher, but you definitely do not want it lower than the 4ohms the amp is rated at in bridged mode.
Hope this helps.
May 26, 2009 | Sony XM-1252GTR Car Audio Amplifier
How do i hook them up to work for 2ohm's
Hello rcantu76,
If your CVR's are 2ohm (model Nr. 07CVR122), you connect the voice coils in series and then parallel both subs to the amp. If the subs are 4ohm (model Nr. 07CVR122), they cannot be wired to 2ohms. Your choices are 1ohm or 4ohms. According to Rockford-Fosgate's data on the P1000-1bd, it is stable at 1ohm.
To wire the 122's at 2ohms, you would connect the sub voice coils in series (jumper one positive to the other negative on each sub), and then connect the remaining positives and negatives to the amp.
To wire the 124's at 1ohm, you would connect all of the positives and all of the negatives together to the amp.
Hope this helps.
May 11, 2009 | Jl Audio 500/1 Car Audio Amplifier
Directed Electronics D600 Car Amp Logo
49 people viewed this question
Top Directed Electronics Car Audio & Video Experts
xxxxxx xxx
Are you a Directed Electronics Car Audio and Video Expert? Answer questions, earn points and help others
