2005 kawasaki KX 125 Logo
Anonymous Posted on May 09, 2010
What is the Kawasaki kx 125 compression i did test tested 135 with cold motor is this what it shuld be i get real bad bog at low rpm
Danny
Level 2:
Scholar:
  • Expert 127 Answers
  • Posted on Jun 09, 2010
Danny
Expert
Level 2:
Scholar:
Answers
127
Questions
Helped
55207
Points
318
Anything over 120 on compression test is ok. anything under 120 and its time for top end. and for bog you might try cleaning carb.
Kx 125 sputtering in high rpms
check and make sure choke is opening all the way,if it is only opening part way could explain why you don't need to use choke at all to start and then at higher rpm's it is not getting enough air causing it to basically choke it self out.
2004 Kawasaki KX 125 quit running
Hey Steve
Put a new spark plug in first...
... Sounds more like a fuel delivery issue... (the jests are in the carb and are considered one item). IF THE ENGINE HAS BEEN MODIFIED - FIND A REAL PRO THAT KNOWS HOW TO JET AN ENGINE - I CANNOT STRESS THIS ENOUGH - THIS IS not FOR AMATEURS!!
Make sure you have fuel flowing to the carb..(turn the gas off at the petcock - remove the gas line and then turn the gas on -- if its flows quickly and a full stream - turn the gas off, reconnect the gas line. Now, on to the carburetor... IF you are a great mechanic, you can clean and set the carb..IF NOT - take it to a qualified pro!! After the carb is cleaned and set.. it should run great...
Please reply to me when you are done with these steps..
My 1990 kx 125 stalls after about 5 mins of riding....it bogs down through the gears and stalls
is the compression good on your engine have you checked and cleaned the carb out also are you running the right pre mix ratio about 32:1 which is about 156 ml oil to 5 litres of petrol
1helpful
Need gas-oil ratio on 2004 kawasaki kx 125 2 stroke bike
32:1--40:1 any less than 40:1 And you take risk of damaging engine(crank and top end),Any more than 32:1 and it will smoke real bad and foul spark plugs alot.....
3helpful
2answers
I have an 86 kx 80 my problem with it is it doesnt have enough power sometime it does and somtimes it doesnt up a hill it goes slow and when in nuetral and i rev it hight it high it will not have a...
Could have low compression or bad reed valves, if you take your hand and move the kick starter is it easy to do? i would do a compression test.
Top kawasaki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a kawasaki Expert? Answer questions, earn points and help others
